Bueno, volvemos otra vez, y con malas noticias, ayer por la noche, volviendo a casa pinche(dios que alegria...), y hoy por la mañana me levanto y nada mas enciendo el coche para lleva a arreglar la rueda me salta el testigo de averia de motor con esto:
Friday,11,November,2011,11:24:56:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 8T0
Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 36 37 42 46 47 52 53
55 56 67 77
VIN: WAUZZZ8T68A001236 Mileage: 116840km/72601miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
67-Voice Control -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb
Part No SW: 8K0 907 401 HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0010
Revision: --H01---
Coding: 01140023180F0120
Shop #: WSC 00280 572 92669
ASAM Dataset: EV_ECM30LTDIA5 A01014
ROD: EV_ECM30LTDIA5.rod
VCID: E8D43AFEE4294D5C
4 Faults Found
4807 - EGR System: Insufficient Flow
P0401 00 [096] - Short to Ground
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 114927 km
Date: 2011.11.07
Time: 15:30:58
5308 - Throttle Body Actuator Bank 1 (J338): Implausible Signal
P0638 00 [175] - Electrical Fault in Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 116623 km
Date: 2011.11.10
Time: 20:23:07
7155 - Intake Manifold Flap Position Sensor (Bank 2): Implausible Signal
P2020 00 [032] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 116623 km
Date: 2011.11.10
Time: 20:23:07
5417 - Glowplug for Cylinder 5 (Q15): Open Circuit
P161E 00 [109] - Open or Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 112197 km
Date: 2007.02.01
Time: 13:49:52
Readiness: 1 1 0 0 0
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 289 D HW: 8K0 907 289 D
Component: BCM2.01 H36 0253
Revision: 00002001
Coding: 070000
Shop #: WSC 06325 000 00000
VCID: 3A7030B64A058FCC
Part No SW: 8T0 959 754 K HW: 8T0 959 754 K
Component: FBSAUDIB8 IDG H34 0050
Part No SW: 8K0 905 852 A HW: 8K0 905 852 A
Component: ELVAUDIB8 H32 0039
1 Fault Found
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 21
Mileage: 112195 km
Time Indication: 0
Date: 2007.01.30
Time: 14:34:40
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 E HW: 8T1 820 043 E
Component: KLIMA 3 ZONEN 003 0080
Revision: C0000000 Serial number: 0115.03.070131
Coding: 36020000
VCID: 336E1D926D6F7E84
1 Fault Found
01187 - Rear Temperature Flap Positioning Motor (V137)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 112480 km
Time Indication: 0
Date: 2011.10.13
Time: 08:00:33
Freeze Frame:
Voltage: 14.30 V
Temperature: 24.0°C
Temperature: 18.0°C
Count: 10000
Count: 9761
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 279 C
Component: BCM1 1.0 H19 0253
Revision: 04019001 Serial number: 00000000011675
Coding: 260050910010AF211F09000000005D5D0F9C038800010141000000
VCID: 2F6611E281475A64
Part No SW: 8T1 955 119 B HW: 8J1 955 119
Component: WWS 290307 H11 0040
Coding: 00FD11
Part No SW: 8T0 955 559 HW: 4E0 955 559 B
Component: RLS H12 0001
Coding: 02532C
Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
2 Faults Found
00471 - Control Module for Elect. Regulated Dampers (J250)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 112190 km
Time Indication: 0
Date: 2007.01.30
Time: 14:11:00
03207 - Charisma Switch Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 112190 km
Time Indication: 0
Date: 2007.01.30
Time: 14:11:00
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0103833956
Coding: 011A0E80003904C1012000
Part No: 8K0 951 177
Component: DWA-Sensor H02 0030
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
No fault code found.
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 C
Component: DSP Prem H11 0400
Revision: 00H11003 Serial number: 34810000211716
Coding: 030101
Shop #: WSC 12336 024 394758
VCID: 3F8641A25127AAE4
1 Fault Found
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 112197 km
Time Indication: 0
Date: 2007.01.30
Time: 15:41:05
Freeze Frame:
Voltage: 12.40 V
Temperature: 29.0°C
Temperature: 30.0°C
Bin. Bits: 00000100
Bin. Bits: 00000010
Bin. Bits: 00000000
End ---------------------------------------------------------------------
Me dieron cita en la audi para el martes, como lo veis de grave esto, ¿paro de andar en el coche o sigo?, ¿sabeis que ha roto?. Espero respuestas
  • 4 meses más tarde...
  • 1 mes más tarde...
Hola!
Yo tenia algun error común con el tuyo y fueron las chapaletas de admisión. 700 euros las 2, con rebaja del 50%.
Esperemos que solo sea eso. Por lo visto es muy común.
Exactamente lo mismo. Las put** chapaletas. Que se ensucian, el motorcito que las mueve se fuerza hasta que mueren y entra en modo averia.
A mi me paso con 80.000km, creo...
