Buenos días a todos,
Aunque llevo tiempo por aqui me acabo de comprar el VAG-COM, he realizado un Autoscan y me ha salido el siguiente chorizo:
Wednesday,15,February,2012,18:30:57:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E35A494211 Mileage: 161760km/100513miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 401 K HW: 8E0 907 401 AJ
Component: 3.0L V6TDI 000SG 0030
Revision: --H01--- Serial number:
Coding: 0011111
Shop #: WSC 06325 000 00000
VCID: 2759FFAFEF7D
2 Faults Found:
001025 - EGR System: Insufficient Flow
P0401 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 3
Time Indication: 0
Freeze Frame:
RPM: 2058 /min
Torque: 159.9 Nm
Speed: 116.5 km/h
Duty Cycle: 63.8 %
Duty Cycle: 20.9 %
Mass Air / Rev.: 522.9 mg/str
Duty Cycle: 52.1 %
004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
P1018 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 128.7 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 20.5 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004425
VCID: 2759FFAFEF7D
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6BD1C39F3315
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10021
Shop #: WSC 06325
VCID: 3B7133DF03F5
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M002JTLG
Coding: 0034622
VCID: 3B7133DF03F5
3 Faults Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 11
Reset counter: 99
Time Indication: 0
01316 - ABS Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 18
Reset counter: 99
Time Indication: 0
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01012
Shop #: WSC 06325
VCID: 43814B3F7B05
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0007141
Shop #: WSC 00311 572 56466
VCID: 295DF997F969
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H54 0660
Revision: 08S Serial number: AUZBZ7E0403203
Coding: 0301311
Shop #: WSC 00162 572 05423
VCID: 2443E8A39E4B
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Date: 2009.03.24
Time: 08:19:03
Freeze Frame:
Voltage: 10.60 V
Mileage: 655350 km
Count: 1502
Clock: 17:15
00858 - Connection; Radio ZF Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 102
Time Indication: 0
Date: 2009.11.19
Time: 15:42:24
Freeze Frame:
Mileage: 655350 km
Count: 1302
Clock: 09:25
02446 - Disk Drive Mechanical Malfunction
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 65
Reset counter: 199
Time Indication: 0
Date: 2007.04.27
Time: 09:24:22
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBD1439FB315
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 07034
Shop #: WSC 06325
VCID: 7DF5FDC75D61
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 397D29D709C9
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301311
VCID: 2443E8A39E4B
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 119
Time Indication: 0
Date: 2009.03.24
Time: 08:19:03
Freeze Frame:
Voltage: 10.60 V
Mileage: 655350 km
Count: 1502
Clock: 17:15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 102
Time Indication: 0
Date: 2009.11.19
Time: 15:42:24
Freeze Frame:
Mileage: 655350 km
Count: 1302
Clock: 09:25
Freeze Frame:
Fault Priority: 5
Fault Frequency: 65
Reset counter: 199
Time Indication: 0
Date: 2007.04.27
Time: 09:24:22
End ---------------------------------------------------------------------
Hay fallos desde 2007 y en el conce no me han dicho ni pio. Sabeis como borrarlos y que significa cada fallo o que tengo que hacer para solucionarlo?
Gracias por adelantado a todos.
Mi vínculoLa mayoria de los fallos son intermitentes con darle a clear all dtcs será suficiente. Lo que esta claro es que el coche tubo un golpe y salto el airbag del pasajero y sustituyerón la centralita del airbag sin registrar la nueva.un saludo
El coche cuanto hace que lo tienes??
Que alguien que controle mas que yo te lo comfirme
pero si esto es lo que creo que es:
69 75 76 77
Freeze Frame:
Voltage: 10.60 V
Mileage: 655350 km
Count: 1502
Clock: 17:15
parece un afeitado???
Editado por CESPIMA
69 75 76 77
Freeze Frame:
Voltage: 10.60 V
Mileage: 655350 km
Count: 1502
Clock: 17:15
No me habia fijado pero si tiene toda la pinta la fecha de los 655.355 km es de 2009. una pasada
Esa impresión me había dado también a mí, que pudieran haberle hecho un afeitado de los buenos y luego fueron tan torpes de no haber borrado los fallos para que no se viese la fecha y los kilómetros que marcaba en el momento de producirse dichos fallos, habría que saber de que año es el coche y tratar de averiguar si hay un historial de mantenimientos en algún concesionario.
lo del concesionario no se yo
Coding: 0007141
VCID: 295DF997F969
la banderita es de Holanda, lo cual da que pensar
No hagas mucho caso de esos numeros ya que a mi me ocurrio igual la primera vez que le pase el vag, me indicaba los mismos kilometros que a ti y el coche solo tenia 2 años y un estado impecable de todo.
Te pongo una captura del mio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 33
Reset counter: 199
Time Indication: 0
Date: 2011.08.18
Time: 18:12:58
Freeze Frame:
Mileage: 655350 km
Count: 2412
Clock: 12:03
Demasiada coincidencia, esos numeros deben significar otra cosa.
Ese tema es el que menos me preocupa, el coche lo compre nuevo en conce oficial en 2005 y os aseguro que no he bajado km ni nada por el estilo. Esos números significan otra cosa seguro.
Podéis ayudarme con el resto de errores? que tengo que hacer para borrarlos? hay algún error importante del que me deba preocupar?
Gracias a todos por vuestra ayuda.
Citandome a mi mismo te respondo y añado por si no se borra el error del airbag
eat Occupied Recognition Control Module (J706)
If the Seat Occupied Recognition Control Module (J706) or the seat itself have been replaced, the basic setting has to be performed.
[select]
[15 - Airbags]
[security Access - 16]
Enter 30475, to enable the basic setting.
If you are having problems performing this security access, contact us.
[Do it!]
[basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The reset has been performed.
[Done, Go Back]
[Close Controller, Go Back - 06]
