bulis Publicado 15 de Marzo del 2012 Denunciar Publicado 15 de Marzo del 2012 Bueno señores, resulta que ayer le pase por primera vez el vagcom al coche para ver que tipo de centralita tenia para poder poner los faros restyling (es la K) y al hacer un scan me salio esto: (Perdon por el tocho) VCDS Version: Release 10.6.0 Data version: 20100630 Wednesday,14,March,2012,19:01:24:46862 Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56 61 62 72 76 77 Mileage: 50770km/31547miles 00-Steering Angle Sensor -- Status: Cannot be reached 1100 01-Engine -- Status: Cannot be reached 1100 02-Auto Trans -- Status: Cannot be reached 1100 03-ABS Brakes -- Status: Cannot be reached 1100 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: Cannot be reached 1100 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Sporadic communication error 1000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Cannot be reached 1100 55-Xenon Range -- Status: Cannot be reached 1100 56-Radio -- Status: Sporadic communication error 1000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 02: Auto Trans Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes Cannot be reached ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0220 Revision: 31050601 Serial number: 10601100659438 Coding: 0000131 Shop #: WSC 02323 785 00200 VCID: E3CE2DD21D0F2E04 Part No: 4F0 910 131 E Component: FBSAUDIC6 EZS H45 0080 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F1 910 732 D HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 350AO077753770 Coding: 0001004 Shop #: WSC 02335 785 00200 VCID: 254AF3CAD3BB1034 Part No: 4F0 910 609 E Component: Bedienteil MMIC6H01 0060 2 Faults Found 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 63 Mileage: 50522 km Time Indication: 0 Date: 2011.12.05 Time: 17:20:47 02244 - Button in Control Head is Stuck 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 112 Mileage: 50778 km Time Indication: 0 Date: 2012.03.14 Time: 18:42:08 Freeze Frame: Bin. Bits: 00100000 Bin. Bits: 0000000 Bin. Bits: 000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF Component: KLIMABETAETIGUNGH30 0020 Revision: 00000052 Serial number: 00000000352669 Coding: 0000278 Shop #: WSC 02325 785 00200 VCID: 1C3CD62EE0F1D1FC No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 K HW: 4F0 907 279 Component: ILM Fahrer H17 0240 Revision: 00000000 Serial number: 4F0907279 Coding: 0012121 Shop #: WSC 02335 785 00200 VCID: 3162179A97734C94 Part No: 4F1 910 113 C Component: Wischer AudiC6 H05 0210 Coding: 00064784 Shop #: WSC 02335 Part No: 4E0 910 557 A Component: REGENLICHTSENSORH13 0090 Coding: 00146221 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H44 0390 Revision: 00044000 Serial number: AUZ5ZBG3149627 Shop #: WSC 00000 000 00000 VCID: 1A30D036EAC5AFCC No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Cannot be reached ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 B Component: Lenksäulenmodul H08 0230 Revision: 00H08000 Serial number: 90025070360018 Coding: 0002142 Shop #: WSC 00168 572 03212 VCID: E6C834C6EE3D5B2C Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 C HW: 4F0 920 932 Component: KOMBIINSTR. M73 H19 0120 Revision: 00100000 Serial number: 5HP53ZJ17 Coding: 2304148 Shop #: WSC 00168 572 93603 VCID: 234EEDD2DD8FEE04 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 130080711381AD Coding: ECFE73C41B3104 Shop #: WSC 02334 785 00200 VCID: 2756F9C2A9B70224 3 Faults Found 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 48 Mileage: 48631 km Time Indication: 0 Date: 2011.08.03 Time: 10:34:57 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 88 Mileage: 48631 km Time Indication: 0 Date: 2011.08.03 Time: 11:02:54 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 88 Mileage: 48631 km Time Indication: 0 Date: 2011.08.03 Time: 11:35:14 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 L Component: MNS ECE H48 1060 Revision: 00000000 Serial number: 364AG077633013 Shop #: WSC 00168 572 57950 VCID: 3B7E35B2453FB6C4 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Cannot be reached ------------------------------------------------------------------------------- Address 46: Central Conv. Cannot be reached ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: Redir Fail! Part No SW: 4F0 910 223 M HW: 4F0 035 223 N Component: Amp.-ASK-RD H07 0270 Revision: 07S00000 Coding: 080001 Shop #: WSC 02399 823 56573 VCID: 2854FAFEA4A90D5C No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000201074 Coding: 0001003 Shop #: WSC 02335 785 00200 VCID: DEB81C26366D03EC No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Cannot be reached ------------------------------------------------------------------------------- Address 53: Parking Brake Cannot be reached ------------------------------------------------------------------------------- Address 55: Xenon Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 394A-077727782 Coding: 0000001 Shop #: WSC 02323 785 00200 VCID: 3162179A97734C94 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: J0644 BEM H12 0590 Revision: 00000000 Serial number: 00000000009984 Shop #: WSC 00168 572 57950 VCID: 234EEDD2DD8FEE04 Part No: 4F0 915 105 D Component: von VA0 2701261656 Coding: 344630393135313035442056413032373031323631363536 Shop #: WSC 00000 384 00290 5 Faults Found 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 6 Mileage: 50406 km Time Indication: 0 Date: 2011.11.26 Time: 19:07:09 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 5 Mileage: 50566 km Time Indication: 0 Date: 2012.01.13 Time: 16:19:28 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 5 Mileage: 50566 km Time Indication: 0 Date: 2012.01.13 Time: 16:28:03 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 5 Mileage: 50566 km Time Indication: 0 Date: 2012.01.13 Time: 16:28:13 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 4 Mileage: 50566 km Time Indication: 0 Date: 2012.01.13 Time: 16:28:23 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Cannot be reached ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 P HW: 4F0 919 283 P Component: Parkhilfe 8-Kan H02 0500 Revision: 00H02000 Serial number: 72330914700585 Coding: 0201016 Shop #: WSC 12345 123 12345 VCID: 3162179A97734C94 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End -------------------------------------------------------------- La pregunta es: Debo preocuparme por algo en especial? Gracias y un saludo Responder
Kolari Publicado 15 de Marzo del 2012 Denunciar Publicado 15 de Marzo del 2012 ¿Lo has pasado con el contacto dado no? Es que se me hace raro que no "reach" tantos modulos... Responder
bulis Publicado 15 de Marzo del 2012 Autor Denunciar Publicado 15 de Marzo del 2012 Hola Kolari, creo que si, pero mañana lo intento de nuevo, a ver que pasa... Gracias y un saludo Responder
herodes Publicado 16 de Marzo del 2012 Denunciar Publicado 16 de Marzo del 2012 (editado) ¿Has quitado la batería o se te ha quedado muy baja de carga?, es que puede ser algo de eso también, borra los fallos y vuelve a hacer un scan pasados unos días a ver que es lo que vuelve a salir. También puede ser que se te esté muriendo la batería y por eso empiecen a fallar tantas cosas. Editado 16 de Marzo del 2012 por herodes Responder
bulis Publicado 16 de Marzo del 2012 Autor Denunciar Publicado 16 de Marzo del 2012 Pues a lo mejor van por ahí los tiros, Herodes, porque no es un coche que use mucho y ahora que dices, el otro día fui al portón a ver el codigo de pintura y no se encendió al abrirlo, me extrañó y abrí las puertas de delante y tampoco se encendieron, y al meter la llave en el contacto, se encendieron pero en el FIS me puso algo así como "arranque o las luces se apagaran en 30 segundos", lo dejé, ya que al día siguiente lo tenia que cojer. Arrancó bien y no me había vuelto a acordar de ese pequeño detalle... Gracias y un saludo Responder
herodes Publicado 16 de Marzo del 2012 Denunciar Publicado 16 de Marzo del 2012 Si no se te encendieron las luces del maletero al abrir, ni las interiores, eso es que el nivel de la batería era muy bajo y estaba en modo de ahorro de energía y se habrían desconectado todos los sistemas no imprescindibles y así reservar el máximo de energía para el arranque y si lo pusiste en marcha se cargaría un poco y por eso al día siguiente te arrancó sin problemas, pero comprueba el nivel de carga que seguramente estará bajo. Responder
txispis Publicado 16 de Marzo del 2012 Denunciar Publicado 16 de Marzo del 2012 Pasa el vag com con el motor en marcha... a ver si entras en todos los módulos. saludos Responder
herodes Publicado 16 de Marzo del 2012 Denunciar Publicado 16 de Marzo del 2012 Pasa el vag com con el motor en marcha... a ver si entras en todos los módulos. saludos Haz lo que dice txispis, si pasaste el Vag-com con el nivel de la batería muy bajo posiblemente muchos de los módulos estarían desconectados para ahorrar energía y por eso no pudiste acceder a ellos. Responder
bulis Publicado 18 de Marzo del 2012 Autor Denunciar Publicado 18 de Marzo del 2012 Buenas de nuevo, le he pasado el vagcom con el coche en marcha como dijo txispis y esto es lo que me ha salido la segunda vez, despues de borrar fallos: Ahora ya ha leido todos los modulos, menos el del telefono, que es por bluetooth de fiscon y no le he puesto (tambien soy ). A ver que os parece ahora... VCDS Version: Release 10.6.0 Data version: 20100630 Sunday,18,March,2012,18:37:56:46862 Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56 61 62 72 76 77 VIN: WAUZZZ4F27N117086 Mileage: 50770km/31547miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Sporadic communication error 1000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Sporadic communication error 1000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F1 910 401 P HW: 4F0 907 401 C Component: 2.7L V6TDI G000CG 0030 Revision: --H04--- Serial number: Coding: 0011382 Shop #: WSC 00168 572 03212 VCID: 2A5000F6BAA53F4C No fault code found. Readiness: 0 0 1 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 4F2 910 155 D HW: 01J 927 156 JG Component: V30 0AN 2.7lTDI RdW 0030 Revision: --H03--- Serial number: 00000000000132 Coding: 0000001 Shop #: WSC 02325 785 00200 VCID: 254AF3CAD3BB1034 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T Component: ESP8 front H01 0070 Revision: 00000000 Serial number: 00000000000000 Coding: 0020872 Shop #: WSC 02325 785 00200 VCID: 65CAB3CA933BD034 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0220 Revision: 31050601 Serial number: 10601100659438 Coding: 0000131 Shop #: WSC 02323 785 00200 VCID: E3CE2DD21D0F2E04 Part No: 4F0 910 131 E Component: FBSAUDIC6 EZS H45 0080 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F1 910 732 D HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 350AO077753770 Coding: 0001004 Shop #: WSC 02335 785 00200 VCID: 254AF3CAD3BB1034 Part No: 4F0 910 609 E Component: Bedienteil MMIC6H01 0060 1 Fault Found 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 72 Mileage: 50778 km Time Indication: 0 Date: 2012.03.18 Time: 18:35:35 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF Component: KLIMABETAETIGUNGH30 0020 Revision: 00000052 Serial number: 00000000352669 Coding: 0000278 Shop #: WSC 02325 785 00200 VCID: 1C3CD62EE0F1D1FC No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 K HW: 4F0 907 279 Component: ILM Fahrer H17 0240 Revision: 00000000 Serial number: 4F0907279 Coding: 0012121 Shop #: WSC 02335 785 00200 VCID: 3162179A97734C94 Part No: 4F1 910 113 C Component: Wischer AudiC6 H05 0210 Coding: 00064784 Shop #: WSC 02335 Part No: 4E0 910 557 A Component: REGENLICHTSENSORH13 0090 Coding: 00146221 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H44 0390 Revision: 00044000 Serial number: AUZ5ZBG3149627 Shop #: WSC 00000 000 00000 VCID: 1A30D036EAC5AFCC No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 E HW: 4F0 959 655 B Component: 43 AIRBAG AUDI8RH30 0280 Revision: 09H30000 Serial number: 0037LD0N03ZJ Coding: 0013363 Shop #: WSC 02325 785 00200 VCID: 2952FFFABFA33454 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 B Component: Lenksäulenmodul H08 0230 Revision: 00H08000 Serial number: 90025070360018 Coding: 0002142 Shop #: WSC 00168 572 03212 VCID: E6C834C6EE3D5B2C Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 C HW: 4F0 920 932 Component: KOMBIINSTR. M73 H19 0120 Revision: 00100000 Serial number: 5HP53ZJ17 Coding: 2304148 Shop #: WSC 00168 572 93603 VCID: 234EEDD2DD8FEE04 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 130080711381AD Coding: ECFE73C41B3104 Shop #: WSC 02334 785 00200 VCID: 2756F9C2A9B70224 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 L Component: MNS ECE H48 1060 Revision: 00000000 Serial number: 364AG077633013 Shop #: WSC 00168 572 57950 VCID: 3B7E35B2453FB6C4 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 F HW: 4F0 959 793 F Component: TSG FA H21 0050 Coding: 0001546 Shop #: WSC 02327 785 00200 VCID: 2D5A0BEA8B4B2874 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 F HW: 4F0 907 289 F Component: Komfortgeraet H22 0170 Revision: 01700022 Serial number: 01032815320000 Coding: 0131717 Shop #: WSC 02335 785 00200 VCID: 2D5A0BEA8B4B2874 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: Redir Fail! Part No SW: 4F0 910 223 M HW: 4F0 035 223 N Component: Amp.-ASK-RD H07 0270 Revision: 07S00000 Coding: 080001 Shop #: WSC 02399 823 56573 VCID: 2854FAFEA4A90D5C No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000201074 Coding: 0001003 Shop #: WSC 02335 785 00200 VCID: DEB81C26366D03EC No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 792 F HW: 4F0 959 792 F Component: TSG BF H21 0050 Coding: 0001546 Shop #: WSC 02327 785 00200 VCID: 2C5C06EEB051217C No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 C HW: 4F0 907 801 A Component: EPB CDEC0080 H04 0080 Revision: --H04--- Coding: 0000531 Shop #: WSC 02324 785 00200 VCID: 2044E2DECC99F51C No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000003 Shop #: WSC 02325 785 00200 VCID: 3D7A3BAA5B2BB8F4 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 394A-077727782 Coding: 0000001 Shop #: WSC 02323 785 00200 VCID: 3162179A97734C94 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: J0644 BEM H12 0590 Revision: 00000000 Serial number: 00000000009984 Shop #: WSC 00168 572 57950 VCID: 234EEDD2DD8FEE04 Part No: 4F0 915 105 D Component: von VA0 2701261656 Coding: 344630393135313035442056413032373031323631363536 Shop #: WSC 00000 384 00290 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 F HW: 4F0 959 795 F Component: TSG HL H21 0050 Coding: 0001026 Shop #: WSC 02327 785 00200 VCID: 2F6611E281475A64 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 F HW: 4F0 959 794 F Component: TSG HR H21 0050 Coding: 0001026 Shop #: WSC 02327 785 00200 VCID: 2F6611E281475A64 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 P HW: 4F0 919 283 P Component: Parkhilfe 8-Kan H02 0500 Revision: 00H02000 Serial number: 72330914700585 Coding: 0201016 Shop #: WSC 12345 123 12345 VCID: 3162179A97734C94 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End --------------------------------------------------------------------- Responder
bulis Publicado 18 de Marzo del 2012 Autor Denunciar Publicado 18 de Marzo del 2012 Tambien he metido (mi padre ha metido) un aparato en la bateria (densiómetro, no sé, ahora vereis) y esto es lo que me daba: Responder
bulis Publicado 18 de Marzo del 2012 Autor Denunciar Publicado 18 de Marzo del 2012 este es el aparato fuera, esta graduado de 1200 (rojo) a 1300 (verde) en intervalos de 25 La pregunta es: que aparato es y que mide? Responder
bulis Publicado 18 de Marzo del 2012 Autor Denunciar Publicado 18 de Marzo del 2012 una mas: Responder
bulis Publicado 20 de Marzo del 2012 Autor Denunciar Publicado 20 de Marzo del 2012 Hola, de nuevo, ayer le hice unos 200 km al coche y he vuelto a mirar la bateria con el aparatejo ese. Y me da lo mismo que el otro dia, es decir, 1125-1150, la foto vale la misma Un saludo Responder
txispis Publicado 20 de Marzo del 2012 Denunciar Publicado 20 de Marzo del 2012 Hola, de nuevo, ayer le hice unos 200 km al coche y he vuelto a mirar la bateria con el aparatejo ese. Y me da lo mismo que el otro dia, es decir, 1125-1150, la foto vale la misma Un saludo Ese aparato te está marcando la densidad, agua-acido, que en tu caso es mala. Esto no se regenera andando con el coche, es la que es. Es mas en estas baterias sin mantenimiento, mas que rellenar con agua destilada hasta tapar los electrolitos no puedes hacer. Pasa el vag com con motor en marcha, borra fallos en cada modulo y luego vuelve ha hacer autoscan. Olvida ese densimetro que no lo necesitas. En las baterias con mantenimiento, en los transpalets etectricos de fabricas, carretillas elevadoras y asi todavia se utiliza Saludos Responder
ximo@6 Publicado 20 de Marzo del 2012 Denunciar Publicado 20 de Marzo del 2012 (editado) ve haciéndote a la idea de comprar una batería nueva, esa el día menos pensado te deja tirado el ácido sulfúrico puedes corregirlo aunque la batería sea sin mantenimiento, compra ácido de baterías en una casa de repuestos recuerda que es muy corrosivo y aparte explosivo en su manejo dos opciones 1-compras agua destilada le quitas un poco de agua medio litro y vas añadiendo ácido y comprobando con el aparato hasta que entre en lo verde después es: sustituir el liquido que lleva la batería pero es peligroso, el ácido quema la piel, hasta el punto que se la come. por otro lado, 2- es echarle ácido directamente a la batería, hasta subirle el nivel al 1,280, sera menos peligroso igualmente tendrás que quitarle agua, si lleva su nivel, con una jeringuilla para que sobrepase el nivel, al añadirle el ácido que hagas esto no quiere decir que la batería valla a durar una eternidad simplemente le alargas el tiempo de expiracion un poco, en casos años, puede que meses, porque depende también de como se encuentren las placas interiores importante, el ácido solo se puede echar al agua, al contrario es explosión segura, nunca, agua al ácido, explota no fumar ni arrimar llamas o aparatos que las puedan provocar, el hidrógeno liberado de la mezcla es inflamable os explico una batería sin mantenimiento, se refiere que no necesita mantenimiento en su vida útil, sabéis que tiempo dan los fabricantes como vida útil, 3,5 años, a partir de estos se supone que es una batería con mantenimiento, por lo tanto si no esta sellada como algunas están fabricadas, se les puede hacer mantenimiento, seguro que hay alguien mas entendido que yo y os lo puede explicar mejor que yo la escala del aparato es 1 coma 2 1 coma 3 lo ideal es 1,280kg/dm3, con 1,24 estaria en media vida a Editado 20 de Marzo del 2012 por ximo@6 Responder
