Hola,
Tengo un A8 4.2 Q gasolina de 2003 (modelo 2004) con 175.000 km.
Todo va bien, salvo porque el otro día, de pronto, dejó de funcionar la detección de la llave al aproximarme al coche (para abrir puertas) y el cierre de puertas desde el botón en las manillas. Curiosamente, el coche sí arranca sin llave (es decir, la antena sí detecta la llave en el interior del coche).
He cponectado el vagcom y me sale esto:
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H02 0110
Revision: 01103502 Serial number: AUX3Z0C1309990
Coding: 0409600
Shop #: WSC 02312 785 00200
VCID: D8BB0C531283
Part No: XXXXXXXXXXX
Component: ELV XXXX
6 Faults Found:
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 211
Mileage: 169936 km
Time Indication: 0
Date: 2012.03.02
Time: 13:19:52
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 211
Mileage: 169936 km
Time Indication: 0
Date: 2012.03.02
Time: 13:19:52
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 211
Mileage: 170112 km
Time Indication: 0
Date: 2012.03.02
Time: 16:08:02
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 211
Mileage: 170112 km
Time Indication: 0
Date: 2012.03.02
Time: 16:08:02
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 211
Mileage: 170144 km
Time Indication: 0
Date: 2012.03.03
Time: 09:04:50
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 8
Mileage: 172416 km
Time Indication: 0
Date: 2012.03.13
Time: 22:31:34
¿Alguna sugerencia?
Gracias!!
Ha mi me paso algo parecido hace poco, pero no me dejaba ni abrirlo ni arrancarlo osea no detectaba la llave de ninguna forma.
La solucion mia fue muy simple, le cambie la pila al mando y listo, yo de ti lo probaba, le medi la tension a la pila antigua y tenia un 98% pero no iva y con la nueva al pelo
mira ver si te se a ido algún fusible no van las antenas
puedes cambiarle la pila pero eso te lo dice el cuadro cuando esta sin pila
A mi el cuadro no me dijo nada simplemete iva conduciendo y de repente me salto un aviso de llave no encontrada o llave fuera del vehiculo no se como era exactamente
  • 3 semanas más tarde...
Hola de nuevo
gracias por las respuestas, pero parece que no lo hemos arreglado aún.
He probado con las dos llaves y nada. Además, me coge bien la llave dentro del coche (para arrancar el coche con la llave en el bolsillo no hay problema) por lo que parece que la antena que va en la zona de la palanca de cambios sí va bien.
Son las antenas de las puertas y maletero las que fallan. Todas de golpe.
También me falla desde hace tiempo el sistema de memorias de asientos etc que en este coche va en el mmi (se graban los usuarios en el mmi y se activan según la llave que se aproxime al coche). Pues bien, nunca pude grabar / borrar un usuario; me da error del sistema. Me pregunto si ambos errores pueden tener algo que ver.
AYUDA!!!
