javierd Publicado 11 de Abril del 2012 Denunciar Compartir Publicado 11 de Abril del 2012 Hola a todos: Pues trasteando con el vagcom me salen todos estos errores , los borro y siguen saliendo. A ver como se repara esto!! Un saludo. Es de un Audi A2 14i ------------------ Address 01: Engine Labels: 036-906-034-APE.lbl Part No: 036 906 034 Q Component: MARELLI 4LV 3415 Coding: 00071 Shop #: WSC 02154 WAUZZZ8ZZ1N008084 AUZ7Z0Y1531269 2 Faults Found: 18044 - Powertrain Data Bus: Missing Message from Airbag Controller P1636 - 35-00 - - 16955 - Brake Switch (F): Implausible Signal P0571 - 35-00 - - Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: Redir Fail! Part No: 8Z0 907 379 B Component: ESP 20 CAN V015 Coding: 10758 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No: 8Z0 820 043 Component: A2-KLIMAVOLLAUTOMAT 0406 3 Faults Found: 01271 - Positioning Motor for Temperature Flap (V68) 41-10 - Blocked or No Voltage - Intermittent 00818 - Sensor for Evaporator Outlet Temperature (G263) 30-00 - Open or Short to Plus 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: None Part No: 8Z0 959 655 E Component: Airbag Front+Seite 3004 Coding: 00102 Shop #: WSC 02154 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8Z0-920-xxx-17.lbl Part No: 8Z0 920 900 G Component: W1-KOMBIINSTR. VDO D12 Coding: 07142 Shop #: WSC 00844 WAUZZZ8ZZ1N008084 AUZ7Z0Y1531269 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: None Part No: 8Z0 959 433 H Component: Komfortgerát T04 02B1 Coding: 02048 Shop #: WSC 02154 2 Faults Found: 01320 - Control Module for Climatronic (J255) 49-10 - No Communications - Intermittent 01561 - Left Rear Door 60-10 - Won't Safe - Intermittent End --------------------------------------------------------------------- Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ferchir Publicado 2 de Mayo del 2012 Denunciar Compartir Publicado 2 de Mayo del 2012 alguno es intermitente prueba a borralos a ver si vuelven a salir. un saludo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
