Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 77
VIN: WAUZZZ8P98A103942 Mileage: 94020km/58421miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC G200SG 9828
Revision: --H07--- Serial number: AUX7Z0GNFN605G
Coding: 0000072
Shop #: WSC 00815 572 57390
VCID: 6FE9D78F070D
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73E1DBFF6B25
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0420
Revision: 212526 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
VCID: 71EDD1F71139
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007876047
Coding: B1884F29902D100018321E4B1E0000000008FF1F321102AE000000000000
Shop #: WSC 06314 000 08192
VCID: 458555277531
Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00061712
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP001N20N
Coding: 0070612
VCID: 4B91631F5355
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 418D41376119
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 E HW: 8P0 920 931 E
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 224NG001116220
Coding: 0004129
Shop #: WSC 00815 572 173408
VCID: 356525E725D1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B0206EF
Coding: E9807F065006020102
VCID: 306B14F3DAB3
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0GNFN605G
VCID: 356525E725D1
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
Component: RNS-E HIGH EU H74 X---
Revision: 05S Serial number: AUZBZ7H1100134
Coding: 0209715
Shop #: WSC 02236 264 21716
VCID: 356525E725D1
1 Fault Found:
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 93055 km
Time Indication: 0
Date: 2012.04.07
Time: 21:04:41
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000144
VCID: 43814B3F7B05
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356525E725D1
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880202002403F000505004F0107
VCID: 458555277531
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674752984836
VCID: 356525E725D1
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000144
VCID: 448348237E0B
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209715
VCID: 356525E725D1
1 Fault Found:
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 93055 km
Time Indication: 0
Date: 2012.04.07
Time: 21:04:41
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 418D41376119
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428F4E3B641F
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005065356
Coding: 0011405
Shop #: WSC 01236 785 00200
VCID: 3B7133DF03F5
_____________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
Esto son los problemas que me da, no se como he conseguido que no me bajen/suban las ventanas desde el mando y cuando cierre o abra desde el mando los intermitentes no se encienden y me dan los dos errores de comunicacion de las dos puertas trasaeras y del navegador, no entiendo porque. Me he dejado horas tocando y tocando pero no lo vuelvo a dejar como estaba.
Alguien me podria dar las configuraciones de sus centralitas?
Mi sportback es del 2008 con chasis del 2010 con centralita de 30byts, es el modelo ambition con volante multifuncion, navegador, telefono etc bueno en el txt del vag sale todo a ver si alguien me puede ayudar porque estoy desesperado.
Un saludo y gracias de ante mano.
No se si habras tocado la codificación del navegador pero según he estado mirando tendrias que tener 205715 en lugar de 209715 a no ser que tengas bose y el nueve sea por eso. un saludo
Coding
0?xxxxx: Model
1 = Lamborghini
2 = Audi A3 (8P)
3 = Audi A4 (8E)
4 = Audi A4 Cabriolet (8H)
5 = Audi A6 (4B)
6 = Audi TT (8J)
7 = Audi R8 (42)
0x?xxxx: Treble Speaker Monitoring inactive
0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
0xx?xxx: Sound Characteristic
0 = Sound Characteristic linear
1 = Audi A4 (8E)
2 = Audi A6 (4B)
3 = Audi A4 Cabriolet (8H)
4 = Audi TT (8J)
5 = Audi A3 (8P)
9 = Sound System
0xxx?xx: Telephone/Telematic
1 = Telephone not installed (Remote Feed Voltage for Microphone active)
2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
6 = Telematic US (Remote Feed Voltage for Microphone inactive)
7 = Base Plate diagnostic capable with Comfort Control
0xxxx?x: Equipment I
1 = Tuner not installed
2 = Digital-Radio installed
3 = Satellite-Radio installed
4 = Satellite and Digital-Radio installed
5 = Analog Input (AUX) installed
7 = Satellite-Radio & Analog Input (AUX) installed
0xxxxx?: Equipment II
1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
2 = TV-Tuner installed
3 = CD-Changer installed
4 = TV-Tuner and CD-Changer installed
5 = Multi-Function Steering Wheel installed
6 = TV-Tuner and Multi-Function Steering Wheel installed
7 = CD-Changer and Multi-Function Steering Wheel installed
8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Coding
0?xxxxx: Model
1 = Lamborghini
2 = Audi A3 (8P)
3 = Audi A4 (8E)
5 = Audi A6 (4B)
6 = Audi TT (8J)
7 = Audi R8 (42)
1 = Audi A4 (8E)
2 = Audi A6 (4B)
4 = Audi TT (8J)
5 = Audi A3 (8P)
9 = Sound System
Gracias por la respuesta!!
lo cambiaré luego tienes razon porque no tengo bose, pero lo que no entiendo es lo de las ventana que no suban con el mando y lo de los intermitentes... será un fusible??
Chassis Type: 1K0
VIN: WAUZZZ8P98A103942 Mileage: 94070km/58452miles
37-Navigation -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
56-Radio -- Status: OK 0000
Coding: 0000072
VCID: 6FE9D78F070D
Revision: 00H11001
Coding: 0023170
VCID: 73E1DBFF6B25
VCID: 71EDD1F71139
Coding: B1884F29902D100018321E4B1E0000000008BE1F321102AE000000000000
VCID: 458555277531
Coding: 00061712
Shop #: WSC 06314
Coding: 0070612
VCID: 4B91631F5355
Coding: 0004042
VCID: 418D41376119
Coding: 0004129
VCID: 356525E725D1
VCID: 306B14F3DAB3
VCID: 356525E725D1
Coding: 0204715
VCID: 356525E725D1
Coding: 0000144
VCID: 43814B3F7B05
VCID: 356525E725D1
Coding: 18800020025824000505084B0107
VCID: 458555277531
VCID: 356525E725D1
Coding: 0000144
VCID: 448348237E0B
Coding: 0204715
VCID: 356525E725D1
Coding: 0000144
VCID: 418D41376119
Coding: 0000144
VCID: 428F4E3B641F
Coding: 0011405
VCID: 3B7133DF03F5
End ---------------------------------------------------------------------
he conseguido dejarlo sin fallos, pero sigue sin funcionar las ventanas en confort y los intermitentes tampoco, lo que me he dado cuenta es que en el modulo 46 creo que no me sale todo lo que tiene, podria ser por los labels de mi vcds que no los tengo completos??
A ver si alguien me pudiese poner las configuraciones del modulo 46 a ver si lo tengo igual o que!!
Gracias
