Hola, haciendo el autoscan con el VAG-Com a mi pequeñín, me ha salido lo siguiente, pero después de haberlo conseguido (pero vosotros mirar que consas estais consiguiendo que haga! :lol: ) me he dado cuenta que el siguiente paso es que no tengo ni idea de interpretar que son las cosas...
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 AE
Component: 1.8L R4/5VT 0001
Coding: 05710
Shop #: WSC 06435
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00040
Shop #: WSC 06435
Address 15 -------------------------------------------------------
Controller: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 06435
Address 17 -------------------------------------------------------
Controller: 8N1 919 880 E
Component: KOMBI+WEGFAHRS. M73 D28
Coding: 05044
Shop #: WSC 51951
Ident.-Nr. Wegfahrs.:AUZ5Z0Y8122256
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
Component: Zentralverrieg.,DWA D04
Coding: 04682
Shop #: WSC 01236
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45 -------------------------------------------------------
Controller: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 06435
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 D
Component: Radio 0001
Coding: 00517
Shop #: WSC 06435
1 Fault Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
End -------------------------------------------------------
Editado por GhosTT
  • 1 año más tarde...
Buenas
Tengo el mismo problema del airbag que tu, he ido al conce y le han pasado el vag y dice:
Unidad de control defectuosa
Averia esporádica
Me han dicho que seguramente no sea nada pero que si quiero lo deje alli porque puede ser la unidad de mando que no este bien y cuando le he preguntado por cuanto me saldria la broma si fuera la unidad de mando me ha dicho que bastantes €€€€€€ posiblemente.
A ver si alguien mas nos puede ayudar
Coding: 05710
Shop #: WSC 06435
Coding: 18446
Shop #: WSC 06435
Coding: 00040
Shop #: WSC 06435
Coding: 10102
Shop #: WSC 06435
Coding: 05044
Shop #: WSC 51951
Coding: 04682
Shop #: WSC 01236
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 06435
Coding: 00517
Shop #: WSC 06435
1 Fault Found:
ghostt, yo en principio lo que haria es, borrar todos esos falllos y despues probar el coche un tiempo y volverla a enchufar la maquina de diagnosis a ver que hay, probablente sean pequeñas averias esporadicas sin importancia, en mercedes suele pasar mucho.
¿Has tenido algún golpe con el coche? Tiene pinta de ser eso, pero lo que no sé es si es algo que queda grabado para siempre o si es que quién lo reparó no borró los errores. Opino que es buena idea lo de borrarlos y ver que pasa luego.
Caray, ya ni me acordaba de este hilo.. hace más de un añito!! :flwrs::lol2:
Creo recordar que hice lo que me comentasteis, borrar los fallos y ver si volvian a salir y las siguientes semanas lo pasé y no me salía ningún problema.
En cualquier caso a ver si este fin de semana tengo tiempo a reinstalar el VAG-Com, que desde que compré el interace USB no lo he estrenado :flwrs: y os cuento como está el tema :lol2:
Pues ese fallo de la radio lo tengo yo y el caso es que todo parece estar OK :blink:
Yo también lo tengo, y lo que si me parece curioso es que dentro de los respiraderos de encima del panel (los que desempañan el parabrisas) he visto que llevo un altavoz, pero solo en uno de los dos ??? En el otro hay un hueco para otro altavoz pero no ta. :clap1:
PD: megacoupe, a ti no te podrán decir que no te lees los posts antiguos antes de exponer un problema :clap1:
Rafa, ese es el error que da el TT antes de soltar una descarga de 100.000.000.000.000.000.000.000.000.000 voltios a su conductor. Será que lo tratas mal... :(
Y yo que pensaba que era la calefacción del asiento!!! :D:p:p
Nos vemos en ZGZ no? :D
Te por seguro que haré todo lo posible por que nos volvamos a ver pronto! un abrazo Jorge!! :D
