Alguien sabe que puede ser todo esto.
Gracias por la ayuda
Sunday,13,May,2012,17:02:21:26365
VCDS Version: Release 805.0
Data version: 20080625
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
VIN: WAUZZZ8K19A027459 Mileage: 85640km/53214miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: None
Part No SW: 03L 906 022 JM HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3173
Revision: --H01---
Coding: 0104002C18072120
Shop #: WSC 06325 000 00000
1 Fault Found:
0018 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 10
Mileage: 85572 km
Date: 2012.05.11
Time: 21:42:01
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AQ HW: 8K0 907 379 AQ
Component: ESP8 front H03 0210
Revision: -------- Serial number: --------------
Coding: 160D00
3 Faults Found:
02214 - Can't Decode, CODE File Not Loaded!
000 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 84637 km
Time Indication: 0
Date: 2012.04.03
Time: 13:48:16
Freeze Frame:
Hex Value: 0x2C00
Hex Value: 0x4006
Hex Value: 0x121A
Hex Value: 0x0EB2
Hex Value: 0x00FF
00473 - Can't Decode, CODE File Not Loaded!
013 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 242
Mileage: 85444 km
Time Indication: 0
Date: 2012.05.10
Time: 21:15:57
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4026
Hex Value: 0x1216
Hex Value: 0x02AE
Hex Value: 0x00FF
03159 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 26
Mileage: 85589 km
Time Indication: 0
Date: 2012.05.11
Time: 21:56:13
Freeze Frame:
Hex Value: 0x0040
Hex Value: 0x4004
Hex Value: 0x1F1A
Hex Value: 0x0DB0
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: Redir Fail!
Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030100
Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
No fault code found.
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0118.05.080099
Coding: 34000000
1 Fault Found:
01321 - Can't Decode, CODE File Not Loaded!
004 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 85572 km
Time Indication: 0
Date: 2012.05.11
Time: 21:42:06
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H21 0253
Revision: 04021001 Serial number: 00000000042944
Coding: 260050914034AF010001000000001D0D0F1C030800010101000000
Part No SW: 8K1 955 119 HW: 8T1 955 119
Component: WWS 200508 H06 0060
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 85572 km
Time Indication: 0
Date: 2012.05.11
Time: 21:42:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75240813400425
Coding: 100003
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 E HW: 8K0 953 568 E
Component: Lenks.Modul H11 0012
Revision: -------- Serial number: 90304HDP00014
Coding: 000006
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H16 0221
Revision: 00000000 Serial number: 8ZT630H58
Coding: 0F04080003000008050000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 85572 km
Time Indication: 0
Date: 2012.05.11
Time: 21:42:02
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G084278870
Coding: 000303
Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 85572 km
Time Indication: 0
Date: 2012.05.11
Time: 21:42:01
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007188016
Coding: 011C02205000410001
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0111549234
Coding: 01000620003900C0012001
3 Faults Found:
02615 - Can't Decode, CODE File Not Loaded!
009 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 47325 km
Time Indication: 0
Date: 2010.08.10
Time: 11:27:02
02616 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 107
Mileage: 47325 km
Time Indication: 0
Date: 2010.08.10
Time: 11:27:34
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 238
Mileage: 85572 km
Time Indication: 0
Date: 2012.05.11
Time: 21:42:02
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007189123
Shop #: WSC 00509 572 81245
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000132171
Coding:
Shop #: WSC 00000 000 00000
2 Faults Found:
004 - Can't Decode, CODE File Not Loaded! - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 238
Mileage: 85572 km
Time Indication: 0
Date: 2012.05.11
Time: 21:42:01
Freeze Frame:
Voltage: 14.20 V
Count: 67
Speed: 114.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
02432 - Can't Decode, CODE File Not Loaded!
012 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 85444 km
Time Indication: 0
Date: 2012.05.10
Time: 21:15:57
Freeze Frame:
Voltage: 14.10 V
Count: 12
Speed: 0.0 km/h
Hex Value: 0x02E1
Hex Value: 0x0021
Hex Value: 0x0108
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
Component: Concert3 H01 0310
Revision: 00000003 Serial number: AUZ5Z6H1063056
Coding: 0500048004010100415B070000
Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Address 62: Door,Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007198279
Coding: 010C02204000210001
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007195869
End ---------------------------------------------------------------------
Yo creo que a tu coche no le pasa nada, el problema es el cable...parece que no tienes bien instalado el programa y no encuentra los archivos label para codificar en cada modulo, y de eso se te esta quejando, no son averias.Suponog que hace mucho que no usas ese cable..no?????
pues no lo se, el cable lo uso poco, pero el tema viene del dia once venia circulando por autopista y en un baden o salto empezo a pitar el cuadro y se encendieron los testigos de co trol de airbag, freno y presion de neumaticos.
Ahora al arrancar el coche pita y se enciende averia en freno de estacionamiento y el de airbag y no se apagan, al cabo de unos km se enciende averia en sistema de presion de neumaticos, ademas el freno de mano no se quita solo y las puertas no se bloquean al pasar de 15 km. alguna centralita sw abra jorobado.
