Tengo activado el ADS en un MMI 3G. He hecho un autoscan y me salen varios errores. Alguien me puede confirmar que son los errores típicos por activar el ADS sin tener la botonera? Los errores en charisma los conocía, pero los eléctyricos tb son por el ADS?
Muchas gracias:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000394780
Coding: 260050914034AF211701000000001D0D4F9C030804010141000000
Shop #: WSC 02391 823 56573
Part No SW: 8K1 955 119 A HW: 8T1 955 119
Component: WWS 191109 H06 0070
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
1 Fault Found:
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 8T1 035 666 J HW: 8T1 035 666 E
Component: H-BN-EU H45 0174
Revision: -------- Serial number: 483K2097576073
Coding: 010100000106C1ED05000F1E000000030001
1 Fault Found:
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 42419 km
Time Indication: 0
Date: 2012.06.10
Time: 10:48:41
Freeze Frame:
Voltage: 12.40 V
Reedito el post porque se había cortado una parte del error del móduloa 09 (charisma).
Un saludo y muchs gracias de antemano por vuestra ayuda,
Coding: 00FD11
Coding: 025028
1 Fault Found:
03207 - Charisma Switch Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 42419 km
Time Indication: 0
Date: 2012.06.10
Time: 10:46:00
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 42419 km
Time Indication: 0
Date: 2012.06.10
Time: 10:48:41
Freeze Frame:
Voltage: 12.40 V
Nadie sabe a que puede ser debido el error que aparece en el moduli 5F? Una ayudita porfavor.
Buenas, has realizado alguna modificación en el MMI 3G?
http://wiki.ross-tech.com/wiki/index.php/03175
Pues he hecho una actualizacion del software del MMI. Por lo que he podido leer en una web de US, este error es debido a la propia actualizacion, si esta no es validada on-line con la casa madre en Alemania. El error solo se puede quitar, por lo tanto, en un taller oficial con conexion. El error aparentemente no afecta para nada al MMI ni a su funcionamiento. Simplemente aparece hasta que la actualuzacion no queda validada por Audi Alemania.
Un saludo y muchas gracias por la informacion.
  • 3 semanas más tarde...
  • 1 año más tarde...
Buenas tardes.
Acabo de recibir el vagcom 12.12 y al realizar el primer test a mi coche me aparecen errores, que puede ser de cuando realicé la revisión en el concesionario. También me tuvieron que p***er una toma de 12 v en el maletero, porque en todos los documentos aparecía que venía de serie y el coche no la traía.
Resumiendo, los errores que me aparecen son:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 42 46 52 53 55 56 5F 62 72
17-Instruments -- Status: Malfunction 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 M HW: 8K0 920 930 M
Component: KOMBIINSTR. H82 0639
Revision: 00000000 Serial number: JUD33ZY6C
Coding: 0F0409000A000008050000
Shop #: WSC 06325 000 00000
VCID: 377DCD5786B85FA6659-8062
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 30265 km
Time Indication: 0
Date: 2013.01.24
Time: 16:25:53
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 666 L HW: 8T1 035 666 E
Component: H-BN-EU H52 0180
Revision: -------- Serial number: 483G 0B7721373
Coding: 01010000000681ED01000B1E000000030000
VCID: 4385A987C2600306C91-8016
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0098
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 34149 km
Time Indication: 0
Date: 2013.05.07
Time: 12:51:16
Freeze Frame:
Voltage: 12.20 V
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 34149 km
Time Indication: 0
Date: 2013.05.07
Time: 15:40:12
Freeze Frame:
Voltage: 12.20 V
Me podría alguien decir si son preocupantes y qué tengo que hacer?.
Gracias y un saludo
