Diego meson Publicado 7 de Julio del 2012 Denunciar Compartir Publicado 7 de Julio del 2012 (editado) Hola el otro dia realize el prier autoscan en el a5 y me aparecieron varios fallos, alguien me puede decir de que son exactamente y si tienen importancia?? muchas gracias!! VCDS Self-Diagnosis Log Friday,06,July,2012,12:31:20:46862 Page 2 VIN: WAUZZZ8T99A023247 License Plate: DIEGO Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0094 Revision: 4GB20042 Serial number: 4200G08902806B Coding: 000303 Shop #: WSC 06325 000 00000 VCID: 468854460EFDFB2C Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 2 Faults Found 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 106592 km Time Indication: 0 Date: 2012.06.28 Time: 17:55:55 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 9 Mileage: 106961 km Time Indication: 0 Date: 2012.07.02 Time: 16:24:00 Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H80 0143 Revision: 00002001 Serial number: 0114892457 Coding: 0100068000390440012000 Shop #: WSC 06325 000 00000 VCID: 3064129E9C79459C 3 Faults Found 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 22 Reset counter: 227 Mileage: 99969 km Time Indication: 0 Date: 2012.03.19 Time: 18:59:24 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 19 Reset counter: 76 Mileage: 99969 km Time Indication: 0 Date: 2012.03.19 Time: 20:56:47 01565 - Luggage Compartment Light (W3) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 9 Reset counter: 83 Mileage: 99995 km Time Indication: 0 Date: 2012.03.20 Time: 00:41:28 Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 C HW: 8T1 035 186 C Component: Concert3 H02 0310 Revision: 00000004 Serial number: AUZ5Z6H1127743 Coding: 05000482040485000359070000 Shop #: WSC 06325 000 00000 VCID: 37762982791792A4 2 Faults Found 02259 - Information Display and Control Head (Front) (J685) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 215 Mileage: 106592 km Time Indication: 0 Date: 2012.06.28 Time: 18:29:17 00870 - Bass Speaker Front Left (R21) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Mileage: 106592 km Time Indication: 0 Date: 2012.06.28 Time: 18:39:19 Muchas gracias y perdon por todo el tocho,ya que no se si llega con menos informacion o es necesario todo... Editado 7 de Julio del 2012 por Diego meson Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 9 de Julio del 2012 Denunciar Compartir Publicado 9 de Julio del 2012 los de el gateway y la radio son intermitentes por lo que puedes borrarlos y ver si desaparecen, si desaparecen no le des importancia el del modulo 46 es la tapa del deposito, te has dado cuenta si se cierra y se abre cuando cierras el coche , lo mismo tienes la cerradura rota Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Diego meson Publicado 9 de Julio del 2012 Autor Denunciar Compartir Publicado 9 de Julio del 2012 Ok,gracias! La tapa del deposito creo q tengo el motor estropeado! Y la radio,sera por tener instalado el navegador Road rover?? Solo son esos fallos? Muchas gracias!! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
