merlo Publicado 24 de Julio del 2012 Denunciar Compartir Publicado 24 de Julio del 2012 Soy novato con el vag com, hoy le pasado el vag y no me deja configurar nada del modulo 46. Habeis si podeis ayudarme. Esto es lo q me salTuesday,24,July,2012,16:43:42:26365 VCDS Version: Release 805.0 Data version: 20080625 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E72A242392 Mileage: 167790km/104259miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AVF.lbl Part No: 038 906 019 FP Component: 1,9l R4 EDC 0000SG 1538 Coding: 00002 Shop #: WSC 63351 WAUZZZ8E72A242392 AUZ6Z0B0021090 1 Fault Found: 17664 - Can't Decode, CODE File Not Loaded! P1256 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04255 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AA Component: A4 Klimaautomat 1450 Coding: 00000 Shop #: WSC 00000 2 Faults Found: 01274 - Can't Decode, CODE File Not Loaded! 41-10 - Can't Decode, CODE File Not Loaded! - Intermittent 00604 - Can't Decode, CODE File Not Loaded! 30-10 - Can't Decode, CODE File Not Loaded! - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00001 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 Component: Airbag 8.4E 5001 Coding: 0010602 Shop #: WSC 63351 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00011 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 G Component: KOMBI+WEGFAHRS. RB4 D26 Coding: 00101 Shop #: WSC 00231 WAUZZZ8E72A242392 AUZ6Z0B0021090 No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 AH Component: Komfortgerát T1B 0617 Coding: 06730 Shop #: WSC 63351 13 Faults Found: 01616 - Can't Decode, CODE File Not Loaded! 49-10 - Can't Decode, CODE File Not Loaded! - Intermittent 01370 - Can't Decode, CODE File Not Loaded! 35-00 - Can't Decode, CODE File Not Loaded! 00962 - Can't Decode, CODE File Not Loaded! 35-00 - Can't Decode, CODE File Not Loaded! 01368 - Can't Decode, CODE File Not Loaded! 35-00 - Can't Decode, CODE File Not Loaded! 01369 - Can't Decode, CODE File Not Loaded! 35-00 - Can't Decode, CODE File Not Loaded! 01374 - Can't Decode, CODE File Not Loaded! 35-00 - Can't Decode, CODE File Not Loaded! 01371 - Can't Decode, CODE File Not Loaded! 35-00 - Can't Decode, CODE File Not Loaded! 01366 - Can't Decode, CODE File Not Loaded! 35-00 - Can't Decode, CODE File Not Loaded! 01560 - Can't Decode, CODE File Not Loaded! 59-10 - Can't Decode, CODE File Not Loaded! - Intermittent 01332 - Can't Decode, CODE File Not Loaded! 53-10 - Can't Decode, CODE File Not Loaded! - Intermittent 01561 - Can't Decode, CODE File Not Loaded! 61-10 - Can't Decode, CODE File Not Loaded! - Intermittent 01333 - Can't Decode, CODE File Not Loaded! 53-10 - Can't Decode, CODE File Not Loaded! - Intermittent 01562 - Can't Decode, CODE File Not Loaded! 61-10 - Can't Decode, CODE File Not Loaded! - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 Component: concert II GRO 0008 Coding: 01001 Shop #: WSC 01059 No fault code found. End ---------------------------------------------------------------------e: Muchas gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 28 de Julio del 2012 Denunciar Compartir Publicado 28 de Julio del 2012 (editado) todos los errores hacen mención a la alarma, has quitado la alarma o las has descodificado del modulo ¿tienes alarma?? si no tienes es que el modulo la tiene activa y no tienes edito para decir que el modulo esta bien codificado para un vehiculo con alarma A4 b6b7 ahora la cuestion es¿ la tienes? porque no se comunica con ninguno de los sensores Editado 28 de Julio del 2012 por ximo@6 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
merlo Publicado 31 de Julio del 2012 Autor Denunciar Compartir Publicado 31 de Julio del 2012 Hola ximo, Muchas gracias por echarme una mano. Si tengo alarma y al parecer si funciona, pero sigue sin dejarme cambiar nada de la configuración del modulo 46. La alarma se configura en otro modulo? Si es así te agradecería como se haría? Gracias de nuevo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 6 de Agosto del 2012 Denunciar Compartir Publicado 6 de Agosto del 2012 (editado) el modulo es el 45 y la codificación correcta es 00001 Editado 6 de Agosto del 2012 por ximo@6 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
