1348079249[/url]' post='3720608']
Hola a todos, escribo este post porque estoy desesperado. Hago todo lo que decís en los post y no me aparece disponible la opcion del ads, solo me sale pero en gris.
a ver si alguien puede hecharme una mano
saludos y gracias
Tienes que activar en el menu oculto Del MMI la opción CHARISMA cuando este activado tienes que reiniciar el mmi
mira en el fondo de este post:
http://www.audisport...5/page__st__435
Editado por 156SW
A ver las instrucciones completas en inglés que tengo para activar el ADS son las siguientes:
"First 09 - Central Electric is coded to "Charisma engine only": byte 7, bit 5, change 0 to 1 (you may also have to change byte 7, bit 2 as well), byte 8, bit 2, change 0 to 1 and byte 17, bit 7, change 0 to 1.
In byte 8 bit 3, 4 and 5 from 0 to 1 will respectively switch steering, suspension and sports differential modes on in addition to the engine mode, although the latter two modes are undoubtedly of no use without such hardware in the car.
Byte 7, bit 4 is apparently for active steering, again probably of use only if such hardware is in the car.
Then 09 - Central Electric, Security Access – 16 (meter el código que sale solo en una ventanita al de unos segundos), Adaptation - 10, change channels 63 to 66 to value 4 (individual mode). (See here for more discussion on these codes: http://www.a5oc.com/forums/showthread.php/vag-com-change-10568/index2.html )
Getting the Audi Drive Select individual option appear in CAR menu (MMI cars only) you may need to access the “hidden menu” (menu oculto) to enable "Charisma" (the code-name for Audi Drive Select), see way above in this article on how to enable and access the hidden menu in MMI 2G and MMI 3G.
Hidden Menu: Head unit controller (07), Adaptation, Channel 8, change 0 to 1, Save.
MMI 2G: In hidden menu menu go to Diag settings, Car menus maske, check Charisma and go down to Accept changes.
MMI 3G: In hidden menu, go to "car", select “cardevicelist”, scroll down and check Charisma. Go back, and still in the "car" hidden menu, select “carmenuoperation”. Scroll down to Charisma, change from 0 to 1.
Important!!!, If you have SERVOTRONIC (and not dynamic steering) you have to change in the Byte 8 the bit "1", not "4"...
And for some cars also the engine (with manual gear) is different: bit "0" instead of bit "2".
On both MMIs then reset the MMI."
Luego, para desactivar el ADS del MMI, es decir, dejarlo precisamente en gris para que no se pueda cambiar al llevarlo al servicio oficial y que no salga fallo en el Vagcom, ha que hacer esto:
"Para borrar el fallo en caso en que tengamos que ir al taller y no queremos que lo vean, basta con deshacer el primer bit que activamos (Coding 09-Central electric: Byte 7 Bit 5 pasar de 0 a 1) Con esto ya no sale el fallo y no hace falta desaher el resto de la codificación...evidentemente se desactiva el ADS pero para la próxima vez que lo queramos codificar basta sólo con rehacer este bit...saludos"
Es decir, que si tu deshaces este último cambio que he puesto (es decir, pones el Bit 5 del byte 7 en central electric con valor "1" y luego pasas con el raton al byte siguiente para que guarde el cambio del valor, tras aceptar la nueva codificación se supone que se te tiene que activar ya el menu del ADS en el MMI en color naranja en vez de gris.
