VAG-COM Version: Release 704.1
Data version: 20071016
Thursday,25,October,2012,22:51:10:59303
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E95A013779 Mileage: 235190km/146140miles
Address 01: Engine Labels: 038-906-019-130.LBL
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC 0000SG 5934
Coding: 00003
Shop #: WSC 63251
WAUZZZ8E95A013779 AUZ6Z0D0165497
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04255
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63251
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63251
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
57-00 - Electric Circuit Failure
00979 - Lamp for Low Beam; Right (M31)
01499 - Bulb for High-Beams; Right (M32)
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01012
Shop #: WSC 63251
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 900 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01103
Shop #: WSC 00050
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1512
Coding: 08042
Shop #: WSC 00050
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0204
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
01559 - Drivers Door
61-10 - Won't De-Safe - Intermittent
01031 - Central Locking Key Switch; Driver Side; Unlock
Address 56: Radio Labels: 8J0-035-1xx-56.LBL
Part No SW: 8E0 035 186 AK HW: 8E0 035 186 AK
Component: R Concert2+ H03 0221
Coding: 0000221
Shop #: WSC 00429
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 19
Reset counter: 194
End --------------------------------------------------------------------------------------------------
Estos son todos los errores que tengo , pero aunque los he buscado no se que hacer para arreglarlos
Alguno podeis orientarme
Gracias
Lo primero deberias de ocultar el numero de bastidor al colgar el log.
Has borrado los fallos y has vuelto a pasar el test?
+1, cuando colgeis el autoscan borrar antes de nada el Vin
