chulebombero Publicado 25 de Octubre del 2012 Denunciar Compartir Publicado 25 de Octubre del 2012 VAG-COM Version: Release 704.1 Data version: 20071016 Thursday,25,October,2012,22:51:10:59303 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E95A013779 Mileage: 235190km/146140miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-130.LBL Part No: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00003 Shop #: WSC 63251 WAUZZZ8E95A013779 AUZ6Z0D0165497 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Part No: 8E0 614 517 A Component: ABS/ESP allrad 4529 Coding: 04255 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.LBL Part No: 8E0 820 043 AA Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 63251 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00001 Shop #: WSC 63251 3 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 57-00 - Electric Circuit Failure 00979 - Lamp for Low Beam; Right (M31) 57-00 - Electric Circuit Failure 01499 - Bulb for High-Beams; Right (M32) 57-00 - Electric Circuit Failure ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.LBL Part No: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 63251 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Part No: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01012 Shop #: WSC 63251 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL Part No: 8E0 920 900 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 01103 Shop #: WSC 00050 WAUZZZ8E95A013779 AUZ6Z0D0165497 1 Fault Found: 01039 - Coolant Temperature Sensor (G2) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.LBL Part No: 8E0 951 177 Component: Innenraumueberw. 0704 Coding: 00001 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Part No: 8E0 959 433 BC Component: Komfortgerát T3B 1512 Coding: 08042 Shop #: WSC 00050 Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0205 Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0205 Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0204 6 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01705 - Selection Switch for Mirror-Adjust (E48) 27-10 - Implausible Signal - Intermittent 01559 - Drivers Door 61-10 - Won't De-Safe - Intermittent 01031 - Central Locking Key Switch; Driver Side; Unlock 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8J0-035-1xx-56.LBL Part No SW: 8E0 035 186 AK HW: 8E0 035 186 AK Component: R Concert2+ H03 0221 Coding: 0000221 Shop #: WSC 00429 1 Fault Found: 00821 - Antenna 2 for Radio (R93) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 19 Reset counter: 194 End -------------------------------------------------------------------------------------------------- Estos son todos los errores que tengo , pero aunque los he buscado no se que hacer para arreglarlos Alguno podeis orientarme Gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carlisu84 Publicado 25 de Octubre del 2012 Denunciar Compartir Publicado 25 de Octubre del 2012 Lo primero deberias de ocultar el numero de bastidor al colgar el log. Has borrado los fallos y has vuelto a pasar el test? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
alagar27 Publicado 25 de Octubre del 2012 Denunciar Compartir Publicado 25 de Octubre del 2012 Lo primero deberias de ocultar el numero de bastidor al colgar el log. Has borrado los fallos y has vuelto a pasar el test? +1, cuando colgeis el autoscan borrar antes de nada el Vin Responder Enlace al comentario Compartir en otros sitios web More sharing options...
