hola a todos,como algunos ya sabeis hace tres dias compre mi coche y como tenia el vagcom hoy se lo
he pasado y me ha dado bastantes fallos,pero es la primera vez que lo uso y no lo entiendo muy bien.
Hice el autoscan,me salieron los fallos,luego le di a clear all dtcs y creo que se borraron...Ahi va:
Monday,05,November,2012,16:14:05:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: Mileage: 218580km/135819miles
Address 01: Engine Labels:
VCID: 55ABF0F0AC1A496
Note: Excessive Comm Errors
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04455
Shop #: WSC 00408
VCID: E5CB40307F7A596
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 C
Component: A4 Klimaautomat 0912
Coding: 00000
Shop #: WSC 63351
VCID: 21439420ABD2F56
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
VCID: 346D6D74042070E
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: F4ED2D7494A0B0E
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 63351
VCID: 3669577C125C62E
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00000
Shop #: WSC 00006
VCID: 2E597F1CEA0C5AE
WAUZZZ8E32A230109 AUZ6Z0A0367836
2 Faults Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
01304 - Radio
49-10 - No Communications - Intermittent
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0102
VCID: 234F9E28B1CEE76
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBDF3608999E6F6
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
81-00 - Open
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AH
Component: Komfortgerát T1B 0617
Coding: 06986
Shop #: WSC 63351
VCID: 77F79A7855D65B6
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
VCID: 040DFDB4140000E
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 64955
End ---------------------------------------------------------------------
ahi van despues de borrarlos:
Monday,05,November,2012,16:35:06:37412
69 75 76 77
Coding: 04455
Shop #: WSC 00408
Coding: 00000
Shop #: WSC 63351
Coding: 00011
Shop #: WSC 63351
Coding: 0010602
Coding: 00012
Shop #: WSC 63351
Coding: 00000
Shop #: WSC 00006
Coding: 00001
Shop #: WSC 00000
Coding: 06986
Shop #: WSC 63351
Coding: 00060
Shop #: WSC 63351
Coding: 00017
Shop #: WSC 64955
Como lo veis,tengo algo mal?
los kilometros que aparecen arriba son los reales de la centralita o los del cuadro?
en el primer modulo engine, en donde pone labels no pone nada,y pone excesive comm errors es eso normal?? porque parece que no lo lee como el resto de modulos
bueno de momento nada mas y perdonar por el tocho
Un saludo y gracias por adelantado
69 75 76 77
Coding: 04455
Shop #: WSC 00408
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 Es posible que tengas que calibrar el sensor de angulo de dirección , no obstante también ha podido ser un fallo puntual del esp. Controlalo y si te vuelve a dar tendrás que calibrar y si el calibrar no funciona te tocará cambiarlo.
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
41-10 - Blocked or No Voltage - Intermittent ,Es el servomotor que recircula el aire de fuera hacia dentro del coche, se suelen romper (aunque no siempre).
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) Es el potenciómetro de la tapa de recirculación.
Coding: 00011
Shop #: WSC 63351
Coding: 0010602
Coding: 00012
Shop #: WSC 63351
Coding: 00000
Shop #: WSC 00006
2 Faults Found:
00668 - Supply Voltage Terminal 30 Voltaje del suministro demasiado bajo (intermitente) o te cambiaron la bateria o está a punto de morir.
01304 - Radio
49-10 - No Communications - Intermittent No hay radio
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System Eso es por que te ha saltado la alarma borralo y sin problema
81-00 - Open
Coding: 06986
Shop #: WSC 63351
3 Faults Found:
35-00 - -
35-00 - -
01705 - Selection Switch for Mirror-Adjust (E48) Esto es un corto en un momento dado del espejos exteriores
Coding: 00060
Shop #: WSC 63351
Coding: 00017
Shop #: WSC 64955
69 75 76 77
Coding: 04455
Shop #: WSC 00408
Coding: 00000
Shop #: WSC 63351
Coding: 00011
Shop #: WSC 63351
Coding: 0010602
Coding: 00012
Shop #: WSC 63351
Coding: 00000
Shop #: WSC 00006
Coding: 00001
Shop #: WSC 00000
Coding: 06986
Shop #: WSC 63351
Coding: 00060
Shop #: WSC 63351
Coding: 00017
Shop #: WSC 64955
Enhorabuena por la compra, esperamos esas fotillos.
Lo suyo habría sido ponerlo en el vag-com, a ver si te lo mueven :thumbsup:
Estos fallos son después de borrar todos los errores?
Muchas gracias Sergio, los fallos son los primeros que puse,es decir, el primer autoscan, después borre los fallos y hice otro ( lo pone en el análisis por la mitad)y ya no salió ninguno, pero lo que me mosquea es esto(aunque no se sí será normal):
VCID:55ABF0F0AC1A496
Parece que no lo lee igual que las otras partes,aunque a lo mejor es normal y yo estoy todo rayado.
P.d: las fotos intente ayer colgar una,pero me decía que era demasiado grande...
Muchas veces cuando aparace Excessive Comm Errors es debido a los bits de puerto COM. Es decir, no es a priori un problema con el módulo, sino de comunicación entre el VAG y el módulo.
¿Que sistema operativo utilizas?. ¿Utilizas una imagen (Virtual Box, VM,..?. Baja los bits de 9600 a un valor inferior y prueba de nuevo.
Yo en tu caso me guardaría el log, borraría todos los errores y volvería a hacer el autoscan 24 horas más tarde; es posible que muchos ya no aparecezcan.
Hola a4quatro,le hice el autoscan, me salieron los errores, los borre al momento y creo que se borraron todos( si te fijas al principio del hilo puse el primer autoscan y seguido el segundo después de borrar los fallos) pero el mensaje ese. EXCESSIVE COMM ERRORS me aparare el los dos escaneos en en modulo ENGINE.
Utilizo el cable 11.11 con Windows vista, lo que me preguntas de la imagen no se lo que es..
Como se hace lo de bajar los bits a un valor inferior??
Saludos y gracias
Saludos y gracias
Mi Pc > Administrar > Adminstrador de Dispositivos > Puertos COM > Picha en el COM del VAGCOM > Propiedades > Configuración de puerto > Bits por segundos: cambiar de 9600 a 7200 o 4800 hasta que conecte.
A mi me ha pasado en algunas ocasiones y lo he solucionado de esta manera que ví en un foro de VAG.
Saludos y gracias
Gracias tio,a ver si lo hago mañana porque aquí en Vigo esta lloviendo bastante.
También estuve leyendo yo, que había que bajarle la lactancia de 16 a 8 o algo así, creo que de la misma forma que dices tu
Saludos y gracias de nuevo
