Buenos dias a todos.
He notado que al cerrar el coche se me queda fijo el testigo de la puerta, por lo que decidi hacerle un scaner al coche.
Sorpresa.Thursday,06,December,2012,20:06:49:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EX7A226114 Mileage: 67140km/41718miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 JD HW: 03G 906 016 JD
Component: R4 2,0L EDC 000SG 9643
Revision: --H05--- Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 06325 000 00000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00001
Shop #: WSC 06325
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H13 4230
Revision: 91H13423 Serial number: 0036M0G6PEMS
Coding: 0030612
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0911
Coding: 01011
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 H HW: 8E0 920 901 H
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0020148
Shop #: WSC 00157 572 05498
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 13679
Shop #: WSC 06325
Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0606
Part No: 8E1959802H
Component: Tõrsteuer.BF BRM 0606
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01403 - Glass-Break Sensors; Rear
36-00 - Open Circuit
Address 56: Radio Labels: 8J0-035-1xx-56.lbl
Part No SW: 8E0 035 186 AL HW: 8E0 035 186 AL
Component: R Concert2+ H01 0270
Revision: 00H01000 Serial number: AUZ1Z3G8318267
Coding: 0010211
Shop #: WSC 09024 572 93841
End ---------------------------------------------------------------------
Como podeis ver tengo dos codigos de error en la alarma.
¿Alguna sugerencia? MUCHISIMAS GRACIAS DE ANTEMANO. :conf:
hola a ver si te sirve algo de esto: el codigo 01463 y 01370 son iguale son el mismo motivo ok
01463 - Alarma activada por sensor para el sistema de alarma antirrobo
Posibles causas
  • Lucha contra el robo de alarma activada por sensor para el sistema de alarma antirrobo
  • Sensor para el sistema de alarma antirrobo defectuoso
  • Cableado / Conectores de / a Sensor de sistema de alarma antirrobo defectuoso
  • Falsa alarma
Posibles soluciones
Notas especiales
  • Controlar / borrar códigos de falla
  • Verificación del sensor para el sistema de alarma antirrobo
  • Comprobar cableado / Conectores de / a Sensor para el sistema de alarma antirrobo
  • Este código de fallo es sólo una nota.
01370 sensores de rotura de cristal trasero
nada mas te puedo decir, espero te sirva de ayuda.
un saludo
SI, me vuelve a aparecer el fallo. Me mirado el sensor y aparentemente se ve bien. El sensor de rotura de cristales traseros no se donde esta.En cuanto a lo que me comentas del testigo de la puerta antes no se quedaba fijo. Por lo menos a mi.
Esa avería no tiene por qué ser reciente.
Si compraste el coche de segunda mano, ya sabes, que a su anterior dueño le rompieron un cristal.
Y, por cierto, por el bien de todos, cuando copieis y pegues los resultados de un escaneo, mostrad sólo la información referente al módulo que tenga el error. Se hará para todos mucho más fácil su compresión.
Además, Y ESTO ES POR LA SEGURIDAD DE TODOS, POR FAVOR, BORRAD LOS NÚMEROS DE BASTIDOR.
Si no, esto va a ser una fuente de información demasiado buena para los que se dedican a vender coches robados falsificando los nºs oríginales de éstos.
SALUDOS
