fallo vag com preocupado.
joseyizan
buenas a todos e pasado el vag com y me sale averia unidad de control de el motor bloqueada.alguien sabe a que puede ser? porque el coche arranca y funciona bien. Address 01 -------------------------------------------------------
Controller: 4B0 907 401 F
Component: 2,5l/4VT EDC G00SG D32
Coding: 01002
Shop #: WSC 02324
1 Faults Found: 17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Aver si alguien sabe algo y en todo caso como podria desbloquearla.
Editado por joseyizan
Enlace al comentario
Compartir en otros sitios web
No sé si has llegado a ver lo que significa el código:
17978/P1570/005488 - Engine Start Blocked by Immobilizer
Possible Symptoms
  • Engine starting but stalling immediately
Possible Causes
  • Key(s) not matched
  • Instrument Cluster not matched
  • Engine Control Unit (ECU) not matched
  • Engine Control Unit (ECU) Power Supply faulty
Possible Solutions
  • Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
  • Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
  • Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
  • Check Engine Control Unit (ECU) Power Supply (Relay)
Special Notes
  • In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related.
  • May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module.
  • If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, in rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example)
  • Low battery voltage (including a faulty battery) may cause Immobilizer system malfunctions and testing should be done only with a known good battery installed.
si lo e leido que puedo empezar por hacer desconectar la bateria aver y dejarlo unos dias aver si vuelve a salir? ayer lo unico que hice fue desmontar el cuadro para arreglar la bombilla de la luz larga y volvi a poner podria ser por aver desconectado el cuadro??
Si antes no tenías este fallo y después de quitar y poner el cuadro te ha salido este fallo, seguramente haya sido provocado por eso que comentas.
Desconecta la batería y luego vuelve a enchufarla tras al menos 5 minutos.
La batería la tienes en buen estado?
Cuando quitaste el cuadro, lo hiciste con la batería enchufada?
Possible Symptoms
Possible Causes
El que no sepa inglés ¿?
ya entiendo está traductor san google
Efectivamente desconecte la batería 15 segundos tocandose las 2 bornas entre si y le e echo unos 50km e vuelto a pasar el vag com y ya no me sale la unidad de control de el motor bloqueada. Muchas gracias a todos.
Me alegro que se haya solucionado.
La próxima vez que toques algo electrico del coche que lleve a una centralita o similar, lo recomendable es quitar la batería para evitar fallos.
