Buenos dias compañerosw, le he pasado esta mañana el vag com al coche y me dan los siguientes fallos, que puedo hacer para solucionarlos, sobre todo el del xenon, aqui dejo el resumen:
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H04 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004517
Shop #: WSC 06325 000 00000
VCID: 2855E6799BE83A9
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDDA691C90D69
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 10021
Shop #: WSC 06325
VCID: 3B7F2935297E811
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M004ZMZ+
Coding: 0033622
VCID: 3B7F29357A7E811
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04042
Shop #: WSC 06325
VCID: 41835BDD4B92EB1
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 L HW: 8E0 920 931 L
Component: KOMBI+WFS 3 H12 0110
Revision: 0110 Serial number: AUX6Z0E0064835
Coding: 0006041
Shop #: WSC 02976 572 91353
VCID: 31630B1DAB327B1
1 Fault Found:
01302 - Control Module for Telematic (J499)
004 - No Signal/Communication
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E HIGH EU H70 0330
Revision: 01S Serial number: AUZBZ7E1101689
Coding: 0319717
VCID: 254BEF4DEFFA271
2 Faults Found:
16352 - Control Module - Electrical Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 3
Reset counter: 11
Time Indication: 0
Date: 2010.07.30
Time: 16:47:55
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 16
Time Indication: 0
Date: 2013.01.16
Time: 18:15:51
Freeze Frame:
Bin. Bits: 0000
Mileage: 655350 km
Count: 1601
Clock: 18:16
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BR
Component: Komfortgerát T23 3332
Coding: 07024
Shop #: WSC 06325
VCID: 820114D18E14B09
Subsystem 1 - Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0406
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2649E84191FC2C9
Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Component: AFS-Modul rechtsH03 0020
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Time Indication: 0
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0319717
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 11
Time Indication: 0
Date: 2010.07.30
Time: 16:47:55
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 16
Time Indication: 0
Date: 2013.01.16
Time: 18:15:51
Freeze Frame:
Bin. Bits: 0000
Mileage: 655350 km
Count: 1601
Clock: 18:16
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 C HW: 8E0 919 283 C
Component: Parkhilfe 8-Kan H06 0020
Revision: 00H06000 Serial number: 00067802120513
Coding: 0000114
VCID: 30650E19A038729
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 C HW: 8P0 862 335 C
Component: FSE_255x BT H18 0160
Revision: 00000001 Serial number: 00000000239096
Coding: 0011855
VCID: 36693801425C5C9
End ---------------------------------------------------------------------
Hola,
has probado a borrar los fallos y vuelto a pasar el scan?
+1
Primero borra los fallos. Da un paseo y vuelve a hacer el autoscan a ver que sale por que la mayoría de fallos son intermitentes.
  • 3 semanas más tarde...
Buenos días compañeros, gracias por vuestros aportes, ya le he pasado un ajuste básico a lo del xenon, y al principio bien pero a la semana me vuelven a parpadear las luces ( son destellos) hasta que se apagan, ahora me lo hace con los dos faros al principio nada mas que con el derecho. Cuando empieza lo que hago es cortas las luces, y al volver a encenderlas me empieza a parpadear la otra lampara, vuelvo apagar las luces y el motor del coche, arranco le doy a las luces y parece ser que se mantienen sin apagarse ni dando destellos.........le he pasado otra vez el vag com y me aparece lo mismo, no se ya que hacer pienso que es problema del balastro, si fuese así existe alguna pagina con balastros a precio moderado? ya que me han comentado que cuestan una pasta.como podría sacar la referencia de los balastros?? existe la posibilidad de montar alguno equivalente al original??......espero solucionar este problema pronto ya que cualquier día me quedo sin luz por la noche :drooling:
Aquí os dejo lo que saca el vag com:
Coding: 0000019
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Time Indication: 0
