AYUDA EL coche no arranca
templario88
  • Respuestas 39
Coding
0?xxxxx: Model
1 = Lamborghini
2 = Audi A3 (8P)
3 = Audi A4 (8E)
4 = Audi A4 Cabriolet (8H)
5 = Audi A6 (4B)
6 = Audi TT (8J)
7 = Audi R8 (42)
0x?xxxx: Treble Speaker Monitoring inactive
0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
0xx?xxx: Sound Characteristic
0 = Sound Characteristic linear
1 = Audi A4 (8E)
2 = Audi A6 (4B)
3 = Audi A4 Cabriolet (8H)
4 = Audi TT (8J)
5 = Audi A3 (8P)
9 = Sound System
0xxx?xx: Telephone/Telematic
1 = Telephone not installed (Remote Feed Voltage for Microphone active)
2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
6 = Telematic US (Remote Feed Voltage for Microphone inactive)
7 = Base Plate diagnostic capable with Comfort Control
0xxxx?x: Equipment I
1 = Tuner not installed
2 = Digital-Radio installed
3 = Satellite-Radio installed
4 = Satellite and Digital-Radio installed
5 = Analog Input (AUX) installed
7 = Satellite-Radio & Analog Input (AUX) installed
0xxxxx?: Equipment II
1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
2 = TV-Tuner installed
3 = CD-Changer installed
4 = TV-Tuner and CD-Changer installed
5 = Multi-Function Steering Wheel installed
6 = TV-Tuner and Multi-Function Steering Wheel installed
7 = CD-Changer and Multi-Function Steering Wheel installed
8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation
Channel 001: Tire Circumference
The tire circumference is being adapted in "mm".
Channel 002: Wheel Pulse
The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
43 = Audi A3 (8P) / Audi TT (8J)
45 = Audi A4 (8E)
Channel 003: Language (Screen)
0 = German
1 = English (UK)
2 = French
3 = Italian
5 = Spanish
6 = Portuguese
7 = English (UK)
Channel 004: Back-Up Camera
0 = Back-Up Camera not installed
2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
0 = max. 0 kph or 0 mph
1 = max 5 kph (Standard for Europe)
Channel 007: Options
Channel 008: Volume Characteristic
Channel 010: Region
0 = Europe/North America
1 = Australia/South America
2 = South Africa
Channel 011: Language (Speech Recognition)
0 = German
1 = English
2 = French
3 = Italian
5 = Spanish
Channel 018: Start Screen
The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
0 = Standard Start Screen
1 = Audi S3 Start Screen
2 = Audi S4 Start Screen
3 = Audi RS4 Start Screen
4 = Audi TT Start Screen
5 = Audi R8 Start Screen
Channel 065: Read Test
Channel 066: Self Test
Channel 067: CD/DVD Drive
000 - Normal/Eject-Button enabled
001 = Eject CD/DVD (will not be saved)
255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test
Values will not be saved, they only act as initiation for each Test Picture.
0 = No Test Picture
1 = Test Picture: Red
2 = Test Picture: Green
3 = Test Picture: Blue
4 = Test Picture: White
5 = Test Picture: Black
6 = Test Picture: Checkerboard
7 = Test Picture: Checkerboard (inverted)
8 = Test Picture: 64 Gray Scales (vertical Bars)
9 = Test Picture: Special
Channel 069: Display Mechanism
000 = Display closed
001 = Display open
200 = Display half open (Obstacle)
255 = Position undefined
Channel 070: Display Brightness
0 = 0% Brightness (Display OFF)
1 = 20% Brightness
2 = 40% Brightness
3 = 60% Brightness
4 = 80% Brightness
5 = 100% Brightness
Channel 099: Transport Mode
Only applies to models without Gateway/Diagnostic Interface for Databus.
0 = Transport Mode inactive
1 = Transport Mode active
Channel 111: Reset
To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
Range: 875...1080
Channel 117: Signal Test (Output)
0 = Fader Center & Balance Center
1 = Fader Front & Balance Left
2 = Fader Front & Balance Right
3 = Fader Rear & Balance Left
4 = Fader Rear & Balance Right
Channel 136: Driver Position
RNS-E Basic
03226 = Left-Hand-Drive (LHD)
02632 = Right-Hand-Drive (RHD)
RNS-E High/US
00005 = Left-Hand-Drive (LHD)
00013 = Right-Hand-Drive (RHD)
Me aparecen los siguientes errores a ver si alguien con eso sabe por donde puedo buscar..
Address 37: Navigation Labels: None
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0220
Revision: 0000012S Serial number: AUZBZ7LD220322
Coding: 0205755
Shop #: WSC 10935 000 10485
VCID: 346C1E8E686179BC
9 Faults Found
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 18:25:29
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 70
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 18:44:10
Freeze Frame:
Mileage: 75430 km
Count: 1702
Clock: 00:00
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 3
Reset counter: 30
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 16:53:31
Freeze Frame:
Mileage: 75430 km
Count: 1702
Clock: 00:00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 70
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 18:44:10
Freeze Frame:
Mileage: 75430 km
Count: 1702
Clock: 00:00
00878 - Connection to Speaker Front Left
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 72
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 20:13:54
00879 - Connection to Speaker Front Right
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 20:13:54
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2013.02.17
Time: 13:20:59
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 30
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 16:53:25
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2013.02.17
Time: 13:21:15
Freeze Frame:
Bin. Bits: 10111011
Bin. Bits: 10
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K094160B4C
Coding: E9801F06500202000100
Shop #: WSC 06314 000 00000
VCID: 37762982791792A4
4 Faults Found
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 154
Reset counter: 33
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 16:52:16
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 23
Reset counter: 72
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 17:00:06
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 72
Mileage: 75437 km
Time Indication: 0
Date: 2013.02.16
Time: 17:00:07
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000420 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72E0D89652F5378C
1 Fault Found
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 70
Mileage: 75438 km
Time Indication: 0
Freeze Frame:
Voltage: 8.30 V
el primero de la CAN Gateway ya me salia creo que desde que compre el coche asi que yo creo que ese lo descartaria
Editado por templario88
Los errores ZF son normales ya que seguramente tienes los amplificadores de la radio concert que no son los mismos, perderas recepcion de radio pero nada mas. Por los otros errores da la impresion que son fallos de los conectores de antena y altavoces. Verifica que todo este bien conectado, antena gps, antena de radio...
si eso de los amplificadores de la radio lo se y bueno el conector de la antena GPS tampoco le doy importancia el GPS va bien lo que lo he conectado y desconectado 1000 veces y por eso saldra el fallo igual que el del micro que micro no tengo pero me marca un fallo
Parece que las conexiones no se encuentran de manera firme, habrá que verificarlas, por otro lado dice que busca la conexión a manos libres, y busca volante multifunción, tienes estos dos dispositivos instalados? si no habrá que desactivarlos para que el rns-e no los busque mas, después de ajustar esto borrar fallos y verificar que vuelve a salir, saludos.
No tengo manos libres, multifuncion si
he borrado fallos y he vuelto hacer el scan y me salen los siguientes errores
3 Faults Found
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 36
Mileage: 75551 km
Time Indication: 0
Date: 2013.02.19
Time: 21:05:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 74
Mileage: 75551 km
Time Indication: 0
Date: 2013.02.19
Time: 21:15:27
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 74
Mileage: 75551 km
Time Indication: 0
Date: 2013.02.19
Time: 21:15:27
Address 56: Radio Labels: None
Coding: 0205755
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 34
Mileage: 75551 km
Time Indication: 0
Date: 2013.02.19
Time: 21:06:30
Freeze Frame:
Mileage: 75550 km
Count: 1902
Clock: 21:06
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 34
Mileage: 75551 km
Time Indication: 0
Date: 2013.02.19
Time: 21:06:24
los que estan en negro los doy por normales pero los rojos no entiendes porque me aprecen
en el modulo 17 intruments channel 62 es posible que no lo tenga o deveria de aparecer siempre?
Esa centralita 1K0 907 530 S de Gateway es la que montaba el cabrio de 2008, ese es tu coche? aquí pueden pasar varias cosas, que esa centralita la hayan puesto a posterior, que no sea la original de tu auto 2009, y al ser de 2008 es compatible con los rns 192 y al haber montado el 193 tu gateway no es completamente compatible, ojalá haya gente con mas experiencia con lo ojos en el tema que nos pueda ayudar, por lo pronto dile a tu rns que no lleva teléfono, saludos.
Hola, has comprobado la codificación? No estoy seguro pero en tu coche creo que no aparece el canal 62 de adaptación del módulo 17 de Instrumentos. Es posible que eso sea sólo para los A4 B7 y quizás para los A3 8L? En el mío que es del 2008 (8P) no aparece nada en ese canal y no tengo errores ni problemas, y en un seat Exeo que tengo, que tiene el mismo RNS-E que el que tu tienes tampoco hay que codificarlo.
Con las opciones que has comentado (Volante multifunción y sin teléfono) si no me equivoco, deberías tener lo siguiente codificado en el módulo 37:
0205115 - Sin equipo Bosé ni entrada AUX de audio.
0209155 - Con equipo Bosé y entrada AUX de audio.
Y si sigues sin poder acceder al módulo 37 del Navegador, comprueba en el módulo 19 del Can Gateway a ver si tienes marcado el bit 6 del Byte 4 en el Long Coding para que reconozca el navegador (La tuya es la referencia terminada en "S"):
Coding (from Index L)
Byte 00 Bit 0 [01] Engine Electronics Byte 00 Bit 1 [11] Engine Electronics II Byte 00 Bit 2 [02] Transmission Electronics Byte 00 Bit 3 [03] Brake Electronics (ABS) Byte 00 Bit 4 [53] Parking Brake Byte 00 Bit 5 [04] Steering Angle Sensor (G85) Byte 00 Bit 6 [44] Steering Assist Byte 00 Bit 7 [15] Airbags Byte 01 Bit 0 [55] Xenon Range Byte 01 Bit 1 [22] All Wheel Drive Byte 01 Bit 2 [13] Distance Regulation Byte 01 Bit 3 [14] Suspension Electronics Byte 01 Bit 4 [4C] Tire Pressure Monitoring II Byte 01 Bit 5 [10] Park/Steering Assist Byte 01 Bit 6 [32] Differential Locking Byte 01 Bit 7 [17] Instrument Cluster Byte 02 Bit 0 [25] Immobilizer Byte 02 Bit 1 [09] Central Electronics Byte 02 Bit 2 [46] Central Convenience Byte 02 Bit 3 [42] Door Electronics (Driver) Byte 02 Bit 4 [52] Door Electronics (Passenger) Byte 02 Bit 5 [62] Door Electronics (Rear Left) Byte 02 Bit 6 [72] Door Electronics (Rear Right) Byte 02 Bit 7 [36] Seat Memory (Driver) Byte 03 Bit 0 [65] Tire Pressure Monitoring Byte 03 Bit 1 [16] Steering Wheel Electronics Byte 03 Bit 2 [08] Climate Control Byte 03 Bit 3 [76] Park Assist Byte 03 Bit 4 [7D] Auxiliary Heating Byte 03 Bit 5 [26] Auto Roof Byte 03 Bit 6 [69] Trailer Byte 03 Bit 7 [06] Seat Memory (Passenger) Byte 03 Bit 0 [3D] Special Function Byte 04 Bit 1 [6D] Trunk Electronic Byte 04 Bit 2 [63] Easy Entry Driver Side Byte 04 Bit 3 [73] Easy Entry Passenger Side Byte 04 Bit 4 [47] Sound System Byte 04 Bit 5 [75] Telematic/Emergency Call Byte 04 Bit 6 [37] Navigation Byte 04 Bit 7 [57] TV-Tuner Byte 05 Bit 0 [0F] Radio (digital) Byte 05 Bit 1 [56] Radio (analog) Byte 05 Bit 2 [77] Telephone Byte 05 Bit 3 [18] Auxiliary Heater Byte 05 Bit 4 [1C] Position Sensing Byte 05 Bit 5 [5D] Operations Byte 05 Bit 6 [6C] Rear View Camera Byte 05 Bit 7 [59] Tow Protection Byte 06 Bit 0 [4F] Central Electronics II Byte 06 Bit 1 [19] CAN-Gateway (Standard) Byte 06 Bit 2 [3C] Lane Change Assist Byte 06 Bit 3 [5C] Lane Maintenance Assist Byte 07 Manufacturer/Model Byte 08 Options
Por otra parte, en el módulo 16 creo deberías confirmar que está bien codificado sin teléfono:
  • 00?xxxx: Transmission
    • 0 = Manual Transmission
    • 1 = Automatic Transmission
    [*]00x?xxx: Steering Wheel
    • 0 = 3-Spoke, w/o Tiptronic, w/o Multi-Function
    • 1 = 3-Spoke, with Tiptronic, w/o Multi-Function
    • 2 = 4-Spoke Multi-Function (with Radio Control)
    • 3 = 4-Spoke Multi-Function (with Radio/Telephone Control)
    • 4 = 4-Spoke Multi-Function (with Radio/Telephone/Voice Control)
    [*]00xx?xx: Tiptronic/Heating
    • +1 = Tiptronic on Steering Wheel
    [*]00xxx?x: Cruise Control/Board Computer
    • 0 = no Board Computer, no Cruise Control
    • 1 = Board Computer, no Cruise Control
    • 2 = no Board Computer, Cruise Control
    • 4 = Board Computer, Cruise Control
    [*]00xxxx?: Rear Wiper
    • 0 = w/o Rear Wiper
    • 1 = with Rear Wiper
A ver si te sirve de ayuda...
Ok, gracias por las respuestas
Juan252 la centralita getway es la original alomejor como fue de los primeros restylings me montaron la atigua no lo se, llame a la audi y se puede actulizar pero me cobran como 1 hora (84€) un poco caro a las malas lo are.
Eryayi si que puedo entrar y ya lo hecho en el modulo 37 en principio lo he configurado todo pero siguen esos fallos lo que me parecia raro es que no me aparece el globo de informacion de los codigos lo he tenido que hacer atraves de otros post del foro
intentare a ver si puedo quitar lo del telefono..
gracias
