Un conocido de por aqui con un A4 cabrio :thumbsup:
de Emilio (a34323) y mio
nos tiene locos con esta averia no la podemos solucionar ni borrar
A alguien le ha pasado?
que nos diga por donde tirar
Gracias
MOTOR
Address 01: Engine Labels: 059-907-401-AKE.LBL
Part No: 8E0 907 401 S
Component: 2.5l V6 TDI 0000SG 0002
Coding: 07002
Shop #: WSC 00672
Part No: 00006059
Component: 130 106LC150_1.V79470676386
2 Faults Found:
01318 - Control Module for Injection Pump (J399)
49-00 - No Communications0
00532 - Supply Voltage B+
07-00 - Signal too Low
Readiness: 0 0 X X X
En la web dice esto:
01318 - Control Module for Injection Pump (J399): Signal Outside Specifications
01318 - Control Module for Injection Pump (J399): Implausible Signal
01318 - Control Module for Injection Pump (J399): Faulty
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
  • Limp Mode & Reduced Power/Output
  • Emergency/Safety Shut-Off
Possible Causes
  • Injection Pump (J399) faulty
Possible Solutions
  • Check/Replace Injection Pump (J399)
01318 - Control Module for Injection Pump (J399): No Communications
Possible Symptoms
Possible Causes
  • Wiring and/or Connector(s) from/to Injection Pump (J399) faulty
Possible Solutions
  • Check Wiring and/or Connector(s) from/to Injection Pump (J399)
  • Check Communication to Injection Pump (J399)
    • See Measuring Value Block (MVB) 018
    [*]Check/Replace Injection Pump (J399)
Special Notes
  • When found on 2.5l V6 TDI, has a Compression Test been performed? This code may be stored in Combination with a Compression Test even though the Communication is OK. Under these Circumstances this Fault Code should be cleared.
01318 - Control Module for Injection Pump (J399): No Elaboration Available
Possible Symptoms
Possible Causes
  • Control Module Software Issue
Special Notes
SAludos, la bomba te esta fallando pues estas bombas las BOSCH VP 30 Y VP 44, se desgastan unas juntas, toman aire y se desceban, con el tiempo cada dia te costara mas arracar por las mañanas, hasta que deje de arrancar, estas bombas tienen dos fallos, uno electrico y el otro el que he comentado, solucion te dejo un enlace donde las arreglan, otra solucion si es por toma de aire, instalale esta bomba auxiliar para que chupe del deposito, esta solucion esta probada, dejo enlace de la bomba,http://www.mister-auto.es/es/bomba-de-combustible/nissan-patrol-hardtop-k160-3-2-td-k160-110cv_v4324_g458.html
y aqui donde se arregla el problema electrico,
http://www.reparacionvp44.es/p/servicios.html
  • 6 meses más tarde...
Hola,a mi me ocurre lo mismo por más que quiero borrarlo me sigue dando error,pienso que será un fallo real,¿cuál fue vuestra solución al final?
Un saludo y gracias.
1 Fault Found
Sent from my iPhone using Tapatalk - now Free
