Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 BT
Component: G000SG 2805
Coding: 00002
Shop #: WSC 00046
2 Faults Found:
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 00046
0 Faults Found:
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 C
Component: 1M-CLIMATRONIC X0603
Coding: 00043
Shop #: WSC 00046
0 Faults Found:
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 820 E
Component: S5-KOMBIINSTR. VDO V02
Coding: 04142
Shop #: WSC 03555
IMMO-IDENTNR: SEZ7Z0X0040841
0 Faults Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00002
Shop #: WSC 00046
0 Faults Found:
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 3U Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00046
11 Faults Found:
01334 - Door Control Module: Rear Right (J398)
49-10 - No Communications - Intermittent
01333 - Door Control Module: Rear Left (J388)
01332 - Door Control Module: Passenger Side (J387)
49-00 - No Communications
01331 - Door Control Module: Driver Side (J386)
00931 - Locking Module for Central Locking: Rear Right (F223)
54-00 - Incorrectly Equipped
00930 - Locking Module for Central Locking: Rear Left (F222)
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
01389 - Tailgate Open Switch (F124)
29-10 - Short to Ground - Intermittent
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 A
Component: Radio 0001
Coding: 00401
Shop #: WSC 00046
1 Faults Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End -------------------------------------------------------
El problema por el que le he pasado el vag era que despues de desmontar la puerta izda completa para repararle, ahora no, va, le he borrado los errores y solo queda este del modulo 46 :
y el 01:
Deduzco que o falta el cable del bus por conectar o se ha jodido el modulo del cierre centralizado.
Deciros que no funciona nada ahora desde esa puerta, ni cierre, ni elevalunas.
Haber que opinion teneis los expertos.
saludos
Este me salió a mí, despues de quedarme sin fuerza en una subida.
Mañana meto el carro en el taller, ya os contaré. El hilo es este. A ACB le pasa lo mismo pero en "Negative".
Del resto de errores no te puedo ayudar, no sé que son.
Saludos, y ya nos contarás :angry:
