desoues de arreglar un tubo rroto borrar errores y dar una vuelta el mismo error os los dejo n75
VAG-COM Version: Release 311.2-N
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 AE
Component: 1.8L R4/5VT 01 0001
Coding: 05710
Shop #: WSC 00001
2 Faults Found:
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-00 - -
17954 - Boost Pressure Regulation Valve (N75): Short to Plus
P1546 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 06435
1 Fault Found:
00814 - Solenoid for Brake Pressure (N247)
35-00 - -
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 ÿ
Component: TT-KLIMAVOLL
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 8N8 909 601
Component: Airbag Front+Seite 0004
Coding: 10102
Shop #: WSC 06435
No fault code found.
Address 17 -------------------------------------------------------
Controller: 8N1 920 880 A
Component: KOMBI+WEGFAHRS. M73 D24
Coding: 04144
Shop #: WSC 00913
Ident.-Nr. Wegfahrs.:AUZ5Z0X6221232
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
Component: Zentralverrieg.,DWA D01
Coding: 04682
Shop #: WSC 01236
1 Fault Found:
01617 - Please Check DTC Memory of Interior Monitoring
35-00 - -
Address 45 -------------------------------------------------------
Controller: 8N8 951 177
Component: Innenraumueberw. D07
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00010
Shop #: WSC 06435
End -------------------------------------------------------
En efecto. Pero te aconsejo que borres todos los errores, ya que imagino que por tu comentario solo borraste los del motor. Borra todo. Dale un par de dias al coche, y cuelga de nuevo el Log.
Si te salen los mismos fallos, tienes bastante trabajo por delante...
