lava4 Publicado 15 de Mayo del 2013 Denunciar Publicado 15 de Mayo del 2013 Hola pasando el auto-scan me da estos fallos ,y no se de donde son ,tengo navi2g y ads sin botonera y creo que algo tiene que ver con eso ,que me podeis decir ,un saludo. Responder
lava4 Publicado 15 de Mayo del 2013 Autor Denunciar Publicado 15 de Mayo del 2013 .Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb Part No SW: 8T0 035 729 N HW: 4E0 035 729 Component: Interfacebox H43 5170 Revision: 00000000 Serial number: 329DP087564140 Coding: 0000004 Shop #: WSC 02145 785 00200 VCID: 448D52C90780FE9 Part No: 8T0 919 609 Component: E0380 BedienteilH08 0100 1 Fault Found: 03157 - Functionality limited due to Communications Disruption 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 12 Mileage: 81429 km Time Indication: 0 Date: 2013.04.16 Time: 23:11:42 Freeze Frame: Bin. Bits: 00000000 10000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000 Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H21 0253 Revision: 04021001 Serial number: 00000000032486 Coding: 260050914114AF201F01000000001D0D4F9C430800010101000000 Shop #: WSC 02399 823 56573 VCID: 2F670D657E066D1 Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 280408 H06 0060 Coding: 00FD11 Subsystem 2 - Part No SW: 8T0 955 559 HW: 4E0 955 559 B Component: RLS H12 0001 Coding: 02532C Subsystem 3 - Part No SW: 8K0 941 531 Q HW: 8K0 941 531 Q Component: E1 - LDS H07 0090 2 Faults Found: 00471 - Control Module for Elect. Regulated Dampers (J250) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 12 Mileage: 81429 km Time Indication: 0 Date: 2013.04.16 Time: 23:02:00 03207 - Charisma Switch Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 12 Mileage: 81429 km Time Indication: 0 Date: 2013.04.16 Time: 23:02:00 Responder
Jormi Dj Publicado 15 de Mayo del 2013 Denunciar Publicado 15 de Mayo del 2013 yo por lo que veo la frecuencia de los fallos en todos ha sido de una sola vez, el ultimo es un error de que no esta bien concectado el conector charisma o no llevas, que corresponde a la botonera de ADS. este no tiene mayor importancia. te da ese error por no llevar la botonera. y aunque borres te seguira saliendo. y en cuanto al primero no se decirte, pero prueba a borrarlo y si no te vuelve a salir esque no hay mayor importancia. Responder
lava4 Publicado 15 de Mayo del 2013 Autor Denunciar Publicado 15 de Mayo del 2013 Muchas gracias ya me parecía que uno era del ads y el primero si me deja borrarlo pero vuelve aparecer .haber si algún entendido del tema me saca de dudas ,saludos Responder
lava4 Publicado 18 de Mayo del 2013 Autor Denunciar Publicado 18 de Mayo del 2013 Nadie sabe nada del primer fallo,saludos Responder
Jormi Dj Publicado 18 de Mayo del 2013 Denunciar Publicado 18 de Mayo del 2013 hola tiot e encontrado algo mas: http://www.gerritspeek.nl/vag-com_dtc-03157.html Responder
lava4 Publicado 19 de Mayo del 2013 Autor Denunciar Publicado 19 de Mayo del 2013 gracias le echare un vistazo a ver si veo algo Responder
