buenos dias compañeros!!!
despues de mucho tiempo y un autoscan sigue saliendome este fallo en el xenon.alguien sabe como poder corregirlo? gracias!!!Wednesday,15,May,2013,16:35:35:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8T0
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72 77
VIN: WAUZZZ8K99N002351 Mileage: 80130km/49790miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JM HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3173
Revision: --H01---
Coding: 0104002C18072120
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TDI03L906022JM A01005
ROD: EV_ECM20TDI03L906022JM.rod
VCID: 79F3F33DF8C2731
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 160500
Shop #: WSC 02399 823 56573
VCID: 78F5F639CBC86A9
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030100
VCID: 2E591061790C649
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0113.05.081277
Coding: 34000000
VCID: 428154D1DD94F09
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H21 0253
Revision: 04021001 Serial number: 00000000142461
Coding: 260050914034AF000001000000001D0D0F1C030800010101000000
VCID: 2F670D657E066D1
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200508 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 C HW: 8K0 941 531 C
Component: E1 - LDS H07 0070
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD15KPU
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7D2A29B770869
Crash sensor for side airbag; driver side:
Serial number: 6334MSME392211382
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME3A224D56J
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME6644190DK
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME65173F1BR
Crash sensor for front airbag; driver side:
Serial number: 63732SME66047817
Crash sensor for front airbag; passenger side:
Serial number: 63832SME71093E61+
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HEE000KS
Coding: 000016
VCID: 3D7B272DA46A8F1
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H15 0221
Revision: 00200000 Serial number: 7BX50MG58
Coding: 0F0D080002000008050000
VCID: 2D5B176D740A1F1
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0843081AB
Coding: 000303
VCID: 468948C1F1BCCC9
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007205467
Coding: 011C02204100410001
VCID: 3F875D25AE669D1
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0111709198
Coding: 0100062000390040012001
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010102
VCID: 6ED9D061B98C249
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007190998
Coding: 011C02204D00410001
VCID: 3E792021A96C949
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000132882
Shop #: WSC 00000 000 00000
VCID: 30650E196338729
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 346D020957204E9
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 56
Mileage: 80074 km
Time Indication: 0
Date: 2013.05.14
Time: 11:30:36
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
Component: Concert3 H01 0310
Revision: 00000003 Serial number: AUZ5Z6H1063955
Coding: 05020082010185000159070000
VCID: 377735058656A51
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
00468 - CD-ROM Drive (R92)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 90
Mileage: 79553 km
Time Indication: 0
Date: 2013.05.12
Time: 01:46:06
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007199168
Coding: 010C02204000210001
VCID: FF079D256EE6DD1
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007173492
VCID: FEF9602169ECD49
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 A HW: 8T0 862 335 A
Component: FSE_256x BT H33 0520
Revision: 00000000 Serial number: 00000005002601
Coding: 0010350
VCID: 387536394B48AA9
End ---------------------------------------------------------------------
la pagina esta de cine amigo.yo llevaba bastante tiempo con ese fallo y mira x donde ya esta solucionado jjj.no sabras como poner el modo autoescuela en el mmi verdad,o para poder hacer algo mas con el vag? gracias
