javiruedas Publicado 18 de Junio del 2013 Denunciar Compartir Publicado 18 de Junio del 2013 hola compañeros he buscado y no he encontrado nada claro sobre el siguiente error, a ver si alguien sabe algo mas. el coche es del 2009 reestilyng Address 01: Engine Labels: 03L-906-022-CAG.clb Control Module Part Number: 03L 906 022 FG HW: 03L 906 022 FG Component and/or Version: R4 2,0L EDC H01 4397 Software Coding: 0105002C18072120 Work Shop Code: WSC 02325 785 00200 ASAM Dataset: EV_ECM20TDI03L906022FG A01006 (AU56) VCID: 6FE7CD65B6862D1 5 Faults Found: 4914 - Diesel Particle Filter; Differential Pressure Sensor P2453 00 [104] - Implausible Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 104233 km Date: 2013.06.14 Time: 20:16:37 5182 - Particulate Trap Bank 1 P2002 00 [108] - Efficiency Below Threshold Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 5 Mileage: 104310 km Date: 2013.06.15 Time: 21:33:23 5253 - Exhaust Pressure Sensor 1 (G450) P0473 00 [046] - Signal too High Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 13 Mileage: 104239 km Date: 2013.06.15 Time: 09:17:44 5262 - Exhaust Pressure Sensor 1 (G450) P0472 00 [040] - Signal too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 110 Mileage: 104248 km Date: 2013.06.15 Time: 13:54:55 5162 - Exhaust Pressure Sensor 1 (G450) P0471 00 [232] - Implausible Signal MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 104519 km Date: 2013.06.17 Time: 15:49:30 Readiness: 1 5 0 0 0 Tuesday,18,June,2013,08:22:12:32264 VCDS Version: Release 11.11.3 Data version: 20120401 Address 01: Engine Labels: 03L-906-022-CAG.clb Control Module Part Number: 03L 906 022 FG HW: 03L 906 022 FG Component and/or Version: R4 2,0L EDC H01 4397 Software Coding: 0105002C18072120 Work Shop Code: WSC 02325 785 00200 ASAM Dataset: EV_ECM20TDI03L906022FG A01006 (AU56) VCID: 6FE7CD65B6862D1 5 Faults Found: 4914 - Diesel Particle Filter; Differential Pressure Sensor P2453 00 [104] - Implausible Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 104233 km Date: 2013.06.14 Time: 20:16:37 5182 - Particulate Trap Bank 1 P2002 00 [108] - Efficiency Below Threshold Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 5 Mileage: 104310 km Date: 2013.06.15 Time: 21:33:23 5253 - Exhaust Pressure Sensor 1 (G450) P0473 00 [046] - Signal too High Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 13 Mileage: 104239 km Date: 2013.06.15 Time: 09:17:44 5262 - Exhaust Pressure Sensor 1 (G450) P0472 00 [040] - Signal too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 110 Mileage: 104248 km Date: 2013.06.15 Time: 13:54:55 5162 - Exhaust Pressure Sensor 1 (G450) P0471 00 [232] - Implausible Signal MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 104519 km Date: 2013.06.17 Time: 15:49:30 Readiness: 1 5 0 0 0 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
raulbs Publicado 13 de Septiembre del 2013 Denunciar Compartir Publicado 13 de Septiembre del 2013 Buenas tardes javiruedas, pudiste solucionar estos errores? A mi coche se le ha encendido el maldito testigo del dpf 4914 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal P2453 00 [032] - Lower Limit Exceeded 5262 - Exhaust Pressure Sensor 1 (G450): Signal too Low P0472 00 [172] - Defective Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 29 Mileage: 110278 km Date: 2013.09.13 Los he borrado y ha desaparecido el testigo. He mirado los valores del dpf y dan: Uploaded with ImageShack.us Gracias. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
