gabete Publicado 28 de Junio del 2013 Denunciar Publicado 28 de Junio del 2013 Bueo aquí os dejo las fallos que me salen uandoe paso el vag com, haber si algn alma caritativa me dice como quitarlos Chassis Type: 1K0 Scan: 01 02 03 08 09 15 16 17 19 25 36 37 42 44 46 47 52 56 57 62 72 76 77 VIN: WAUZZZ8P68B013495 Mileage: 49630km/30838miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Cannot be reached 1100 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: Not registered 0011 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 021 LG HW: 03G 906 021 AN Component: R4 2,0L EDC G000AG 9828 Revision: --H07--- Serial number: AUX7Z0H0FN704F Coding: 0000078 Shop #: WSC 11111 257 00032 1 Fault Found: 005784 - Please Check DTC Memory of Steering Wheel Electronics P1698 - 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Mileage: 49637 km Time Indication: 0 Date: 2013.06.21 Time: 13:24:27 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.39 V Bin. Bits: 00101011 Bin. Bits: 00000000 (no units): 0.0 Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-300-0xx.lbl Part No SW: 02E 300 050 D HW: 02E 927 770 AE Component: GSG DSG 081 1401 Revision: 04708010 Serial number: 00000712140235 Coding: 0000020 Shop #: WSC 00046 412 163840 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0023170 Shop #: WSC 00046 412 16384 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG Component: KlimavollautomatH19 0430 Revision: 230322 Serial number: 8P0820043AG Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl Part No SW: 8P0 907 279 K HW: 8P0 907 279 K Component: Bordnetz-SG H54 2501 Revision: 00H54000 Serial number: 00000007998382 Coding: E5881F01901410004F1600001600000000085E175C010000000000000000 Shop #: WSC 00046 412 172032 Part No: 8P1 955 119 E Component: Wischer AU350 H01 0130 Coding: 00062736 Shop #: WSC 00046 Part No: 4E0 910 557 B Component: REGENLICHTSENSORH13 0100 Coding: 00150573 Shop #: WSC 00046 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-94.lbl Part No SW: 8P0 959 655 L HW: 8P0 959 655 L Component: Airbag 9.41 H01 4210 Revision: 91H01421 Serial number: 003CP0023U9+ Coding: 0070612 Shop #: WSC 00046 412 16384 1 Fault Found: 01218 - Side Airbag Igniter; Passenger Side (N200) 001 - Upper Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 1 Fault Frequency: 1 Mileage: 49600 km Time Indication: 0 Date: 2013.06.20 Time: 17:48:16 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549-F.lbl Part No SW: 8P0 953 549 F HW: 8P0 953 549 F Component: J0527 H38 0070 Coding: 0012142 Shop #: WSC 12345 123 12345 Part No: XXXXXXXXXXX Component: E0221 H02 0030 1 Fault Found: 00895 - Cruise Control Switch (E45) 014 - Defective ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.lbl Part No SW: 8P0 920 931 E HW: 8P0 920 931 E Component: KOMBIINSTR. VDO H22 0660 Revision: D0H22003 Serial number: 2240H003133373 Coding: 0000128 Shop #: WSC 11111 111 11111 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533__Gateway H15 0180 Revision: H15 Serial number: 1400K07B150097 Coding: ED80FF0E5006020102 Shop #: WSC 80093 222 69422 2 Faults Found: 01335 - Drivers Seat/Mirror Position Control Module (J543) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 122 Mileage: 49594 km Time Indication: 0 Date: 2013.06.20 Time: 17:31:56 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 122 Mileage: 49594 km Time Indication: 0 Date: 2013.06.20 Time: 17:31:56 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl Part No SW: 8P0 920 931 E HW: 8P0 920 931 E Component: KOMBIINSTR. VDO H22 0660 Revision: D0H22003 Serial number: AUX7Z0H0FN704F Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Cannot be reached ------------------------------------------------------------------------------- Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 S HW: 8P0 035 192 S Component: RNS-E HIGH EU H99 0660 Revision: 21S Serial number: AUZBZ7L9926640 Coding: 0205755 Shop #: WSC 11111 000 00000 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 122 Mileage: 49594 km Time Indication: 0 Date: 2013.06.20 Time: 17:31:47 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl Part No SW: 8P0 959 801 K HW: 8P0 959 801 K Component: Tuer-SG H03 0050 Coding: 0000216 Shop #: WSC 00046 412 81920 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 M Component: EPS_ZFLS Kl.079 H08 1901 Shop #: WSC 02069 000 90108 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 J Component: KSG H11 0080 Coding: 1980202002586E0985054C8FC677 Shop #: WSC 00046 412 17203 Part No: 1K0 951 605 D Component: LIN BACKUP HORN H07 9001 Part No: 1K0 907 719 C Component: Neigungssensor 005 0003 Part No: 8P0 951 177 Component: Innenraumueberw.H04 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8Px-035-382.lbl Part No SW: 8P4 035 382 D HW: 8P4 035 382 D Component: AB2 SUBWOOFERBOXH06 0180 Revision: 00005 Serial number: 30674753112054 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl Part No SW: 8P0 959 802 K HW: 8P0 959 802 K Component: Tuer-SG H03 0050 Coding: 0000216 Shop #: WSC 00046 412 81920 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 S HW: 8P0 035 192 S Component: RNS-E HIGH EU H99 0660 Revision: 21S Serial number: AUZBZ7L9926640 Coding: 0205755 Shop #: WSC 11111 000 00000 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 122 Mileage: 49594 km Time Indication: 0 Date: 2013.06.20 Time: 17:31:47 ------------------------------------------------------------------------------- Address 57: TV Tuner Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 8P4-959-801.lbl Part No SW: 8P4 959 801 E HW: 8P4 959 801 E Component: Tuer-SG H04 0040 Coding: 0000216 Shop #: WSC 00046 412 1012544 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 8P4-959-802.lbl Part No SW: 8P4 959 802 E HW: 8P4 959 802 E Component: Tuer-SG H04 0040 Coding: 0000216 Shop #: WSC 00046 412 1012544 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8P0-919-283.lbl Part No SW: 8P0 919 283 D HW: 8P0 919 283 D Component: Parkhilfe 4-Kan H09 0070 Revision: 00H09000 Serial number: 00067824840734 Coding: 0001013 Shop #: WSC 00046 412 172032 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q Component: FSE_255x BT H26 0350 Revision: 00000000 Serial number: 00000005292593 Coding: 0011455 Shop #: WSC 00298 572 57925 No fault code found. End --------------------------------------------------------------------- Friday,21,June,2013,13:34:32:13314 VCDS Version: Release 908.0 Data version: 20090911 Responder
