Oscar-flat26 Publicado 22 de Julio del 2013 Denunciar Compartir Publicado 22 de Julio del 2013 (editado) Hoy he conseguido instalar correctamente el vag com y hacer mi primer escaneo y me ha salido esto. ¿Me puede explicar alguien lo que me ha salido? Sunday,21,July,2013,14:49:50:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: XXXXXXXXXXXXXXXX Mileage: 133310km/82834miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BLB.clb Part No SW: 03G 906 016 GN HW: 028 101 211 3 Component: R4 2,0L EDC G000SG 9618 Revision: 12345678 Serial number: Coding: 0000072 Shop #: WSC 01610 572 92628 VCID: 75EBFF0D1CDA171 7 Faults Found: 17996 - Engine Mount Solenoid Valves (N144/N145) P1588 - 000 - Open Circuit Freeze Frame: RPM: 966 /min Torque: 22.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.16 V Bin. Bits: 00101100 Torque: 146.4 Nm Torque: 0.0 Nm 17055 - Cylinder 1 Glow Plug Circuit (Q10) P0671 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 17056 - Cylinder 2 Glow Plug Circuit (Q11) P0672 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 17057 - Cylinder 3 Glow Plug Circuit (Q12) P0673 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 17058 - Cylinder 4 Glow Plug Circuit (Q13) P0674 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 16683 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached Freeze Frame: RPM: 2415 /min Torque: 278.0 Nm Speed: 97.0 km/h Load: 74.5 % Voltage: 14.14 V Bin. Bits: 00101000 Absolute Pres.: 2274.6 mbar Absolute Pres.: 1856.4 mbar 16485 - Mass Air Flow Sensor (G70) P0101 - 000 - Implausible Signal Freeze Frame: RPM: 2289 /min Torque: 0.0 Nm Speed: 114.0 km/h Temperature: 27.9°C Mass Flow: 28.44 g/s (no units): 1.55 Temperature: 84.6°C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK Component: ESP8 front H05 0120 Revision: 00000000 Serial number: 00000000000000 Coding: 0004401 Shop #: WSC 06325 000 00000 VCID: 2855E6799BE83A9 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01001110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 214 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4022 Hex Value: 0x0001 Hex Value: 0xDAAF Hex Value: 0x0001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BJ Component: A4 Klimaautomat 2832 Coding: 00000 Shop #: WSC 00000 VCID: 6AD1DC711664C89 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 L Component: int. Lastmodul ECE 0504 Coding: 10001 Shop #: WSC 06325 VCID: 3B7F2935297E811 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H11 3530 Revision: 91H1135 Serial number: 0036M0072HX4 Coding: 0033622 Shop #: WSC 06325 000 00000 VCID: 3B7F29357A7E811 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 02042 Shop #: WSC 06325 VCID: 41835BDD4B92EB1 1 Fault Found: 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 D HW: 8E0 920 901 D Component: KOMBI+WFS 4 H12 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0006141 Shop #: WSC 00001 001 00001 VCID: 2649E84192FC2C9 1 Fault Found: 01304 - Radio 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: EBDF5975999E511 1 Fault Found: 01463 - Alarm triggered by Sensor for anti-theft alarm System 43-00 - Closed ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CA Component: Komfortgerát T3B 3332 Coding: 08058 Shop #: WSC 06325 VCID: 72E1C4113EB4009 Subsystem 1 - Part No: 8E1959801H Component: Tõrsteuer.FS BRM 0406 Subsystem 2 - Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0205 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0205 3 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - End --------------------------------------------------------------------- Sunday,21,July,2013,14:57:49:32264 VCDS Version: Release 11.11.3 Data version: 20120401 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: XXXXXXXXXXXXX Mileage: 133310km/82834miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BLB.clb Part No SW: 03G 906 016 GN HW: 028 101 211 3 Component: R4 2,0L EDC G000SG 9618 Revision: 12345678 Serial number: Coding: 0000072 Shop #: WSC 01610 572 92628 VCID: 75EBFF0D1CDA171 7 Faults Found: 17996 - Engine Mount Solenoid Valves (N144/N145) P1588 - 000 - Open Circuit Freeze Frame: RPM: 966 /min Torque: 22.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.16 V Bin. Bits: 00101100 Torque: 146.4 Nm Torque: 0.0 Nm 17055 - Cylinder 1 Glow Plug Circuit (Q10) P0671 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 17056 - Cylinder 2 Glow Plug Circuit (Q11) P0672 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 17057 - Cylinder 3 Glow Plug Circuit (Q12) P0673 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 17058 - Cylinder 4 Glow Plug Circuit (Q13) P0674 - 000 - Electrical Fault Freeze Frame: RPM: 840 /min Torque: 40.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101111 Temperature: 13.5°C Bin. Bits: 10110000 16683 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached Freeze Frame: RPM: 2415 /min Torque: 278.0 Nm Speed: 97.0 km/h Load: 74.5 % Voltage: 14.14 V Bin. Bits: 00101000 Absolute Pres.: 2274.6 mbar Absolute Pres.: 1856.4 mbar 16485 - Mass Air Flow Sensor (G70) P0101 - 000 - Implausible Signal Freeze Frame: RPM: 2289 /min Torque: 0.0 Nm Speed: 114.0 km/h Temperature: 27.9°C Mass Flow: 28.44 g/s (no units): 1.55 Temperature: 84.6°C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK Component: ESP8 front H05 0120 Revision: 00000000 Serial number: 00000000000000 Coding: 0004401 Shop #: WSC 06325 000 00000 VCID: 2855E6799BE83A9 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01001110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 214 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4022 Hex Value: 0x0001 Hex Value: 0xDAAF Hex Value: 0x0001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BJ Component: A4 Klimaautomat 2832 Coding: 00000 Shop #: WSC 00000 VCID: 6AD1DC711664C89 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 L Component: int. Lastmodul ECE 0504 Coding: 10001 Shop #: WSC 06325 VCID: 3B7F2935297E811 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H11 3530 Revision: 91H1135 Serial number: 0036M0072HX4 Coding: 0033622 Shop #: WSC 06325 000 00000 VCID: 3B7F29357A7E811 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 02042 Shop #: WSC 06325 VCID: 41835BDD4B92EB1 1 Fault Found: 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 D HW: 8E0 920 901 D Component: KOMBI+WFS 4 H12 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0006141 Shop #: WSC 00001 001 00001 VCID: 2649E84192FC2C9 1 Fault Found: 01304 - Radio 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: EBDF5975999E511 1 Fault Found: 01463 - Alarm triggered by Sensor for anti-theft alarm System 43-00 - Closed ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CA Component: Komfortgerát T3B 3332 Coding: 08058 Shop #: WSC 06325 VCID: 72E1C4113EB4009 Subsystem 1 - Part No: 8E1959801H Component: Tõrsteuer.FS BRM 0406 Subsystem 2 - Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0205 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0205 3 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - End --------------------------------------------------------------------- Muchas gracias de antemano y un saludo a todos. Editado 22 de Julio del 2013 por Serjio Responder Enlace al comentario Compartir en otros sitios web More sharing options...
TRACKER_A4 Publicado 22 de Julio del 2013 Denunciar Compartir Publicado 22 de Julio del 2013 Borra todos los errores y pasalo de nuevo a ver que sale. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Oscar-flat26 Publicado 22 de Julio del 2013 Autor Denunciar Compartir Publicado 22 de Julio del 2013 Eso mismo es lo que salio despues de borrar. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
TRACKER_A4 Publicado 22 de Julio del 2013 Denunciar Compartir Publicado 22 de Julio del 2013 Los de la alarma tambien? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Oscar-flat26 Publicado 22 de Julio del 2013 Autor Denunciar Compartir Publicado 22 de Julio del 2013 Si, salvo que haya hecho algo raro eso es lo que salió. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
TRACKER_A4 Publicado 22 de Julio del 2013 Denunciar Compartir Publicado 22 de Julio del 2013 Es que los de la alarma saltada no deberian de apatecer. Ahi salen fallos como cableado de bujias o caudalimetro. El coche te va bien? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Oscar-flat26 Publicado 22 de Julio del 2013 Autor Denunciar Compartir Publicado 22 de Julio del 2013 No va muy fino. Me pega tirones a veces a bajas revoluciones y también echa humo negro a bajas revoluciones. Y en un par de ocasiones no tiraba, paré el coche, volví a arrancar y otra vez iba normal. En cuanto al arranque no va fino del todo, siempre arranca a la primera pero arranca algo raro. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
TRACKER_A4 Publicado 22 de Julio del 2013 Denunciar Compartir Publicado 22 de Julio del 2013 Que motor es? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Oscar-flat26 Publicado 22 de Julio del 2013 Autor Denunciar Compartir Publicado 22 de Julio del 2013 TDI 2.0 140CV B7 2005 Creo que es BLB, de los que se rompe la bomba. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Serjio Publicado 22 de Julio del 2013 Denunciar Compartir Publicado 22 de Julio del 2013 ¿Y todos esos errores te da una vez borrados? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
TRACKER_A4 Publicado 23 de Julio del 2013 Denunciar Compartir Publicado 23 de Julio del 2013 Ostras, si es diesel lo que te dije de las bujias no es. Como no se refiera a inyectores... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Oscar-flat26 Publicado 23 de Julio del 2013 Autor Denunciar Compartir Publicado 23 de Julio del 2013 ¿Y todos esos errores te da una vez borrados? Eso es, salvo que hiciera algo mal, así es. En cuanto a lo de las bujías, el mecánico lo enganchó a su ordenador, no es vag com, y daba error de bujías de precalentamiento, creo recordar que de las 4. Lo que en teoría se supone que son los calentadores, ¿no? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
TRACKER_A4 Publicado 23 de Julio del 2013 Denunciar Compartir Publicado 23 de Julio del 2013 ¿Y todos esos errores te da una vez borrados? Eso es, salvo que hiciera algo mal, así es. En cuanto a lo de las bujías, el mecánico lo enganchó a su ordenador, no es vag com, y daba error de bujías de precalentamiento, creo recordar que de las 4. Lo que en teoría se supone que son los calentadores, ¿no? Si, calentadores. Eso explicaria el problema de arranque. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Oscar-flat26 Publicado 23 de Julio del 2013 Autor Denunciar Compartir Publicado 23 de Julio del 2013 (editado) Pero siempre ha arrancado a la primera, solo que muchas veces es un arranque raro, no es limpio. Pero, ¿eso quiere decir que tengo que cambiar los 4 calentadores? En cuanto a los demás fallos, ¿qué debo hacer tamnién? Editado 23 de Julio del 2013 por Oscar-flat26 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
TRACKER_A4 Publicado 23 de Julio del 2013 Denunciar Compartir Publicado 23 de Julio del 2013 En principio, cambiar el caudalimetro o el sensor MAP. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
