Hola a todos, hoy iba al médico a Madrid y me ha dejado tirado el coche.
Se le ha tenido que llevar la grúa al taller.
Acabo de pasarme por el taller y le he pasado el vag com.
Esto es lo que me ha salido.
¿Qué me decís?
Tuesday,30,July,2013,17:01:30:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 133920km/83214miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 01610 572 92628
VCID: 75EBFF0D1CDA171
8 Faults Found:
17996 - Engine Mount Solenoid Valves (N144/N145)
P1588 - 000 - Open Circuit
Freeze Frame:
RPM: 966 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00101100
Torque: 146.4 Nm
Torque: 0.0 Nm
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00101111
Temperature: 13.5°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00101111
Temperature: 13.5°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00101111
Temperature: 13.5°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00101111
Temperature: 13.5°C
Bin. Bits: 10110000
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 2289 /min
Torque: 0.0 Nm
Speed: 114.0 km/h
Temperature: 27.9°C
Mass Flow: 28.44 g/s
(no units): 1.55
Temperature: 84.6°C
16787 - EGR Valve (N18)
P0403 - 000 - Malfunction
Freeze Frame:
RPM: 1659 /min
Torque: 0.0 Nm
Speed: 27.0 km/h
Duty Cycle: 84.4 %
Voltage: 14.06 V
Mass Air / Rev.: 460.0 mg/str
Duty Cycle: 25.3 %
Bin. Bits: 00000000
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2331 /min
Torque: 180.0 Nm
Speed: 116.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 01101000
Absolute Pres.: 1978.8 mbar
Absolute Pres.: 1224.0 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 2855E6799BE83A9
2 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01001110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 176
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4022
Hex Value: 0x0001
Hex Value: 0xDAAF
Hex Value: 0x0001
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0600
Hex Value: 0x1302
Hex Value: 0x0003
Hex Value: 0x1693
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BJ
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6AD1DC711664C89
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 10001
Shop #: WSC 06325
VCID: 3B7F2935297E811
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M0072HX4
Coding: 0033622
VCID: 3B7F29357A7E811
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02042
Shop #: WSC 06325
VCID: 41835BDD4B92EB1
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 D HW: 8E0 920 901 D
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0006141
Shop #: WSC 00001 001 00001
VCID: 2649E84192FC2C9
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CA
Component: Komfortgerát T3B 3332
Coding: 08058
Shop #: WSC 06325
VCID: 72E1C4113EB4009
Subsystem 1 - Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0406
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
4 Faults Found:
01134 - Alarm Horn (H12)
37-10 - Faulty - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
End ---------------------------------------------------------------------
Según me ha comentado esta mañana el mecánico parece ser que la EGR está fastidiada.
Así que a ponerla nueva.
Espero que con eso se solucione todo.
Os iré contando.
Oscar espero que solo sea la EGR, porque ya se van 300€ si es original.
Pues la EGR original me sale por 250€, a parte la mano de obra.
Además ya le voy a poner los 4 calentadores nuevos y a cambiar el sensor map, ya que están dando error en el vag com.
Así que todo eso mas la mano de obra pues mínimo 500€ la broma.
A mi me cobraron 312€ en Audi por la EGR + mano de obra. Los calentadores puedes cambiarlos tu y pedirlos en Oscaro, seguro que te ahorras pasta. Del sensor no tengo ni idea.
Los calentadores y el sensor los he pedido en Oscaro Iván, pero yo no tengo ni idea de mecánica así que me los monta el mecánico.
Yo le llevo las piezas y me cobra la mano de obra.
Las piezas me han salido por 100€.
En cuanto a la EGR la que lleva mi coche es Siemens VDO y la misma en Oscaro cuesta 235€ creo recordar y si se la cojo al mecánico esa misma también me sale por 250€.
Como me corre prisa y no hay apenas diferencia pues le he dicho que la pida.
Pues nada, espero que con eso ya tengas el coche arreglado. Ya nos contaras.
En principio me lo dan hoy por la mañana.
Ya os contaré mis primeras impresiones después de los cambios.
Bueno, he recogido el coche hace nada del taller y por el momento las primeras impresiones son buenas,
Lo tendré que probar mas para verlo bien.
Y en cuanto a la cantidad total han sido 447€.
Vaya bromita...
En cuanto pueda le pasaré el vag com, pero el mecánico me ha dicho que a el ya no le salía ningún error.
Acabo de pasar el vag com y ahora sale esto (despues de borrar y volver a escanear).
¿Que me podeis decir al respecto?
Friday,02,August,2013,22:18:00:32264
69 75 76 77
VIN: XXXXXXXXXXXXXXXXXX Mileage: 133940km/83226miles
Coding: 0000072
1 Fault Found:
Freeze Frame:
RPM: 1008 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Torque: 144.0 Nm
Torque: 0.0 Nm
Coding: 0004401
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 171
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4022
Hex Value: 0x0001
Hex Value: 0xDAAF
Hex Value: 0x0001
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x0600
Hex Value: 0x1302
Hex Value: 0x0003
Hex Value: 0x1693
Hex Value: 0x0001
Coding: 00000
Shop #: WSC 00000
Coding: 10001
Shop #: WSC 06325
Coding: 0033622
Coding: 02042
Shop #: WSC 06325
1 Fault Found:
01304 - Radio
Coding: 0006141
1 Fault Found:
01304 - Radio
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBDF5975999E511
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Coding: 08058
Shop #: WSC 06325
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
