Mira la copia abajo el historial de las ultimas ITV´s desde 2010, no hay nada alarmante:
CX06DOUAUDI A4
Check another vehicle
ColourBlue
Fuel typeDiesel
Date registered26 April 2006
MOT valid until22 October 2019
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal.(Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Open All
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories
Date tested23 October 2018
PASS
Mileage84,323 miles
MOT test number2424 9118 0601
Test location
 View test location
Expiry date22 October 2019
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested16 April 2018
PASS
Mileage81,040 miles
MOT test number4320 4169 4232
Test location
 View test location
Expiry date6 May 2019
Advisory notice item(s)
  • oil leak on the rear diff
  • under trays fitted
 What are advisories?
FAIL
Mileage81,038 miles
MOT test number7289 0827 1460
Test location
 View test location
Reason(s) for failure
  • Offside Rear coil spring broken (2.4.C.1a)
  • brake pad light on
 What are failures and advisories?
Date tested21 April 2017
PASS
Mileage76,278 miles
MOT test number5583 4596 5938
Test location
 View test location
Expiry date6 May 2018
  • Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
  • Rear Brake pad(s) wearing thin (3.5.1g)
  • Rear Oil leak differential ()
  • under trays fitted preventing full inspection of underside components
Date tested20 April 2017
FAIL
Mileage76,276 miles
MOT test number6015 6872 9183
Test location
 View test location
  • Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Offside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Date tested25 April 2016
PASS
Mileage71,446 miles
MOT test number7117 6256 3730
Test location
 View test location
Expiry date6 May 2017
Date tested23 April 2015
PASS
Mileage66,505 miles
MOT test number7875 4341 5161
Test location
 View test location
Expiry date6 May 2016
Date tested23 April 2014
PASS
Mileage61,727 miles
MOT test number4784 7351 4137
Test location
 View test location
Expiry date6 May 2015
Date tested24 April 2013
PASS
Mileage56,804 miles
MOT test number2171 5401 3475
Test location
 View test location
Expiry date6 May 2014
Date tested12 April 2012
PASS
Mileage52,418 miles
MOT test number3257 3320 2177
Test location
 View test location
Expiry date6 May 2013
Date tested6 May 2011
PASS
Mileage47,679 miles
MOT test number2279 0612 1437
Test location
 View test location
Expiry date6 May 2012
  • Tyre worn close to the legal limit (4.1.E.1)
Date tested5 May 2010
PASS
Mileage42,428 miles
MOT test number8434 2562 0176
Test location
 View test location
Expiry date6 May 2011
Date tested7 May 2009
PASS
Mileage36,621 miles
MOT test number3347 6722 9120
Test location
 View test location
Expiry date6 May 2010
  • Respuestas 82
Posted Images
hace 58 minutos, goll1974 dijo:
Totalmente cierto en lo que dices, son más "Flexibles" y te voy a poner un ejemplo que lo explica:
Cuando le puse la instalación de Xenón OEM al B5, en la ITV de Galicia no les dije nada y me hice el tonto , estuvieron mirando y remirando "mosqueados"por que algo no les cuadraba a pesar de que la instalación que hice es casi "perfecta" (no es por echarme flores pero es ASI) pero al final me la pasaron.
Al año siguiente, lo matriculé aquí en Reino unido y el que me pasa las ITV´s aquí es amigo y le comente que el Xenón fue montado "después" y su respuesta fue que  "aquí sólo miramos si el dispositivo funciona y si no nada que pueda ser peligroso y yo lo veo todo bien". No necesité homologación, esto es solo para modificaciones importantes.
y es como deberia de funcionar ser, funciona bien esta bien instalado adelante. Lo mismo con frenos, ruedas, defensas etc..
hace 56 minutos, goll1974 dijo:
El xenón se lo montaría yo después y el cuero para mí no es imprescindible.
Ya lo veré mañana pero el interior no parece que esté desgastado para más millas.
viendo lo que me comentaste antes, tambien haria lo mismo, total no es nada complicado y ahi teneis de todo!! jejejje
CX06DOUAUDI A4
ColourBlue
Fuel typeDiesel
Open All
MOT history
PASS
Mileage84,323 miles
Test location
 View test location
PASS
Mileage81,040 miles
Test location
 View test location
FAIL
Mileage81,038 miles
Test location
 View test location
PASS
Mileage76,278 miles
Test location
 View test location
FAIL
Mileage76,276 miles
Test location
 View test location
PASS
Mileage71,446 miles
Test location
 View test location
PASS
Mileage66,505 miles
Test location
 View test location
PASS
Mileage61,727 miles
Test location
 View test location
PASS
Mileage56,804 miles
Test location
 View test location
PASS
Mileage52,418 miles
Test location
 View test location
PASS
Mileage47,679 miles
Test location
 View test location
PASS
Mileage42,428 miles
Test location
 View test location
PASS
Mileage36,621 miles
Test location
 View test location
Lo que veo es que no das arreglado la fuga de aceite del diferencial jajajajja
lo que no comprendo es que unas veces te tiran para atras por eso y otras pasas.
hace 10 horas, Carlisu84 dijo:
Pero si eso es el historial de las ITV que las puedes ver en internet en la pagina del gobierno Británico!!!
Lo puedes ver de cualquier coche matriculado aquí en UK.
Ese es el historial del coche que voy a ver mañana!! no es el mío.
Perdona que no lo había especificado!!
Eso es genial porque hay menos fraude.
Carlos, se puede saber desde que chasis o fecha se solucionó lo de los tensores de la cadena de los 3.0 TDI? o si alguien lo sabe?
En 3/2/2019 a las 16:56, Carlisu84 dijo:
la verdad es que no se y tampoco me suena nada sobre eso.
Lo que si se, es que estos motores han salido bastante duros y robustos y pocas averias comunes han tenido.
Al final, no pude ver ese B7 3.0 pero a ver si la semana que viene.
Me he estado empapando sobre la historia de la cadena de estos motores y parece que en los primeros años de fabricación (2005 a 2008) daban problemas los tensores pudiendo acabar en la destrucción del motor si se ignoraba.
La reparación no es complicada pero toma tiempo porque hay que sacar el motor y después embrague, volante motor, tapas cadenas, etc y el kit no es muy caro :
https://www.ebay.co.uk/itm/SWAG-Germany-STEUERKETTE-STEUERKETTENSATZ-AUDI-2-7-3-0-TDI-BSG-BPP-BMK-BNG-BUN/182456181162
Hay vídeos sobre esto :
Bueno chavales,
Al final me he hecho con un B7 2.7 TDI S-Line de septiembre de 2007 con 150.000 kms y le he hecho 200 kilómetros de la compra-venta a mi casa y es ES-PEC-TA-CULAR.
Al final Carlisu me ha convencido.
Ya haré una presentación como Dios manda este fin de semana en este foro; llego a casa de trabajar sin luz y no puedo hacer fotos.
hace 18 minutos, batanson dijo:
Felicidades por la adquisición.
Gracias, ya daré mas detalles.
Una pregunta urgente referente a este B7.
La dirección asistida  hace un poco de ruido al girar y he visto que el nivel de fluido está al mínimo, tiene servotronic
¿Sabéis si utiliza un fluido diferente al verde (G004000M2) ó es el mismo?
Gracias.
En 13/2/2019 a las 7:47, goll1974 dijo:
Gracias.
No no tiene servotronic, este aún es a la antigua usanza.
Si está el nivel bajo aprietas los capuchones de la cremallera haber si hay perdida de líquido por ahi
En 15/2/2019 a las 15:28, Carlisu84 dijo:
Carlos,
Según la pegatina de los códigos de equipamiento sí lleva "Servotronic" y es 1N3, aparte de que se endurece con la velocidad.
Le he rellenado un poco de líquido pero parece que los capuchones no están hinchados.
