Os expongo las dos lecturas del forero que conocí el sabado en la Vaguada:
1ª LECTURA.
VAG-COM Version: Release 704.1
Data version: 20070422
Saturday,28,September,2013,13:56:18:26365
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Mileage: 307050km/190792miles
Address 01: Engine Labels: 059-907-401-AKE.LBL
Part No: 4B0 907 401 H
Component: 2,5l/4VT EDC G00SG D33
Coding: 01002
Shop #: WSC 05308
7 Faults Found:
00550 - Start of Injection Regulation
17-10 - Control Difference - Intermittent
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
01376 - Engine Speed Signal for Injection Pump
37-10 - Faulty - Intermittent
00523 - Intake Air Temp Sensor (G42)
30-10 - Open or Short to Plus - Intermittent
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
01318 - Control Module for Injection Pump (J399)
49-10 - No Communications - Intermittent
00546 - Data wiring faulty
Readiness: N/A
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.LBL
Part No: 4B0 820 043 F
Component: A6-Klimavollautomat D55
Coding: 00063
Shop #: WSC 02324
7 Faults Found:
00779 - Outside Air Temp Sensor (G17)
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-10 - Blocked or No Voltage - Intermittent
01272 - Positioning Motor for Central Flap (V70)
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01273 - Fresh Air Blower (V2)
01582 - Signal for Coolant Temperature
Address 15: Airbags Labels: None
Part No: 4B0 959 655 J
Component: Airbag 7 Audi 0501
Coding: 00106
Shop #: WSC 02324
1 Fault Found:
Address 17: Instruments Labels: 4B0-919-xxx-17.LBL
Part No: 4B0 919 880 GX
Component: C5-KOMBIINSTR. VDO D03
Coding: 05160
Shop #: WSC 05308
Part No: IMMO
Component: IDENTNR: AUZ7Z0W0436738
IMMO-IDENTNR: AUZ7Z0W0436738
2 Faults Found:
01176 - Key
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Part No: 4B0 962 258 E
Component: Zentralverrieg.,DWA D32
Coding: 04683
Shop #: WSC 02325
6 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Part No: 4B0 951 173
Component: Innenraumueberw. D02
Coding: 00001
Shop #: WSC 02324
4 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
27-10 - Implausible Signal - Intermittent
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
End --------------------------------------------------------------------------------------------------
2ª LECTURA TRAS BORRADO ANTERIOR
Saturday,28,September,2013,14:37:34:26365
76 77
Coding: 01002
Shop #: WSC 05308
1 Fault Found:
Readiness: N/A
Coding: 00063
Shop #: WSC 02324
1 Fault Found:
Coding: 00106
Shop #: WSC 02324
No fault code found.
Coding: 05160
Shop #: WSC 05308
Part No: IMMO
1 Fault Found:
Coding: 04683
Shop #: WSC 02325
Coding: 00001
Shop #: WSC 02324
Pues en principio el sensor de temperatura de admisión esta mal, si no me equivoco esta en el intercooler, puede ser la propia instalación, el avance de bomba parece que falla, puede ser por la bomba o por mal ajuste y poco mas, fallos en el clima, sensor de temperatura experior pero ahí ni idea.
SALUDOS
Sí, los fallos de alarma y clima me parecen los típicos que nos salen a todos. Los raros son los que comentas.
Lo gracioso es que se le enciende la luz del abs pero el vagcom no entra en el modulo. Supongo que estará achicharrada da la centralita.
Emilio por casualidad no se le encenderá el testigo del ESP (El circulo con el coche dentro o algo asi) al ir en marcha y notara que tiene un pequeño bajoncito???
SALUDOS
Hola Emilio.
El mío que tiene todo el catálogo de fallos tiene esos síntomas también. La luz del ABS está siempre encendida y no puedo entrar al módulo con el vagcom. Cuando retuerzo un poco el módulo con el contacto puesto, se escucha el típico "trrrrrr" y se apaga la luz. Entonces sí puedo entrar con Vagcom y me sale el dichoso fallo de falta de comunicación....
Por lo visto, es por culpa del famoso fallo en estos módulos. Se sueltan unos cablecillos de aluminio de la placa y no conecta. Lo arreglan por 240 euros.
