dosega Publicado 6 de Octubre del 2013 Denunciar Publicado 6 de Octubre del 2013 VCDS Version: Release 805.0 Data version: 20080529 Sunday,06,October,2013,12:16:12:21461 Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 61 62 72 VIN: WAUZZZ4F15N055452 Mileage: 122620km/76192miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: Cannot be reached 1100 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door,Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 401 A HW: 4F0 907 401 A Component: 3.0L V6TDI G000AG 0020 Revision: --H01--- Serial number: Coding: 0011372 Shop #: WSC 66565 257 00032 3 Faults Found: 001025 - EGR System: Insufficient Flow P0401 - 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01110010 Fault Priority: 0 Fault Frequency: 240 Mileage: 90145 km Time Indication: 0 Date: 2012.07.16 Time: 05:54:38 Freeze Frame: RPM: 2163 /min Torque: 156.0 Nm Speed: 121.0 km/h Duty Cycle: 54.8 % Duty Cycle: 20.9 % Mass Air / Rev.: 575.8 mg/str Duty Cycle: 48.5 % 012597 - Intake Manifold Runner Control: Lower Stop not Reached P3135 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 254 Mileage: 90474 km Time Indication: 0 Date: 2012.07.16 Time: 10:23:19 Freeze Frame: RPM: 1176 /min Torque: 171.6 Nm Speed: 5.6 km/h Voltage: 13.38 V Duty Cycle: 88.8 % Duty Cycle: 80.9 % Duty Cycle: 80.9 % 013128 - Control Circuit for Controller for Turbocharger 1 (J724): Electrical Malfunction P3348 - 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 4 Mileage: 115680 km Time Indication: 0 Date: 2013.07.10 Time: 17:30:35 Freeze Frame: RPM: 1680 /min Torque: 280.8 Nm Speed: 40.3 km/h Temperature: 90.9°C Duty Cycle: 68.3 % Voltage: 13.60 V Duty Cycle: 12.6 % Readiness: 1 2 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F0 910 156 H HW: 09L 927 156 Component: AG6 09L 3.0lTDI RdW 0080 Revision: --H01--- Serial number: 0055816 Coding: 0000001 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 E HW: 4F0 614 517 A Component: ESP8 quattro H03 0010 Revision: 00000000 Serial number: 00000000000000 Coding: 0004488 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0220 Revision: 31050601 Serial number: 10600300071584 Coding: 0000003 Shop #: WSC 00317 572 87327 Part No: 4F0 910 131 E Component: FBSAUDIC6 EZS H43 0070 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: None Part No SW: 4F1 910 732 D HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 350IT047539525 Coding: 0030004 Shop #: WSC 00000 000 08192 Part No: 4F0 910 609 Component: Bedienteil MMIC6H07 0870 1 Fault Found: 00658 - Control Head 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 177 Mileage: 121754 km Time Indication: 0 Date: 2013.09.26 Time: 13:43:25 Freeze Frame: Bin. Bits: 001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 F Component: KLIMABETAETIGUNGH04 0110 Revision: 00000023 Serial number: 00000000061915 Coding: 0000150 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 B HW: 4F0 907 279 B Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0000101 Shop #: WSC 02335 785 00200 Part No: 4F1 910 113 Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 5 Faults Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01111110 Fault Priority: 2 Fault Frequency: 56 Reset counter: 137 Mileage: 147536 km Time Indication: 0 Date: 2009.10.07 Time: 21:38:00 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 9 Reset counter: 177 Mileage: 121552 km Time Indication: 0 Date: 2013.09.26 Time: 07:57:00 01495 - Bulb for High-Beams; Left (M30) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 47 Reset counter: 137 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:34:00 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 8 Reset counter: 177 Mileage: 121552 km Time Indication: 0 Date: 2013.09.26 Time: 07:57:00 01499 - Bulb for High-Beams; Right (M32) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 47 Reset counter: 137 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:34:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBD6016005 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655.lbl Part No SW: 4F0 910 655 D HW: 4F0 959 655 B Component: 33 AIRBAG AUDI8RH29 0250 Revision: 05H29000 Serial number: 0037LD044PLC Coding: 0013107 Shop #: WSC 00384 572 90104 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90022042650135 Coding: 0002041 Shop #: WSC 00233 572 96669 Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 900 S Component: KOMBIINSTR. M73 H09 0630 Revision: 00200000 Serial number: 4H+781R94 Coding: 0001143 Shop #: WSC 00233 572 96669 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 B Component: Gateway H09 0030 Revision: 09 Serial number: 08008049240182 Coding: 6CFE73C41B0104 Shop #: WSC 02325 785 00200 1 Fault Found: 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 132 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:33:31 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 C HW: 4F0 959 793 C Component: TSG FA H10 0020 Revision: 00000000 Serial number: –t$ Coding: 0000522 Shop #: WSC 02327 785 00200 1 Fault Found: 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 177 Mileage: 122626 km Time Indication: 0 Date: 2013.10.06 Time: 12:13:18 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 D HW: 4F0 907 289 D Component: Komfortgeraet H14 0090 Revision: 00900014 Serial number: 01000872110000 Coding: 0000133 Shop #: WSC 02335 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-AS.lbl Part No SW: 4F0 910 223 G HW: 4F0 035 223 Component: Amp.-ASK H09 0350 Revision: 15S00001 Serial number: 00809040029043 Coding: 0000008 Shop #: WSC 02335 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000021633 Coding: 0001003 Shop #: WSC 02323 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 792 C HW: 4F0 959 792 C Component: TSG BF H10 0020 Revision: 00000000 Serial number: $R$ Coding: 0000522 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 D HW: 4F0 907 801 B Component: EPB CEFC0090 H05 0090 Revision: --H05--- Coding: 0000321 Shop #: WSC 00315 781 75399 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 352IY047564188 Coding: 0000001 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H11 0490 Revision: 00000000 Serial number: 00000000061391 Shop #: WSC 00384 572 90104 Part No: 4F0 915 105 D Component: von VA0 1409130773 Coding: 344630393135313035442056413031343039313330373733 Shop #: WSC 00000 384 00290 No fault code found. ------------------------------------------------------------------------------- Address 62: Door,Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 795 A Component: TSG HL H09 0010 Coding: 0000002 Shop #: WSC 02327 785 00200 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 123 Reset counter: 137 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:33:29 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 794 A Component: TSG HR H09 0010 Coding: 0000002 Shop #: WSC 02327 785 00200 No fault code found. End --------------------------------------------------------------------- Responder
Miros Publicado 6 de Octubre del 2013 Denunciar Publicado 6 de Octubre del 2013 (editado) borra los fallos y mira si algunos vuelven aparecer. el primer fallo de la EGR tienes que limpiar el tubo -conducto que va del EGR hasta la mariposa. Editado 6 de Octubre del 2013 por Miros Responder
Tolo Publicado 6 de Octubre del 2013 Denunciar Publicado 6 de Octubre del 2013 Tendrás un inyector que pulveriza mal o no cierra bien. El gasoil se filtra por el cilindro y se mezcla con el aceite. Repáralo rápido o tendrás que cambiar el motor, el gasoil limpia las paredes y el cilindro trabaja sin engrase. Responder
MooCKye Publicado 6 de Octubre del 2013 Denunciar Publicado 6 de Octubre del 2013 Exacto si te sube el nivel de aceite es por que un inyector no cierra correctamente, lo raro es que no te de un fallo el vag y te indique que un inyector falla Responder
ximo@6 Publicado 6 de Octubre del 2013 Denunciar Publicado 6 de Octubre del 2013 si es por desgaste no dan fallo, porque realmente cierra y hace su función, el gasoil es filtrado por desgaste Responder
dosega Publicado 6 de Octubre del 2013 Autor Denunciar Publicado 6 de Octubre del 2013 Muchas gracias a todos mañana llevo el coche al taller. por cierto esto me da el vag com sobre los inyectores, a ver si podeis decirme cuales tengo mal gracias otra vez.- 077: -24 -8.0 -12.0 076: -28 -18 -16 075; -32 -22 -18 074; -14 -6 -8 073; -14 -10 -14 072; -48 -18 -22 imagino que estan mal, el coche anda perfecto ralentí estable, pero a ralentí si echa bastante humo Responder
ximo@6 Publicado 6 de Octubre del 2013 Denunciar Publicado 6 de Octubre del 2013 (editado) te contestado en el otro hilo, no hubiese hecho falta abrirlo , a lo poco que se mueven los post últimamente nada mas que se pone algo nuevo se esta leyendo ¿has borrado los fallos para ver los que se te quedan fijos? Editado 6 de Octubre del 2013 por ximo@6 Responder
dosega Publicado 6 de Octubre del 2013 Autor Denunciar Publicado 6 de Octubre del 2013 si, y quedan fijos gracias Responder
ximo@6 Publicado 6 de Octubre del 2013 Denunciar Publicado 6 de Octubre del 2013 algunos de los que tienes solo son bombillas fundidas Responder
Sardinero Publicado 8 de Octubre del 2013 Denunciar Publicado 8 de Octubre del 2013 Buenos días, Dosega: Por si te interesase: No estoy muy puesto en el uso del VagCom, así que no puedo leer - como sí hacen otros compañeros - los datos que proporcionas, pero, en relación con la subida del nivel de aceite, te comento que en coches con DPF, no solo de Audi sino también de otras marcas (si no es tu caso, olvida esto que te digo), se han observado ocasionalmente subidas del nivel de aceite, en algunos casos importantes, causadas por el paso del combustible al carter como consecuencia de las repetidas regeneraciones del DPF. En el foro hay cosas a este respecto. Un saludo, Responder
