Alguien puede ayudarme? el nivel de aceite sube solo
VCDS Version: Release 805.0
Data version: 20080529
Sunday,06,October,2013,12:16:12:21461
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
61 62 72
VIN: WAUZZZ4F15N055452 Mileage: 122620km/76192miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 A HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 66565 257 00032
3 Faults Found:
001025 - EGR System: Insufficient Flow
P0401 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 240
Mileage: 90145 km
Time Indication: 0
Date: 2012.07.16
Time: 05:54:38
Freeze Frame:
RPM: 2163 /min
Torque: 156.0 Nm
Speed: 121.0 km/h
Duty Cycle: 54.8 %
Duty Cycle: 20.9 %
Mass Air / Rev.: 575.8 mg/str
Duty Cycle: 48.5 %
012597 - Intake Manifold Runner Control: Lower Stop not Reached
P3135 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 254
Mileage: 90474 km
Time Indication: 0
Date: 2012.07.16
Time: 10:23:19
Freeze Frame:
RPM: 1176 /min
Torque: 171.6 Nm
Speed: 5.6 km/h
Voltage: 13.38 V
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
013128 - Control Circuit for Controller for Turbocharger 1 (J724): Electrical Malfunction
P3348 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 4
Mileage: 115680 km
Time Indication: 0
Date: 2013.07.10
Time: 17:30:35
Freeze Frame:
RPM: 1680 /min
Torque: 280.8 Nm
Speed: 40.3 km/h
Temperature: 90.9°C
Duty Cycle: 68.3 %
Voltage: 13.60 V
Duty Cycle: 12.6 %
Readiness: 1 2 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: --H01--- Serial number: 0055816
Coding: 0000001
Shop #: WSC 02327 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004488
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300071584
Coding: 0000003
Shop #: WSC 00317 572 87327
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: None
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350IT047539525
Coding: 0030004
Shop #: WSC 00000 000 08192
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
1 Fault Found:
00658 - Control Head
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 177
Mileage: 121754 km
Time Indication: 0
Date: 2013.09.26
Time: 13:43:25
Freeze Frame:
Bin. Bits: 001
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 F
Component: KLIMABETAETIGUNGH04 0110
Revision: 00000023 Serial number: 00000000061915
Coding: 0000150
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Shop #: WSC 02335 785 00200
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
5 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 2
Fault Frequency: 56
Reset counter: 137
Mileage: 147536 km
Time Indication: 0
Date: 2009.10.07
Time: 21:38:00
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 9
Reset counter: 177
Mileage: 121552 km
Time Indication: 0
Date: 2013.09.26
Time: 07:57:00
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 47
Reset counter: 137
Mileage: 121552 km
Time Indication: 0
Date: 2013.09.20
Time: 19:34:00
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 177
Mileage: 121552 km
Time Indication: 0
Date: 2013.09.26
Time: 07:57:00
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 47
Reset counter: 137
Mileage: 121552 km
Time Indication: 0
Date: 2013.09.20
Time: 19:34:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6016005
Shop #: WSC 00000 000 00000
Address 15: Airbags Labels: 4F0-910-655.lbl
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 33 AIRBAG AUDI8RH29 0250
Revision: 05H29000 Serial number: 0037LD044PLC
Coding: 0013107
Shop #: WSC 00384 572 90104
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90022042650135
Coding: 0002041
Shop #: WSC 00233 572 96669
Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 S
Component: KOMBIINSTR. M73 H09 0630
Revision: 00200000 Serial number: 4H+781R94
Coding: 0001143
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008049240182
Coding: 6CFE73C41B0104
Shop #: WSC 02325 785 00200
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 132
Mileage: 121552 km
Time Indication: 0
Date: 2013.09.20
Time: 19:33:31
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H10 0020
Revision: 00000000 Serial number: –t$
Coding: 0000522
1 Fault Found:
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 122626 km
Time Indication: 0
Date: 2013.10.06
Time: 12:13:18
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 D HW: 4F0 907 289 D
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000872110000
Coding: 0000133
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 15S00001 Serial number: 00809040029043
Coding: 0000008
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000021633
Coding: 0001003
Shop #: WSC 02323 785 00200
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H10 0020
Revision: 00000000 Serial number: $R$
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000321
Shop #: WSC 00315 781 75399
Address 55: Xenon Range
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352IY047564188
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000061391
Part No: 4F0 915 105 D
Component: von VA0 1409130773
Coding: 344630393135313035442056413031343039313330373733
Shop #: WSC 00000 384 00290
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000002
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 123
Reset counter: 137
Mileage: 121552 km
Time Indication: 0
Date: 2013.09.20
Time: 19:33:29
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000002
End ---------------------------------------------------------------------
borra los fallos y mira si algunos vuelven aparecer.
el primer fallo de la EGR tienes que limpiar el tubo -conducto que va del EGR hasta la mariposa.
Editado por Miros
Tendrás un inyector que pulveriza mal o no cierra bien. El gasoil se filtra por el cilindro y se mezcla con el aceite.
Repáralo rápido o tendrás que cambiar el motor, el gasoil limpia las paredes y el cilindro trabaja sin engrase.
Muchas gracias a todos mañana llevo el coche al taller.
por cierto esto me da el vag com sobre los inyectores, a ver si podeis decirme cuales tengo mal
gracias otra vez.-
077: -24 -8.0 -12.0
076: -28 -18 -16
075; -32 -22 -18
074; -14 -6 -8
073; -14 -10 -14
072; -48 -18 -22
imagino que estan mal, el coche anda perfecto ralentí estable, pero a ralentí si echa bastante humo
te contestado en el otro hilo, no hubiese hecho falta abrirlo , a lo poco que se mueven los post últimamente nada mas que se pone algo nuevo se esta leyendo
¿has borrado los fallos para ver los que se te quedan fijos?
Editado por ximo@6
Buenos días, Dosega:
Por si te interesase: No estoy muy puesto en el uso del VagCom, así que no puedo leer - como sí hacen otros compañeros - los datos que proporcionas, pero, en relación con la subida del nivel de aceite, te comento que en coches con DPF, no solo de Audi sino también de otras marcas (si no es tu caso, olvida esto que te digo), se han observado ocasionalmente subidas del nivel de aceite, en algunos casos importantes, causadas por el paso del combustible al carter como consecuencia de las repetidas regeneraciones del DPF. En el foro hay cosas a este respecto.
Un saludo,
