conde1.8t Publicado 27 de Octubre del 2013 Denunciar Compartir Publicado 27 de Octubre del 2013 amigos tengo los siguientes dramas que marca el auto todos ya los borre una vez y vuelven ah aparecer :/ VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 AC Component: 1.8L R4/5VT G 0002 Coding: 0004581 Shop #: WSC 66565 12 Faults Found: 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small P1290 - 002 - Lower Limit Exceeded 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation P1340 - 002 - Lower Limit Exceeded - Intermittent 17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High P1114 - 008 - Implausible Signal - Intermittent 17545 - Fuel Trim: Bank 1 (Add): System too Rich P1137 - 002 - Lower Limit Exceeded - Intermittent 16891 - Idle Control System RPM Higher than Expected. P0507 - 001 - Upper Limit Exceeded - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 008 - Implausible Signal - Intermittent 16687 - Cylinder 3 Misfire Detected P0303 - 008 - Implausible Signal - Intermittent 16688 - Cylinder 4 Misfire Detected P0304 - 008 - Implausible Signal - Intermittent 16686 - Cylinder 2 Misfire Detected P0302 - 001 - Upper Limit Exceeded - Intermittent 16683 - Boost Pressure Regulation: Control Range Not Reached P0299 - 002 - Lower Limit Exceeded - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 002 - Lower Limit Exceeded 16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 002 - Lower Limit Exceeded Readiness: 0000 0000 Address 02 ------------------------------------------------------- Controller: 01J 927 156 ET Component: V30 01J 1.8l5VT RdW 3011 Coding: 00001 Shop #: WSC 04926 1 Fault Found: 18265 - Load Signal: Error Message from ECU P1857 - 35-00 - - Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1729 Coding: 04499 Shop #: WSC 06435 3 Faults Found: 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-00 - - 00526 - Brake Light Switch-F 36-10 - Open Circuit - Intermittent 18265 - Load Signal: Error Message from ECU P1857 - 35-00 - - Address 08 ------------------------------------------------------- Controller: 8E0 820 043 K Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 3 Faults Found: 01809 - Actuating Motor for Temperature Flap: Left (V158) 41-10 - Blocked or No Voltage - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 01206 - Signal for Duration of Ignition: OFF 27-00 - Implausible Signal Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BC Component: Komfortgerát T3B 1110 Coding: 07790 Shop #: WSC 06324 18 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch: Passenger Side 35-00 - - 01331 - Door Control Module: Driver Side (J386) 53-10 - Supply Voltage Too Low - Intermittent 01811 - Supply Voltage for Door Controller: Drivers Side (J386) 37-10 - Faulty - Intermittent 01802 - Door Warning Lamp: Pass Side (W36) 57-10 - Electric Circuit Failure - Intermittent 01332 - Door Control Module: Passenger Side (J387) 53-10 - Supply Voltage Too Low - Intermittent 01812 - Supply Voltage for Door Controller: Pass. Side (J387) 37-10 - Faulty - Intermittent 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01333 - Door Control Module: Rear Left (J388) 53-10 - Supply Voltage Too Low - Intermittent 01813 - Supply Voltage for Door Controller: Rear Left (J388) 37-10 - Faulty - Intermittent 01804 - Door Warning Lamp: Rear Right (W38) 57-10 - Electric Circuit Failure - Intermittent 01334 - Door Control Module: Rear Right (J398) 53-10 - Supply Voltage Too Low - Intermittent 01814 - Supply Voltage for Door Controller: Rear Right (J389) 37-10 - Faulty - Intermittent 00935 - Electric Window Motor: Rear Right (V27) 62-10 - No or Incorrect Adjustment - Intermittent alguna orientacion porfavor estaria muy agradecido. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 27 de Octubre del 2013 Denunciar Compartir Publicado 27 de Octubre del 2013 yo le cambiaría las bujías lo primero que parece las tienes mal, después poco a poco si no van desapareciendo los errores seguiría con el caudalimetro, sonda lambda, ¿te marca bien la temperatura del motor? parece que tienes el sensor mal en cuanto al 46 asi por encima que saltas la alarma de vez en cuando y una bombilla fundida pero yo borraria y volveria a ver que sale Responder Enlace al comentario Compartir en otros sitios web More sharing options...
conde1.8t Publicado 28 de Octubre del 2013 Autor Denunciar Compartir Publicado 28 de Octubre del 2013 amigo muchas gracias por responder, hoy saque la tapa plastica del motor y habian unos cables sufurados (verdosos) y se estaban topando, los separe con cinta asiladora elecetrica, empezare con lo me dices y actualizo el tema con fotos, saludos y gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
