hola, me gustaria que me echarais una mano con una duda que tengo para codificar el cuadro en el modulo 17.
cuando entro en modulo 17 y le doy a coding me sale una ventana que es para seleccionar diferentes acabados, yo queria poner que es traccion quattro, como debo hacer?
CANAL 17
Coding
00??xxx: Options I
+00 = 1. K-Number (Europe/USA/Rest of World)
+01 = Smaller Fuel Tank Volume (All-Wheel-Drive)
+02 = Side Marker Lights Indicator Lamp inactive
+04 = 3. K-Number (Rental Cars)
+08 = 2. K-Number (Australia)
+16 = Clutch Pedal Switch Operation in FIS Display
00xx?xx: Country
0 = Germany (D)
1 = Rest of World (RoW)
2 = USA (US)
3 = Canada (CAN)
4 = Great Britain (GB)
5 = Japan (JP)
6 = Saudi Arabia
7 = Australia (AUS)
00xxx?x: AVISO DEL CINTURON
0 = No Seatbelt Warning
1 = Seatbelt Warning Europe-NCAP
2 = Seatbelt Warning USA and Canada (NAR old)
3 = Seatbelt Warning USA and Canada (NAR new)
4 = Seatbelt Warning Europe-NCAP (incl. passenger)
5 = Seatbelt Warning USA and Canada old (incl.pasajero)
6 = Seatbelt Warning USA and Canada NAR new (incl. passenger)
00xxxx?: Options II
1 = Standard (< 11/2006)
4 = Washer Fluid Warning inactive (11/2006 >)
8 = Washer Fluid Warning active (11/2006 >)
Adaptation Canal17
Channel 029: Tank Characteristic (Fuel Level Sensor 2)
Parallel shift of tank characteristic by +/- 32 Ohm. Only for Quattro models.
Standard Value: 128
Value Range: 96...160 (-8.0...+8.0 l)
Increments: 1 = 1 Ohm = 1/4 l
Channel 030: Tank Characteristic (Fuel Level Sensor 1)
Standard Value: 128
Channel 032: Tank Characteristic (Not detactable Tank Volume)
The tank volume which is not recordable by the fuel gauge sender(s).
Channel 033: Tank Characteristic (Full Calibration)
Non-parallel shift of the tank characterictic above a readout of 1/2. To start the adaptation enter '65535' as new value.
Standard Value: 128
Value Range: 112...144 (-4.0...+4.0 l)
Channel 034: Tank Characteristic (Dry Calibration)
Channel 035: Speed Threshold
This value represents the speed threshold for the dynamic oil pressure system. The threshold can be raised in increments of 250 RPM.
http://www.ross-tech.com/vcds/tour/screenshots/coding.png
segun esto tengo que sumar al valor que me salga en software coding +01. en mi caso me sale 09101 y tendria que poner 09111 es correcto?
Editado por Iñ@ki
  • 3 semanas más tarde...
para empezar tu coche es un A4 b67?
a ver tu tendrias que sumar ese 1 al nueve
por lo tanto si tu codificación es 09101 tendrías que poner 10101
te explico el XXXXX1 este uno siempre es uno
la siguiente XXXX0x esta cifra es para estados unidos por lo tanto tu debes dejarla a 0
la siguiente XXX1XX esta cifra corresponde al pais y España corresponde a resto del mundo 1
las dos siguientes X??XXX aqui es donde debes sumar ese uno y como tienes un 9 pasa a ser un 10
por lo que tu código queda así 10101
