Pues eso, desde hace dos días se me enciende la luz roja de la presión del aceite, al principio se encendía pitaba y después se quitaba. El nivel del aceite esta perfecto y el coche va ok, no hace nada anomalo...
A alguien se le ocurre algo???
Gracias
Sunday,29,December,2013,20:54:13:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: TRUZZZ8JX81048910 Mileage: 145770km/90577miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8J0 907 115 N HW: 8J0 907 115
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H3FNP0QW
Coding: 0113000318070060
Shop #: WSC 00191 264 15243
VCID: 377735054656A51
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8J0-614-517.lbl
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0017424
Shop #: WSC 01236 785 00200
VCID: EAD15C71C564489
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AF HW: 8J0 820 043 AF
Component: J255 Klima 1 Zone 0080
Revision: 00H08005 Serial number: 00000001089196
Coding: 1572868
VCID: 6AD1DC714564C89
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 13
Mileage: 137133 km
Time Indication: 0
Date: 2013.06.14
Time: 07:56:21
Freeze Frame:
Voltage: 14.30 V
Temperature: 23.0°C
(no units): 40.0
(no units): 31.0
Temperature: 21.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000008349477
Coding: A1060E8280141C004F1800001800000000095E075C210802000000000000
VCID: 458B4FCD0CBAC71
Subsystem 1 - Part No: 8J1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer AU354 H07 0070
Coding: 00064784
Shop #: WSC 01236
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -s Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K002N57N
Coding: 0011635
VCID: F9F3733DB0C2F31
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002011
VCID: 41835BDD1892EB1
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 930 E HW: 8J0 920 930 E
Component: KOMBIINSTR. VDO H23 0150
Revision: D0H23003 Serial number: 2243H003117125
Coding: 0004128
Shop #: WSC 80093 222 69422
VCID: 2E591061B90C649
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K084088060
Coding: E9801F061002024100
VCID: 346D020957204E9
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 15
Reset counter: 161
Mileage: 142588 km
Time Indication: 0
Date: 2013.08.07
Time: 11:29:46
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H23003 Serial number: AUX7Z0H3FNP0QW
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8J8 959 801 D HW: 8J8 959 801 D
Component: Tuer-SG H02 0060
Coding: 0004149
VCID: 3E792021696C949
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 8J1 909 143 C
Component: EPS_ZFLS Kl.157 H08 1903
VCID: 30650E19A338729
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Mileage: 145740 km
Temperature: 24.0°C
Voltage: 7.70 V
Voltage: 7.50 V
Address 46: Central Conv. Labels: 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H11 0080
Coding: 1890300201182D298505488AD677
VCID: 356B3F0D5C5A571
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
008 - Implausible Signal - Intermittent
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 B HW: 8J0 035 223 B
Component: J525 Amp Std H03 0120
Revision: 00H03001 Serial number: 93802005284406
Coding: 0106114
VCID: 234FF155E2CED91
Address 52: Door Elect, Pass. Labels: None
VCID: 55AB9F8DBC1A771
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 56: Radio
Cannot be reached
End ---------------------------------------------------------------------
Sunday,29,December,2013,20:58:58:32264
Chassis Type: 1K0
Address 01: Engine
Cannot be reached
Revision: 00H52001
Coding: 0017424
Coding: 1572868
Coding: 00064784
Shop #: WSC 01236
Coding: 0011635
Coding: 0002011
Coding: 0004128
Coding: 0004149
Coding: 0106114
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8J8 959 802 D HW: 8J8 959 802 D
Coding: 0004148
VCID: 3F875D256E669D1
Address 56: Radio
Cannot be reached
Todo apunta a un sensor en mal estado en su defecto la batería que esta en las últimas. Además, tienes varios fallos,¿tienes relenti inestable? Algunos errores son de este verano, ¿has probado hacer autoscan borrar fallos y volver a pasar el vagcom?
En efecto pueden ser del verano, me robaron las 4 ruedas y forzaron la cerradura, la radio se rompio y el circuito electrico debió fallar, asi que imagino que sera por eso.
Lo he llevado al taller y con el manometro los bares al ralenti estaban en 1 y al acelerar estaban bien, con lo que parece fallo del sensor.
Saludos y gracias
  • 1 mes más tarde...
