Taim Publicado 6 de Marzo del 2014 Denunciar Publicado 6 de Marzo del 2014 Hola, he pasado el vag 12.12 a mi coche y me dice esto, a ver que opinais: Thursday,06,March,2014,19:10:07:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 VIN: License Plate: xxxxx Mileage: 172550km-107217mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4B - Audi A6 C5 (1998 > 2006) Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67 75 76 77 Mileage: 172550km/107217miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 4B0 907 552 C Component: 2.4L V6/5V MOTR HS D03 Coding: 04102 Shop #: WSC 00981 VCID: 2541171FBF14DD36C75-49D8 3 Faults Found: 18010 - Power Supply Terminal 30 P1602 - 35-10 - Voltage too Low - Intermittent 17972 - Throttle Actuator (J338) P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent 17973 - Throttle Actuator (J338) P1565 - 35-10 - Lower Stop not Reached - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl Part No: 8E0 614 111 R Component: ABS/ASR 5.3 FRONT D12 Coding: 00064 Shop #: WSC 02315 VCID: 2D51EF3FE7E4E5760F5-5072 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl Part No: 4B0 820 043 F Component: A6-Klimavollautomat D52 Coding: 00060 Shop #: WSC 02324 VCID: 1D313FFF974415F69F5-2566 3 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 01841 - Potentiometer/Actuator for Temperature Flap; Left (G220) 30-10 - Open or Short to Plus - Intermittent 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI7.lbl Part No: 4B0 959 655 C Component: Airbag 7 Audi D02 Coding: 00104 Shop #: WSC 00000 VCID: 306FF64BF0D6889E243-5072 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-919-xxx-17.lbl Part No: 4B0 919 880 AX Component: C5-KOMBIINSTR. VDO D12 Coding: 05162 Shop #: WSC 00311 VCID: 820BEC838EFA4A0E027-5000 Subsystem 1 - Part No: IMMO Component: IDENTNR: AUZ7Z0X1059309 IMMO-IDENTNR: AUZ7Z0X1059309 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 4B0-962-258.lbl Part No: 4B0 962 258 B Component: Zentralverrieg.,DWA D16 Coding: 04618 Shop #: WSC 00311 VCID: 285F1E2BC806C05EFC3-4E42 8 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 00957 - Key 3 09-10 - Adaptation Limit Surpassed - Intermittent 00958 - Key 4 09-10 - Adaptation Limit Surpassed - Intermittent 01482 - Motors for Central Locking 29-00 - Short to Ground ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. DP2 Coding: 00001 Shop #: WSC 00000 VCID: E0CFC60B60B6F81E743-4A9C 5 Faults Found: 01377 - Ultra Sonic Sensor for Alarm System; Left (G170) 27-10 - Implausible Signal - Intermittent 01378 - Ultra Sonic Sensor for Alarm System; Right (G171) 27-10 - Implausible Signal - Intermittent 01381 - Alarm triggered by Anti-Theft Sensor; Rear Right 35-00 - - 01382 - Alarm triggered by Anti-Theft Sensor; Front Left 35-00 - - 01383 - Alarm triggered by Anti-Theft Sensor; Front Right 35-00 - - End --------------------------------------------------------------------- He probado a borrarlos y luego he arrancado y he encendido el aire en todas sus posiciones y he acelerado a ver, y luego lo he vuelto a pasar y dice que no hay fallos en nada, esperemos que fuese algo antiguo y puntual. ¿Que es eso de Redir Fail en Engine? Gracias! Responder
kumbas Publicado 7 de Marzo del 2014 Denunciar Publicado 7 de Marzo del 2014 Si buscas por google, puedes encontrar eso y mas: Pon redir fail vag com. :acute: Responder
Taim Publicado 8 de Marzo del 2014 Autor Denunciar Publicado 8 de Marzo del 2014 Si buscas por google, puedes encontrar eso y mas: Pon redir fail vag com. :acute: Gracias! Por esa regla de 3 no hace falta este foro.... Responder
