Es facil. Mete las dos en el coche y arranca. Luego sal del coche con una de ellas y deja la otra. Si el FIS te alerta de que no detecta la llave, la predominante es la que has sacado.
  • Respuestas 216
Jeje claro es con la llave confort o manos libres. Yo actualmente la llevo en el Megane CC y cuando meto las dos es una fiesta... y tengo que quitarle la pila a una de ellas porque o no arranca o a medio camino dice que no hay llave etc..
La llave predominante siempre es la de la mujer jejejeje. . (Sin ofender). A mí me aparece la radio y la temperatura cambiada.
son las que mandan en este mundo...
  • 1 mes más tarde...
Buenas;
Retomando anteriores comentarios, alguien sabe si es posible activar el drive select con vag-com?
Aunque sea cambiándolo desde el MMI.
Gracias y un saludo
Encontre esto en ross-tech, pero no me queda muy claro si lo a echo o no.
Ross-Tech Forums - Powered by vBulletin
A collective effort - coding Audi Drive Select on A3 8V
Thread: A collective effort - coding Audi Drive Select on A3 8V
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Tags: None
m_bolc said:
03-24-2016 11:43 PM
Being able to code-in ADS on my car has been an aspirational goal since mid 2014 when I got my first MQB A3. I gave up on that one because it was pretty basic, I was able to get the car how I wanted with just adjusting the steering weight in VCDS.
Now I have a better equipped car and would like to continue efforts to tweak ADS into the car. I've done quite a bit of tinkering and I will present my results here. My thinking is that these cars are relatively new still and we need more information, especially in those cases where the long coding helper has not been populated by the great people of Ross-Tech.
I failed to take a picture of the MMI, but I got a blank Audi Drive Select screen, i.e. it did not display Dynamic, Auto, Efficiency, Comfort or Individual - just a picture of the A3 in the middle, "Systems" on the bottom left, and "Individual settings" on the bottom right.
Curiously, the "joker" button on the steering wheel also had a new option for cycling the ADS profile.
Without further a do; here are the changes I made.
Code: [View]
Address 09:5Q0 937 084 AS recoded (Long Coding) from 04041A42C041227D03A04004B10807000000000000000000000000000000 to 04041A42C041227D07A04004B10807000000000000000000000000000000 (06385/790/00016)
I found a tick box in the log coding for central electronics. It was related to Driving Profiles. Enabling or disabling the bit did not populate or remove anything from the MMI.
Code: [View]
Address 44:5Q0 909 144 S recoded (ADP-Characteristic curve of steering assistance) from Dynamic to Driving profile selection button
Address 44:5Q0 909 144 S recoded (Long Coding) from 0502 to 8502 (06385/790/00016)
Here the adaptation change is pretty self explanatory. The coding change was also a tick box which was related to Driving Profiles.
Code: [View]
Address 5F:8V0 035 840 C recoded (ADP-(86)-Vehicle menu operation-menu_display_charisma) from not activated to activated
Address 5F:8V0 035 840 C recoded (ADP-(89)-Vehicle menu operation-menu_display_charisma_standstill) from not activated to activated
Address 5F:8V0 035 840 C recoded (ADP-(45)-Vehicle function list BAP-charisma_0x17) from not activated to activated
These three adaptations are what enabled the ADS menu on the MMI, alas with no content.
Now, I'm looking for scans from cars that do have ADS. Preferably from S-tronic A3s without magnetic ride.
Photos to illustrate what my results have been will be added to the thread possibly tomorrow, that way you'll be able to see that the last thing pending is to "populate" the ADS screen within the MMI with the different driving profiles.
Scan for reference
Code: [View]
Thursday,24,March,2016,20:28:01:29892
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.3.0.0 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: WAUZZZ8V7H1000288 License Plate: TRS456
Mileage: 552km-342mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7H1000288 Mileage: 552km-342miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CYVB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 GR HW: 04E 907 309 BL
Component: R4 1.2l TFS H23 2394
Revision: R4H23---
Coding: 02250012230400082000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
ROD: EV_ECM12TFS01104E906027GR.rod
VCID: 7AFBDCC3FDAB9DECE1-802E
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 048 K HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0614
Revision: 00005005 Serial number: CU501512106812
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
VCID: 4487623BCFEF1B1CCB-8010
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 63625000001935
Coding: 13F16AA22420126C0179060841CB25C8562448806082A4B2002100348208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 79F9C3CFF8AD96F4E8-802C
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 D HW: 8V0 820 047 D
Component: AC Manuell el H11 0052
Revision: 20021000 Serial number: 00000000187281
Coding: 03000004100000000000000000000000
ASAM Dataset: EV_AirCondiFrontManAU37X 008018
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 377D05F78E3940845E-8062
1 Fault Found:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 436 km
Date: 2016.03.22
Time: 19:28:12
Voltage terminal 30: 12.0 V
Compressor shut-off requirement: Shut-off from Engine Control Module (ECM) via CAN
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061533701281
Coding: 04041A42C041227D03A04004B10807000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_VW37.rod
VCID: 0919B30FA84D8674F8-805C
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 151118 043 0585
Serial number: 151126161111
Coding: 0A47F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 D HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0004
Serial number: 50030281
Coding: 06885D
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
Component: E1 - LDS MQB H05 0032
Serial number: 17 10 2015 00000327
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY153154N42
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000064431957
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39291534203226
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002024
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3C771ADBB71F63DCB3-8068
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 015 0388
Serial number: 003MMR1BC5J-
Coding: 98CCC000000000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 000FAE2B9B77C73CAF-8054
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 001 812 15
Component: SideSensor_Df 001 0887
Serial number: 357670000001F741381P
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 812 15
Component: SideSensor_Pf 001 0887
Serial number: 358670000007A741381R
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 811 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502B11E34435E21%
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 403 011 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502C91E2431261B3
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 509 15
Component: FrontSensor_D 001 6149
Serial number: 3556502C71CF2D82920N
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 EM HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 10121504221033
Coding: 8018
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_AU37.rod
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 860 N HW: 8V0 920 860 N
Component: KOMBI H03 6423
Coding: 07841A082B8000080500BA001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 45817F3FC4D52214DC-8010
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 10121510800534
Coding: 01010008300864005B000208100B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti.rod
Generator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 11 12 2015 A0038721
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 181015BJH00562
Coding: 00100A204100040000001002
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 41896B2FD0FD0E34E0-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000008171337
Coding: 110000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0502
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_VW37.rod
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 111015BJA06371
Coding: 001002204D00040000001002
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 408F6E2BDBF7073CEF-8014
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000008176200
Coding: 090000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 010A000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E1CFFFD4B5F2948C-8020
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 840 C HW: 8V0 035 840 B
Component: MU-S--ER 042 0461
Serial number: A3E01212150142
Coding: 01730100FF0A000021220001001A00002F0001040100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE_AU37.rod
VCID: 35610FFF9435B2944C-8060
Seat Adjustment Driver Side:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30F2K3
Sound System:
Subsystem 2 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: ALJAL111111500010126
End-------------------------(Elapsed Time: 03:37)--------------------------
NEtech said:
03-25-2016 02:58 AM
It looks like it is done with SWaP.
Part number 8V0 063 765, Activation code and wires.
Car with PR-2H6, has also Bits in Byte 15 activated, but SWaP is needed, is my best guess.
155 euro, additional online activation.
PS Uwe, adding SWaP (Software as Product) as "short hoover"!
Uwe's Avatar
Uwe said:
03-25-2016 08:33 AM
Quote Originally Posted by NEtech View Post
Done!
-Uwe-
Ceterum censeo, delenda est Daesh.
m_bolc said:
03-26-2016 09:57 PM
So this means that without SWaP the tweak is not possible?
andyvee's Avatar
andyvee said:
03-27-2016 02:59 PM
Pretty much - the below Adaptation IDs on 19 and 5F might help if you are a genius, very brave, and can afford a new CAN Gateway and MIB unit
$3C00 = Status_of_all_existing_FS-IDs_in_the_ECU
$3C0A = SWaP_individualization_feature
Octavia 3 VCDS Adaptations
Editado por dpa3
