angelillo2 Publicado 9 de Abril del 2014 Denunciar Publicado 9 de Abril del 2014 ESTE ES EL CODIGO DE ERROR QUE ME DA Y SE ENCIENDE LA LUZ AMARILLA. HACE COMO DOS MESES LE CAMBIE LA PALOMILLA DE ADMISION, Y HACE COMO UN AÑO ME LIMPIARTOSN LA EGR Y ME DIJERON QUE ESTABA BIEN LE QUITO EL ERROR Y A LOS POCOS DIAS ME SALTA OTRA VEZ, PERO EL COCHE VA BIEN ME PASA CUANDO LLEVO UN RATO A 100-120 kM/H Y A 1900-2100 RPM Y CON CONTROL DE VELOCIDAD SIN TOCAR EL ACELERADOR, ES DECIR CUNADO EL COCHE VA ABURRIDO A VER SI ME PODEIS DECIR QUE PUEDFE SER ESTO?? ES CONVENIENTE ANULAR LA EGR?? GRACIAS FOREROS VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Control Module Part Number: 4F0 910 402 D HW: 4F0 907 401 C Component and/or Version: 3.0L V6TDI G000AG 0020 Software Coding: 0011372 Work Shop Code: WSC 75757 258 178224 VCID: 1E3338FAC917D8EE86F-804B 1 Fault Found: 001025 - EGR System P0401 - 002 - Insufficient Flow - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 0 Fault Frequency: 4 Reset counter: 255 Mileage: 161105 km Time Indication: 0 Date: 2014.04.07 Time: 14:48:27 Freeze Frame: RPM: 1911 /min Torque: 152.1 Nm Speed: 107.5 km/h Duty Cycle: 76.7 % Duty Cycle: 20.9 % (no units): 0.0 Duty Cycle: 14.2 % Readiness: 0 1 0 X 0 Responder
