Que tal compañeros, necesito que por favor me echéis un cable con unos fallos del A5 de una amiga que le salen al meter el vagcom.
Estos son los fallos...
Address 01: Engine (J623-CAMA) Labels: 059-907-401-CAP.clb
Part No SW: 8K1 907 401 HW: 8K0 907 401
Component: 2.7TDI EDC17 H01 0005
Revision: --H01---
Coding: 0114002C02070128
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM27TDI8K1907401 A01005
ROD: EV_ECM27TDI8K1907401.rod
1 Fault Found:
5231 - Fuel Rail/System Pressure: Too Low
P0087 00 [036] - Cannot Be Tested at this Time
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 20
Mileage: 182035 km
Date: 2014.04.29
Time: 18:43:38
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0253
Revision: 00002001
Coding: 010000
Shop #: WSC 06435 000 00000
Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H34 0050
Part No SW: 8K0 905 852 A HW: 8K0 905 852 A
Component: ELVAUDIB8 H33 0039
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 181149 km
Time Indication: 0
Date: 2014.04.04
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0106187303
Coding: 0100068000390400012000
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 181149 km
Time Indication: 0
Date: 2014.04.04
Time: 18:00:55
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 181149 km
Time Indication: 0
Date: 2014.04.04
Time: 18:33:56
Gracias de antemano!!!
:thumbsup: :thumbsup: :thumbsup:
Editado por Dr. West
El primero es claro. Falta de presion en la entrada de combustible en el common rail. Ha cambiado alguna vez el filtro de gasoil? Si es asi, y no nota nada raro al conducir no se de que sera.
El segundo, le falta gas en el aire acondicionado o bien le falla una valvula. Sale el aire frio? A mi me dejaba de salir aire frio al cabo de 1 hora de viaje con un error como ese.
El tercero es del famoso motor de la tapa del deposito de combustible que no cierra o no abre. Cambiar el motor, creo que habia una campaña en audi.
  • 9 meses más tarde...
me podrias decir que fue al final este fallo?
esque me acaba de salir esta tarde
gracias
Si pues al final la bomba del gasoil le fallaba, y la sustituyó por una de las recuperadas o reparadas.. Creo recordar que la broma le salió por unos 800-900 euros.
gracias
ok muchisimas gracias
de momento le cambie el filtro de gasoil y no a vuelto a salir.
pero lo tendre en cuenta
