Hola chicos, hoy he conectado por primera vez el cable al coche. El problema es que me salen muchos fallos y nose si son verdaderos o no. Cuelgo el documento aver si hay alguien que sepa mas y me lo lea. Muchas Gracias!
Saturday,17,May,2014,16:33:53:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8K0AA073692 License Plate:
Mileage: 114300km-71022mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 72
VIN: WAUZZZ8K0AA073692 Mileage: 114300km/71022miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGB) Labels: None
Part No SW: 03L 906 022 MM HW: 03L 906 022 B
Component: R4 2,0L EDC H01 8440
Revision: 11H01---
Coding: 0104002C02072118
Shop #: WSC 01028 202 08193
ASAM Dataset: EV_ECM20TDI03L906022MM A01006
ROD: EV_ECM20TDI03L906022C.rod
VCID: 7CF7127BF71EBCFEC8B-8029
13 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
4914 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [040] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 113822 km
Date: 2014.05.16
Time: 17:49:20
5182 - Particulate Trap Bank 1
P2002 00 [108] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Mileage: 113676 km
Date: 2014.04.20
Time: 16:23:07
4799 - Mass Air Flow Sensor (G70)
P0102 00 [040] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 113797 km
Date: 2014.04.27
Time: 13:14:31
5380 - Valve for Air Filter Bypass Flap (N275)
P1016 00 [096] - Open Circuit
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [032] - Short to GND
7136 - No Communication with ABS Brake Control Module
U0121 00 [032] - -
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [032] - -
4710 - No Communications with Airbag Control Module
U0151 00 [032] - -
4713 - No Communication with ABS Brake Control Module
U0121 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 113635 km
Date: 2014.04.13
Time: 12:56:21
4714 - Steering Column Control Module
U0212 00 [032] - No Communications
5162 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [096] - Implausible Signal
Readiness: 0 3 0 0 0
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K0 927 155 AF HW: 0AW 927 156 H
Component: 0AW 20TDI RdW H03 0007
Revision: --H03--- Serial number: 0000000011
Coding: 000002
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A02006
ROD: EV_TCMVL381.rod
VCID: 77FD0D57CE389FA6A59-8022
7 Faults Found:
2251 - Shift Lock Solenoid (N110)
P1761 00 [044] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 112464 km
Date: 2013.12.01
Time: 15:22:40
2264 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 112464 km
Date: 2013.12.01
Time: 15:22:40
2265 - No Communication with ABS Brake Control Module
U0121 00 [044] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 113635 km
Date: 2014.04.13
Time: 12:56:21
4323 - Signal Line for Tiptronic
P1890 00 [044] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 112464 km
Date: 2013.12.01
Time: 15:22:40
5676 - Steering Column Control Module
U0212 00 [044] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 112464 km
Date: 2013.12.01
Time: 15:48:13
5677 - No Communications with Steering Angle Sender (G85)
U0126 00 [044] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 112464 km
Date: 2013.12.01
Time: 15:48:13
7066 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 112464 km
Date: 2013.12.01
Time: 15:48:13
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK
Component: ESP8 front H04 0070
Revision: -------- Serial number: --------------
Coding: 170500
VCID: 820BEC831DFA4A0E027-80D7
4 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 46
Mileage: 112464 km
Time Indication: 0
Date: 2013.12.01
Time: 15:47:39
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0025
Hex Value: 0x46AA
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 46
Mileage: 112464 km
Time Indication: 0
Date: 2013.12.01
Time: 15:47:40
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x22A2
Hex Value: 0x002E
Hex Value: 0x02A1
Hex Value: 0x00FF
01200 - ABS Valves Supply Voltage
000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:55:54
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x02A0
Hex Value: 0x0002
Hex Value: 0x8191
Hex Value: 0x00FF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:52
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x2280
Hex Value: 0x0032
Hex Value: 0x1D8E
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 010200
VCID: 8109E38F18FC51161BD-80D4
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:22
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0171
Revision: A1000000 Serial number: 01131020091071
Coding: 34100000
VCID: 7DF11F7FE404B5F6FF5-8028
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000365551
Coding: 260050914034AF000001000300001D0D001C470800010101000000
VCID: 3C77D27BBF9E7CFE88B-8069
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 081009 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
9 Faults Found:
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:57:00
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 13:03:00
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 52
Mileage: 103690 km
Time Indication: 0
Date: 2013.06.22
Time: 05:22:00
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 2
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:57:00
00926 - Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:00
03123 - Terminal 30 - 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:57:00
03124 - Terminal 30 - 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:00
00576 - Terminal 15
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 46
Mileage: 112464 km
Time Indication: 0
Date: 2013.12.01
Time: 15:23:00
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:55:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39930928404792
Coding: 000103
VCID: 3E73D873A9826EEEA6F-806B
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD04SJ4E
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4189A38FD07C1116DBD-8014
Crash sensor for side airbag; driver side:
Serial number: 6334MSME4C4452015
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME4C4452319
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME013E4F1CR
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME583E4108L
Crash sensor for front airbag; driver side:
Serial number: 63732SME793E4F36H
Crash sensor for front airbag; passenger side:
Serial number: 63832SME7B3E3310%
2 Faults Found:
13636864 - Control Module for ABS Brakes
U1015 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Date: 2014.04.13
Time: 12:56:21
12658176 - No Communications with Steering Angle Sender (G85)
U0126 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 112464 km
Date: 2013.12.01
Time: 15:48:13
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IJD00068
Coding: 000017
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H02 0003
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:21
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 D HW: 8K0 920 930 D
Component: KOMBIINSTR. H20 0255
Revision: 00000000 Serial number: CIY5358A9
Coding: 0F06100002000008010000
VCID: 2E53E83379E29E6E36F-807B
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:22
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:53
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E09A09807E
Coding: 00C303
VCID: 52AB9CC30D1A9A8E727-8007
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
4 Faults Found:
03041 - Energy Management Active
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 40
Reset counter: 55
Mileage: 112414 km
Time Indication: 0
Date: 2013.11.14
Time: 03:29:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.20 V
Count: 17
01771 - Control Module for Headlight Range (J431)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 6
Mileage: 112464 km
Time Indication: 0
Date: 2013.12.01
Time: 15:48:15
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.40 V
Count: 6
Bin. Bits: 10011
Time: 0.40 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:22
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.30 V
Count: 6
Bin. Bits: 10011
Time: 15.50 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:52
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.30 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000102055140
Coding: 011002204000410001
VCID: 479DBD97F6582F26159-8012
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:55:56
Address 46: Central Conv. Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
Component: TSG BF H11 0306
Revision: Serial number: 0000102022296
VCID: 4683B093F152362EEEF-8013
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000474768
Shop #: WSC 00000 000 00000
VCID: 3467FA5B97CEB4BE40B-8061
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:52
Freeze Frame:
Voltage: 11.60 V
Count: 67
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:21
Freeze Frame:
Voltage: 11.60 V
Count: 65
Hex Value: 0x0263
Hex Value: 0x0081
Hex Value: 0x1010
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 112464 km
Time Indication: 0
Date: 2013.12.01
Time: 15:48:12
Freeze Frame:
Voltage: 11.60 V
Count: 48
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 112464 km
Time Indication: 0
Date: 2013.12.01
Time: 15:47:40
Freeze Frame:
Voltage: 13.10 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Xenon Range
Cannot be reached
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H45 0020
Revision: AB001007 Serial number: 341JZ097654542
Coding: 010003020000000001
VCID: 1C3732FB1F5E1CFE68B-8049
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 666 D HW: 8T1 035 666 D
Component: H-BN-EU H41 0047
Revision: -------- Serial number: 483J5097550958
Coding: 01010001000681ED01000B1E000000030001
VCID: 3B75D167BA907BC6811-806E
Subsystem 1 - Part No: 8R0 060 884 E
Component: EUR 2009/2010 5805
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:56:22
Freeze Frame:
Bin. Bits: 00000000 01100000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102094475
Coding: 010002204000210001
VCID: 428BAC83DD7A0A0EC27-8017
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 46
Mileage: 113635 km
Time Indication: 0
Date: 2014.04.13
Time: 12:55:56
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102094472
End ---------------------------------------------------------------------
Hola! Me parecen muchos errores, creo que he contado 14 malfunction. Yo te diría que le des a borrar los fallos y realices otro autoscan, deberían quedarse solo alguno de ellos, y de los que queden ya vemos qué son.
Has desconectado la batería recientemente? Tantos errores pueden ser debido a ello. Borra los errores y escanea de nuevo, verás como disminuyen. A veces hay que repetir el proceso varias veces y los que te queden permanentes ya te los tomas más en serio
Fui a cambiar el aceite multitronic. Alomejor los chicos del taller han desconectado la bateria. He borrado todo y me salen solamente 3. De los xenon y otras cosas k no me acuerdo. Pero el motor y lo demas todo bien.
Enviado desde mi LT18i mediante Tapatalk
Entonces seguramente desconectaron la batería. En cuanto al xenón haz el autoscan con la llave de luces en modo auto o encendidas ya verás como se quita. Sí tienes una puerta abierta también suele dar fallo y abs y esp también lo dan casi siempre (creo que con motor arrancado no, pero no estoy seguro ahora).
