Elenafael Publicado 1 de Julio del 2014 Denunciar Publicado 1 de Julio del 2014 El otro día con un amigo que tiene un A6 2.0 TDI tiptronic del 2005 y que se le había encendido la luz con el motorcillo amarillo, le pasé el VAG COM y me salió esto: Sunday,29,June,2014,19:32:36:10074 VCDS Version: Release 10.6.4 Data version: 20110418 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62 72 76 VIN: Mileage: 52330km/32516miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 03G 906 016 GC HW: 03G 906 016 GC Component: R4 2,0L EDC G000CG 9642 Revision: --H02--- Serial number: Coding: 0000076 Shop #: WSC 00000 785 00200 VCID: 6ADFC69B3CEF 5 Faults Found: 001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal P0471 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 2 Fault Frequency: 12 Time Indication: 0 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h (no units): -45.90 (no units): 10.20 Mass Flow: 0.00 g/s Temperature: 198.0°C Temperature: 12.6°C 009299 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal P2453 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 2 Fault Frequency: 6 Time Indication: 0 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h (no units): -15.30 (no units): 5.10 Mass Flow: 0.00 g/s Temperature: 228.0°C Temperature: 10.8°C 008194 - Particulate Trap Bank 1: Efficiency Below Threshold P2002 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 2 Fault Frequency: 1 Mileage: 51947 km Time Indication: 0 Date: 2014.03.11 Time: 13:37:15 Freeze Frame: RPM: 1764 /min Speed: 92.0 km/h (no units): 0.00 (no units): 5.10 Mass Flow: 46.93 g/s Temperature: 402.0°C Temperature: 21.6°C 009263 - Diesel Particulate Filter (Bank 1): Restricted/Clogged P242F - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 1 Mileage: 51997 km Time Indication: 0 Date: 2014.04.15 Time: 12:26:34 Freeze Frame: RPM: 1071 /min Speed: 25.0 km/h (no units): 0.0 Duty Cycle: 75.0 % (no units): 86.70 Temperature: 20.7°C Time: 499.2 s 006275 - Park/Neutral Switch: Implausible Signal P1883 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 1 Fault Frequency: 1 Mileage: 52077 km Time Indication: 0 Date: 2014.06.22 Time: 13:12:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 13.68 V Bin. Bits: 00101011 Bin. Bits: 0 (no units): 97.0 Readiness: 1 2 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 4F2 910 155 H HW: 01J 927 156 JG Component: V30 01J 2.0l PD RdW 0010 Revision: --H03--- Serial number: 00000000000010 Coding: 0000001 Shop #: WSC 02325 785 00200 VCID: 295DF997F969 1 Fault Found: 001815 - Transmission Input Speed Sensor (G182): No Signal P0717 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 1 Mileage: 51977 km Time Indication: 0 Date: 2014.03.18 Time: 07:56:30 Freeze Frame: RPM: 864 /min RPM: 120 /min (no units): 13.0 Torque: -4.0 Nm Temperature: 32.0°C T.B. Angle: 0.0° Bin. Bits: 0101 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T Component: ESP8 front H01 0070 Revision: 00000000 Serial number: 00000000000000 Coding: 0020856 Shop #: WSC 02325 785 00200 VCID: 65C5B5A7D5F1 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0220 Revision: 31050601 Serial number: 10601100586810 Coding: 0000003 Shop #: WSC 02323 785 00200 VCID: E3C12BBF5BC5 Part No: 4F0 910 131 E Component: FBSAUDIC6 EZS H45 0080 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: Redir Fail! Part No SW: 4F0 910 769 G HW: 4F0 035 769 A Component: MMI Cockpit H35 0410 Revision: C61060DE Serial number: AUZ6Z3FB3342L3 Coding: 0544104 Shop #: WSC 02335 785 00200 VCID: 316D11F7D1B9 Part No: 4F0 910 609 E Component: Bedienteil MMIC6H02 0060 2 Faults Found: 01327 - Control Module for Parking Aid (J446) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Mileage: 52061 km Time Indication: 0 Date: 2014.04.22 Time: 13:21:49 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 1 Mileage: 35105 km Time Indication: 0 Date: 2011.01.17 Time: 18:06:46 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 T Component: KLIMABETAETIGUNGH20 0170 Revision: 00000031 Serial number: 00000000321162 Coding: 0008212 Shop #: WSC 02325 785 00200 VCID: DBB1135F63B5 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 L HW: 4F0 907 279 B Component: ILM Fahrer H15 0240 Revision: 00000000 Serial number: 4F0907279 Coding: 0000101 Shop #: WSC 02335 785 00200 VCID: 326F1EFBD4BF Part No: 4F1 910 113 C Component: Wischer AudiC6 H05 0210 Coding: 00064784 Shop #: WSC 02335 Part No: 4E0 910 557 A Component: REGENLICHTSENSORH13 0090 Coding: 00146221 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: Redir Fail! Part No SW: 4F0 910 769 G HW: 4F0 035 769 A Component: MMI Cockpit H35 0410 Revision: C61060DE Serial number: AUZ6Z3FB3342L3 Coding: 0544104 Shop #: WSC 02335 785 00200 VCID: 316D11F7D1B9 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 E HW: 4F0 959 655 B Component: 43 AIRBAG AUDI8RH29 0280 Revision: 08H29000 Serial number: 0037LD0HHRW8 Coding: 0013363 Shop #: WSC 02325 785 00200 VCID: 295DF997F969 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H08 0230 Revision: 00H08000 Serial number: 90026062840353 Coding: 0002041 Shop #: WSC 02323 785 00200 VCID: E6C732ABA8F7 Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 C HW: 4F0 920 901 C Component: KOMBIINSTR. M73 H12 0120 Revision: 00400000 Serial number: 58U71U0C6 Coding: 2304148 Shop #: WSC 04561 572 108335 VCID: 204BE4B38A53 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 1300806A318340 Coding: ECFE53C41B0104 Shop #: WSC 02334 785 00200 VCID: 2759FFAFEF7D No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: VCID: 55A585678591 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H22 0170 Revision: 01700022 Serial number: 01023833040000 Coding: 0001157 Shop #: WSC 02335 785 00200 VCID: 2E570A8BC087 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4F0 910 223 H HW: 4F0 035 223 K Component: Amp.-ASK-RD H07 0130 Revision: 07S00000 Coding: 080000 Shop #: WSC 02399 823 56573 VCID: 2341EBBF9B45 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 4 Fault Frequency: 2 Reset counter: 115 Mileage: 35105 km Time Indication: 0 Date: 2011.01.18 Time: 08:54:38 Freeze Frame: Voltage: 12.00 V Temperature: 12.0°C Bin. Bits: 00000011 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000187232 Coding: 0001004 Shop #: WSC 02323 785 00200 VCID: DEB71A4B70A7 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 792 E Component: TSG BF H12 0120 Revision: 00000000 Serial number: ft Coding: 0000522 Shop #: WSC 02327 785 00200 VCID: 2C530083F69B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 C HW: 4F0 907 801 A Component: EPB CDEC0080 H04 0080 Revision: --H04--- Coding: 0000131 Shop #: WSC 00000 785 00200 VCID: 204BE4B38A53 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: Redir Fail! Part No SW: 4F0 910 769 G HW: 4F0 035 769 A Component: MMI Cockpit H35 0410 Revision: C61060DE Serial number: AUZ6Z3FB3342L3 Coding: 0544104 Shop #: WSC 02335 785 00200 VCID: 316D11F7D1B9 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: J0644 BEM H12 0590 Revision: 00000000 Serial number: 00000000123903 Shop #: WSC 04561 572 68279 VCID: 2341EBBF9B45 Part No: 4F0 915 105 C Component: von VA0 2611020034 Coding: 344630393135313035432056413032363131303230303334 Shop #: WSC 00000 384 00290 2 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 6 Mileage: 35105 km Time Indication: 0 Date: 2011.01.18 Time: 09:12:04 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 4 Time Indication: 0 Date: 2011.01.18 Time: 09:32:53 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 F HW: 4F0 959 795 F Component: TSG HL H21 0050 Coding: 0000002 Shop #: WSC 02327 785 00200 VCID: 2F69178FC78D No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 F HW: 4F0 959 794 F Component: TSG HR H21 0050 Coding: 0000002 Shop #: WSC 02327 785 00200 VCID: 2F69178FC78D No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 F HW: 4F0 919 283 F Component: Parkhilfe 4-Kan H09 0060 Revision: 00H09000 Serial number: 06230630602525 Coding: 0001006 Shop #: WSC 02323 785 00200 VCID: 2759FFAFEF7D No fault code found. End --------------------------------------------------------------------- Mi ingles no es mujy bueno y mi conocimiento del VAG muy limitado. Os pediria, a los gurus del foro; una traducción para saber cual es el problema que tiene mi amigo. Por lo que he leido creo que es algo de la regeneración incompleta del DPF, el filtro de particulas. Voy bien, o equivocado... Gracias de antemano. Responder
tecnalux Publicado 1 de Julio del 2014 Denunciar Publicado 1 de Julio del 2014 Vas bien con lo del filtro de partículas, se ve que tiene 9 años y muy pocos km por lo que deduzco que hace mucha ciudad. Mete el coche en carretera y pisale por encima de los limites legales, o en su defecto si no es automatico hazlo que revolucione en 3ª o 4ª velocidad. La idea es que el escape coja suficiente temperatura y que queme toda la "m****" acumulada; por lo demás, también aparece un fallo en el sensor de aparcamiento. Mi consejo es que después de haber hecho lo de calentar, borres los fallos y hagas una nueva diagnosis a ver cual de ellos vuelve a aparecer. De todas formas si solucionas lo del filtro de partículas, se apagara la "cafetera" por que esa no se enciende por el fallo de lo del parking. Si me equivoco, que algún forero me corrija. Un saludo. Responder
Elenafael Publicado 1 de Julio del 2014 Autor Denunciar Publicado 1 de Julio del 2014 Es automático. Y si, hace muy pocos kilómetros. Me comentó que este año la ultima vez que le echo gasoil fue en febrero, antes de este fin de semana. Lo utiliza muy poco. Pero me extraña lo de que no hizo el ciclo ya que vino dándole cera de Sevilla hasta Huelva, donde nos vimos. En fin le diré que lo fuerce un poco más. Responder
audi a6 2.0tdi Publicado 1 de Julio del 2014 Denunciar Publicado 1 de Julio del 2014 echale un liquido al gasoil que eleva temperatura de gases escape y se te acabara problema. salu2 Responder
tecnalux Publicado 2 de Julio del 2014 Denunciar Publicado 2 de Julio del 2014 Si tu amigo es de Sevilla, podíamos vernos si quiere, yo tb soy de Sevilla............ Responder
ximo@6 Publicado 2 de Julio del 2014 Denunciar Publicado 2 de Julio del 2014 que si es automático no hace falta que lo pase de los limites legales, automático también tiene una posición manual en la que se puede subir el coche de revoluciones sin pasarse de velocidad permitida pero yo borraría los fallos y volvería a scanear para saber con mas seguridad lo que falla Responder
Elenafael Publicado 2 de Julio del 2014 Autor Denunciar Publicado 2 de Julio del 2014 Gracias a todos por vuestras respuestas. Responder
tecnalux Publicado 2 de Julio del 2014 Denunciar Publicado 2 de Julio del 2014 Ximo, el mio es un 3.0 tiptronic y en la posición manual si le piso y no cambio yo, ya cambia el solo. También si por ejemplo el coche va en manual en 3ª velocidad y paro en un semáforo, el solo cambia a 1ª para salir estando en manual. Son protecciones que trae pienso yo para que no hagamos el burro. Responder
ximo@6 Publicado 9 de Julio del 2014 Denunciar Publicado 9 de Julio del 2014 vamos a ver a que revoluciones quieres conducirlo tu? es que si le pisas a tope es normal que el coche cambie si no cambiara el cambio estaría mal, pero si subes revoluciones poco a poco el coche detecta que quieres ir alto de vueltas y no cambia, a no ser que le pises a reventar el motor por el contrario hacia abajo conforme le van faltando vueltas al motor le quita marchas para evitar que se cale yo mi coche es un multitronic y su funcionamiento es así tal como describo y un amigo que tiene un tiptronic es igual, la única diferencia de entre uno y otro es que el mio mantiene siempre las revoluciones igual mientras sube de velocidad y el suyo varían por ser una caja de cambios con engranajes dejemos el quattro aparte Responder
