albertoavant Publicado 4 de Agosto del 2014 Denunciar Compartir Publicado 4 de Agosto del 2014 hola compañeros hoy le pasado el vag a un amiguete y le a salido estos fallos, la mayoria estan controlados pero algunoas os lo marco en rojo para que me echeis una mano, por cierto me salen dos kilometrajes diferentes eso puede ser? gracias Monday,04,August,2014,19:23:38:55062 VCDS Version: Release 11.11.4 Data version: 20120807 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8T0 Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72 VIN: WAUZZZ8K39N058396 Mileage: 153750km/95535miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 1010 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 MJ HW: 03L 906 022 B Component: R4 2,0L EDC H01 4378 Revision: 11H01--- Coding: 0104002C18072120 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_ECM20TDI03L906022MJ A01006 ROD: EV_ECM20TDI03L906022MJ.rod VCID: 79F25A8EF80E44D066B 1 Fault Found 5346 - Intake Manifold Flap; Bank 1 P2009 00 [032] - Short to Ground Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 152298 km Date: 2014.06.19 Time: 12:32:25 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: None Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE Component: ESP8 front H04 0240 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 02391 823 56573 VCID: 7CFC439AFF3C71F87DD No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 030100 Shop #: WSC 02399 823 56573 VCID: 2E58B9D279C05368839 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 T HW: 8T1 820 043 T Component: KLIMA 1 ZONE H06 0150 Revision: A0000000 Serial number: 01230120090778 Coding: 34000000 Shop #: WSC 02391 823 56573 VCID: 4280FD62DD58C708771 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H22 0253 Revision: 04022001 Serial number: 00000000299521 Coding: 260050914034AF000001000000001D0D0F1C030800010101000000 Shop #: WSC 02391 823 56573 VCID: 2F66A4D67ECA5A6088F Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 230109 H06 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA Component: E1 - LDS H07 0080 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 F HW: 8K0 919 475 Component: PARKHILFE 4K H06 0040 Revision: 11001001 Serial number: 40140902104406 Coding: 000003 Shop #: WSC 02391 823 56573 VCID: 3C7C839ABFBCB1F83DD 1 Fault Found 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 152523 km Time Indication: 0 Date: 2014.06.19 Time: 14:37:24 Freeze Frame: Temperature: 27.0°C ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: None Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1DN2MI Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C7C839AB7BCB1F83DD Crash sensor for side airbag; driver side: Serial number: 6334MSME461164252 Crash sensor for side airbag; passenger side: Serial number: 6344MSME4612753EG Crash sensor for side airbag; rear driver side: Serial number: 6352QSME3A2017202 Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME6C1F0820M Crash sensor for front airbag; driver side: Serial number: 63732SME5E162F0A9 Crash sensor for front airbag; passenger side: Serial number: 63832SME5F161D3CD No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 E HW: 8K0 953 568 E Component: Lenks.Modul H13 0013 Revision: -------- Serial number: 90315IA7000GC Coding: 000006 Shop #: WSC 02391 823 56573 VCID: 3C7C839ABFBCB1F83DD No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 C HW: 8K0 920 900 C Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9DS3A7P19 Coding: 0F04080002000008050000 Shop #: WSC 02391 823 56573 VCID: 2A50B5C245283F485F1 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 M HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0095 Revision: GB300043 Serial number: 4300G091210089 Coding: 000303 Shop #: WSC 02391 823 56573 VCID: 4B9ED046EA120640847 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 2 Faults Found 01305 - Databus for Infotainment este no lo entiendo 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 7 Reset counter: 94 Mileage: 151051 km Time Indication: 0 Date: 2014.05.13 Time: 07:47:59 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 5 Reset counter: 89 Mileage: 151051 km Time Indication: 0 Date: 2014.05.13 Time: 07:48:01 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008278635 Coding: 011C02204100410001 Shop #: WSC 02391 823 56573 VCID: 4182F26ED85EDC106EB 2 Faults Found aqui los km son diferentes al anterior 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 64 Mileage: 1048575 km Time Indication: 0 01705 - Selection Switch for Mirror-Adjust (E48) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 64 Mileage: 1048575 km Time Indication: 0 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: Redir Fail! Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0116714455 Coding: 0100062000390040012001 Shop #: WSC 02391 823 56573 VCID: 2E58B9D279C05368839 2 Faults Found 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 13 Mileage: 150864 km Time Indication: 0 Date: 2014.05.06 Time: 15:46:41 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 13 Mileage: 150864 km Time Indication: 0 Date: 2014.05.10 Time: 12:44:12 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008365353 Coding: 011C02204100410001 Shop #: WSC 02391 823 56573 VCID: 4084F76AD354D518615 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 F HW: 8K0 907 801 F Component: EPB Audi B8 H06 0070 Revision: 00000003 Serial number: 10000000167640 Shop #: WSC 00000 000 00000 VCID: 3260ADA26DF87788E71 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 02145 785 00200 VCID: F7F6DCB6861AD2A090F No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 P HW: 8T1 035 186 P Component: Concert3 H01 0300 Revision: 00000003 Serial number: AUZ5Z6H1158645 Coding: 0500048004010100015B070000 Shop #: WSC 02391 823 56573 VCID: 448CFB7AC74CC93845D Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A Component: Display 1 Fault Found 00468 - CD-ROM Drive (R92) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 5 Fault Frequency: 151 Reset counter: 54 Mileage: 152228 km Time Indication: 0 Date: 2014.06.12 Time: 16:39:30 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000100665621 Coding: 010C02204000210001 Shop #: WSC 02391 823 56573 VCID: 448CFB7AC74CC93845D 2 Faults Found 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 7 Reset counter: 64 Mileage: 150864 km Time Indication: 0 Date: 2014.05.06 Time: 15:46:42 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 64 Mileage: 1048575 km Time Indication: 0 ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000100665617 Coding: 010C02204000210001 Shop #: WSC 02391 823 56573 VCID: 448CFB7AC74CC93845D No fault code found. End --------------------------------------------------------------------- Monday,04,August,2014,19:36:20:55062 VCDS Version: Release 11.11.4 Data version: 20120807 Chassis Type: 8T0 Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72 VIN: WAUZZZ8K39N058396 Mileage: 153750km/95535miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 1010 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 MJ HW: 03L 906 022 B Component: R4 2,0L EDC H01 4378 Revision: 11H01--- Coding: 0104002C18072120 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_ECM20TDI03L906022MJ A01006 ROD: EV_ECM20TDI03L906022MJ.rod VCID: 79F25A8EF80E44D066B 1 Fault Found 5346 - Intake Manifold Flap; Bank 1 P2009 00 [032] - Short to Ground Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 152298 km Date: 2014.06.19 Time: 12:32:25 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: None Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE Component: ESP8 front H04 0240 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 02391 823 56573 VCID: 7CFC439AFF3C71F87DD No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 030100 Shop #: WSC 02399 823 56573 VCID: 2E58B9D279C05368839 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 T HW: 8T1 820 043 T Component: KLIMA 1 ZONE H06 0150 Revision: A0000000 Serial number: 01230120090778 Coding: 34000000 Shop #: WSC 02391 823 56573 VCID: 4280FD62DD58C708771 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H22 0253 Revision: 04022001 Serial number: 00000000299521 Coding: 260050914034AF000001000000001D0D0F1C030800010101000000 Shop #: WSC 02391 823 56573 VCID: 2F66A4D67ECA5A6088F Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 230109 H06 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA Component: E1 - LDS H07 0080 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 F HW: 8K0 919 475 Component: PARKHILFE 4K H06 0040 Revision: 11001001 Serial number: 40140902104406 Coding: 000003 Shop #: WSC 02391 823 56573 VCID: 3C7C839ABFBCB1F83DD 1 Fault Found 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 152523 km Time Indication: 0 Date: 2014.06.19 Time: 14:37:24 Freeze Frame: Temperature: 27.0°C ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: None Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1DN2MI Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C7C839AB7BCB1F83DD Crash sensor for side airbag; driver side: Serial number: 6334MSME461164252 Crash sensor for side airbag; passenger side: Serial number: 6344MSME4612753EG Crash sensor for side airbag; rear driver side: Serial number: 6352QSME3A2017202 Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME6C1F0820M Crash sensor for front airbag; driver side: Serial number: 63732SME5E162F0A9 Crash sensor for front airbag; passenger side: Serial number: 63832SME5F161D3CD No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 E HW: 8K0 953 568 E Component: Lenks.Modul H13 0013 Revision: -------- Serial number: 90315IA7000GC Coding: 000006 Shop #: WSC 02391 823 56573 VCID: 3C7C839ABFBCB1F83DD No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 C HW: 8K0 920 900 C Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9DS3A7P19 Coding: 0F04080002000008050000 Shop #: WSC 02391 823 56573 VCID: 2A50B5C245283F485F1 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 M HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0095 Revision: GB300043 Serial number: 4300G091210089 Coding: 000303 Shop #: WSC 02391 823 56573 VCID: 4B9ED046EA120640847 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 2 Faults Found 01305 - Databus for Infotainment 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 7 Reset counter: 94 Mileage: 151051 km Time Indication: 0 Date: 2014.05.13 Time: 07:47:59 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 5 Reset counter: 89 Mileage: 151051 km Time Indication: 0 Date: 2014.05.13 Time: 07:48:01 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008278635 Coding: 011C02204100410001 Shop #: WSC 02391 823 56573 VCID: 4182F26ED85EDC106EB 2 Faults Found 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 64 Mileage: 1048575 km Time Indication: 0 01705 - Selection Switch for Mirror-Adjust (E48) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 64 Mileage: 1048575 km Time Indication: 0 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: Redir Fail! Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0116714455 Coding: 0100062000390040012001 Shop #: WSC 02391 823 56573 VCID: 2E58B9D279C05368839 2 Faults Found 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 13 Mileage: 150864 km Time Indication: 0 Date: 2014.05.06 Time: 15:46:41 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 13 Mileage: 150864 km Time Indication: 0 Date: 2014.05.10 Time: 12:44:12 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008365353 Coding: 011C02204100410001 Shop #: WSC 02391 823 56573 VCID: 4084F76AD354D518615 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 F HW: 8K0 907 801 F Component: EPB Audi B8 H06 0070 Revision: 00000003 Serial number: 10000000167640 Shop #: WSC 00000 000 00000 VCID: 3260ADA26DF87788E71 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 02145 785 00200 VCID: F7F6DCB6861AD2A090F No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 P HW: 8T1 035 186 P Component: Concert3 H01 0300 Revision: 00000003 Serial number: AUZ5Z6H1158645 Coding: 0500048004010100015B070000 Shop #: WSC 02391 823 56573 VCID: 448CFB7AC74CC93845D Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A Component: Display 1 Fault Found 00468 - CD-ROM Drive (R92) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 5 Fault Frequency: 153 Reset counter: 54 Mileage: 152228 km Time Indication: 0 Date: 2014.06.12 Time: 16:39:30 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000100665621 Coding: 010C02204000210001 Shop #: WSC 02391 823 56573 VCID: 448CFB7AC74CC93845D 2 Faults Found 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 7 Reset counter: 64 Mileage: 150864 km Time Indication: 0 Date: 2014.05.06 Time: 15:46:42 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 64 Mileage: 1048575 km Time Indication: 0 ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000100665617 Coding: 010C02204000210001 Shop #: WSC 02391 823 56573 VCID: 448CFB7AC74CC93845D No fault code found. End --------------------------------------------------------------------- en otros fallos tambien sale el kilometraje diferente pero creo que viendo uno es suficiente para ver la gran diferencia un saludo y gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
albertoavant Publicado 4 de Agosto del 2014 Autor Denunciar Compartir Publicado 4 de Agosto del 2014 perdon no se a marcado en rojo. en adsres 42 y el 63 marca mas de un millon de km y en otros los que tiene el coche que son 150000 km arriba o abajo. y el codigo de averia que no entiendo es el addres 19 muchas gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
juanitoa6 Publicado 4 de Agosto del 2014 Denunciar Compartir Publicado 4 de Agosto del 2014 que envidia a mi el mileage no me aparece, imagino que porque mi vag no se relaciona bien con la ECU. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
