hola,estoy liado con el cable de vagon,mas bien desesperado....jajjajaja me hace bien el test,pero si quiero entrar en instrument,para modificar el idioma ,no me deja,tambien intento borrar los errores de servicio y abs y nada...uufff estoy muy perdido!!
Thursday,28,August,2014,18:38:20:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Address 03: ABS Brakes (4D0 907 379 L)
18:38:17
1.0 km/h Front Left
1.0 km/h Front Right
1.0 km/h Rear Left
1.0 km/h Rear Right
Thursday,28,August,2014,18:40:19:62939
VCDS Release 12.12.0: SRI Reset
Control Module Part Number: 4D0 919 033 K Labels: 4D0-919-033-MYW.lbl
Component:D2-KOMBIINSTRUMENT__D21, Coding:00083
Operation: Please select an operation
Channel Description Unit Current val. New val.
05 Distance to Oil Change (OEL) km x1000 8 ---
06 Distance to Inspection 1 (IN1) km x1000 16 ---
07 Time to Inspection 1 (IN1) Days x10 0 ---
08 Time to Inspection 2 (IN2) Days x10 0 ---
Thursday,28,August,2014,19:31:26:62939
Thursday,28,August,2014,21:17:00:62939
Address 17: Instruments Labels: 4D0-919-033-MYW.LBL
Component and/or Version: D2-KOMBIINSTRUMENT__D21
Software Coding: 00083
Work Shop Code: WSC 00186
VCID: 2C57E23BDFFEEC7E18B-5072
No fault code found.
Thursday,28,August,2014,21:18:43:62939
21:18:41 Group 001: Weel Speed Sensors
1.0 km/h Front Left
1.0 km/h Rear Left
1.0 km/h Rear Right
1.0 km/h Front Left
1.0 km/h Rear Left
1.0 km/h Rear Right
21:18:41 Group 002: Miscellaneous
0 Brake lightsw. (0=OFF) (1=ON)
0 Voltage to ABS Return Pump(0=OK)
0 ABS solenoid Relay J106(1=OK)
1 Not in use
Friday,29,August,2014,08:46:59:62939
Adaptation Channel 000:
Stored value ---
Test value 000
Note: SAVE
Ch. 00 Resets
All Factory
Defaults
Friday,29,August,2014,08:47:40:62939
08:47:38
1.0 km/h Front Left
1.0 km/h Rear Left
1.0 km/h Rear Right
Friday,29,August,2014,08:49:52:62939
08:49:51 Group 001: Weel Speed Sensors
1.0 km/h Front Left
1.0 km/h Rear Left
1.0 km/h Rear Right
08:49:51 Group 002: Miscellaneous
1 Not in use
Friday,29,August,2014,09:04:09:62939
Chassis Type: 4D - Audi A8 D2 (1994 > 2003)
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
02
Address 25: Immobilizer Labels: 4A0-953-234.lbl
Part No: 4A0 953 234 F
Component: IMMO AUZ9Z0T4776505 D77
Coding: 00000
Shop #: WSC 00000
VCID: 2541171FBF14DD36C75-5072
Address 01: Engine Labels: Redir Fail!
Part No: 4D0 907 557 J
Component: 4,2L V8/4V MOTR AT D01
Coding: 04263
Shop #: WSC 00000
VCID: 3365F94701C0B386591-4A9C
Readiness: N/A
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
Part No: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 7680
Shop #: BB 37680
VCID: 377DCD5715B85FA6659-5072
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
30-00 - Open or Short to Plus
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4D0 820 043 C
Component: D2-KLIMAVOLLAUTOMAT_D03
Coding: 00180
Shop #: WSC 02314
VCID: 1C3732FB8C5E1CFE68B-2534
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 K
Component: Airbag V AUDI D00
Coding: 01022
Shop #: WSC 02314
VCID: 3B75D16729907BC6811-5000
Address 02: Auto Trans Labels: None
Part No: 4D0 927 156 E
Component: AG4 GETRIEBE 018 D40
Coding: 00000
Shop #: WSC 00000
VCID: 2B55E127D9F0EB46111-4F1E
1 Fault Found:
00526 - Brake Light Switch-F
03-00 - No Signal
End ---------------------------------------------------------------------
Friday,29,August,2014,09:11:23:62939
02
Coding: 00000
Shop #: WSC 00000
Coding: 04263
Shop #: WSC 00000
Readiness: N/A
Shop #: BB 37680
Coding: 00180
Shop #: WSC 02314
Coding: 01022
Shop #: WSC 02314
VCID: 3B75D16729907BC6811-5072
Coding: 00000
Shop #: WSC 00000
VCID: 2B55E127D9F0EB46111-4F8E
Friday,29,August,2014,11:20:03:62939
02
Coding: 00000
Shop #: WSC 00000
VCID: 2541171FBF14DD36C75-50E6
Coding: 04263
Shop #: WSC 00000
Readiness: N/A
Shop #: BB 37680
VCID: 377DCD5715B85FA6659-5000
1 Fault Found:
Coding: 00180
Shop #: WSC 02314
Coding: 01022
Shop #: WSC 02314
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
03-00 - No Signal
