Tras el cambio de la bateria del coche por la varta I1, al encender coche me marca fallo de sistema de frenos, he intentando borrarlo con la bateria nueva y la antigua y no hay forma.
Tampoco me deja acceder al modulo de regulacion de bateria 61.
Pego lo que me lee el vag-com
VCDS Version: Release 11.11.3
Data version: 20120401
Wednesday,24,September,2014,19:45:51:32264
Chassis Type: 4F0
Scan: 01 03 05 08 09 15 16 17 19 42 46 4F 52 53 55 56 5F 62 72 76
VIN: WAUZZZ1F8BN016677 Mileage: 183850km/114239miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 FG HW: 03L 906 022 FG
Component: R4 2,0L EDC H05 6420
Revision: 11H05--- Serial number:
Coding: 0105002C18072120
Shop #: WSC 02325 785 00200
ASAM Dataset: EV_ECM20TDI03L906022FG A01007
ROD: EV_ECM20TDI03L906022FG.rod
VCID: 6FE7CD65B6862D1
1 Fault Found:
4699 - Function Restriction due to Received Malfunction Value
U1113 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 183852 km
Date: 2010.04.01
Time: 00:04:05
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
Component: ESP8 front H03 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0020859
VCID: 6DDBD76D748ADF1
No fault code found.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901621296
Coding: 0000001
Shop #: WSC 02324 785 00200
VCID: 254BEF4DECFA271
Part No: 4F0 910 132 D
Component: FBSAUDIC6 EZS H03 0020
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0054
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AK
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000076 Serial number: 00000030553638
Coding: 0000020
VCID: 1D3BC7ADC4AAEF1
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AB HW: 4F0 907 279
Component: ILM Fahrer H27 0360
Revision: 00000000 Serial number: 4F0907279
Coding: 0003121
Shop #: WSC 02335 785 00200
VCID: 69D3A37D4062C31
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
Address 15: Airbags Labels: None
Revision: ------(- Serial number: 003F9053DBY2
Coding: 30314236303635303032554A3049344630532D39303632
ASAM Dataset: EV_Airga10AURG4 001001
ROD: N/A
VCID: 55AB9F8D341A771
No ASAM data for: "EV_Airga10AURG4" (VW36)
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 933 Q HW: 4F0 920 933 Q
Component: KOMBIINSTR. H09 0208
Revision: 00000000 Serial number: EVL22EX6A
Coding: 0F74090502000008050100
Shop #: WSC 02391 823 56573
VCID: 356B3F0D9C5A571
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0035
Revision: LB100029 Serial number: 2900L1062981F7
Coding: 000B03
VCID: 3973333DB042B31
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0125
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0004000091878
Coding: 011C06204040410001
VCID: 489546F9FBA8DA9
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H29 0250
Revision: 02500029 Serial number: 01323662990000
Coding: 0133361
VCID: 356B3F0D5C5A571
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000725727
Coding: 0001104
VCID: DEB900A1092C349
Address 52: Door Elect, Pass. Labels: None
VCID: 55AB9F8DBC1A771
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000111
Shop #: WSC 02145 785 00200
VCID: 2143FB5DF8D2CB1
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3F875D256E669D1
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4G0 035 056 H HW: 4G0 035 056
Component: Radio U STD H51 0134
Revision: AB001007 Serial number: 469G20A7527364
Coding: 010003020100000000
VCID: 2649E84151FC2C9
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 670 K HW: 4E0 035 670 C
Component: H-BNT-EU H49 0187
Revision: -------- Serial number: 453G.0A7535085
Coding: 01010000000283ED01000715EF6300030000
Shop #: WSC 00158 572 87472
VCID: 2953E37D40E2031
Subsystem 1 - Part No: 8R0 060 884 BK
Component: EUR 2014 1703
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H42 0098
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 S
Component: Bedienteil MM H01 0060
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
1 Fault Found:
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 183852 km
Time Indication: 0
Date: 2010.04.01
Time: 00:07:09
Freeze Frame:
Voltage: 14.50 V
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0357
Revision: Serial number: 0004000088967
Coding: 010804204040220001
VCID: 468948C1F1BCCC9
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0004000088962
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H02 0500
Revision: 00H02000 Serial number: 12691017905974
Coding: 0200006
VCID: 2A511C7185E4089
End ---------------------------------------------------------------------
Chassis Type: 4F0
1 Fault Found:
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 183852 km
Date: 2010.04.01
Time: 00:04:05
Coding: 0020859
Coding: 0000001
Coding: 0000020
1 Fault Found:
Coding: 0003121
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
ROD: N/A
Cannot be reached
Coding: 000B03
Coding: 0133361
Coding: 0001104
No Faults Found
Revision: --H05---
Coding: 0000111
Coding: 0000003
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 183852 km
Time Indication: 0
Date: 2010.04.01
Time: 00:07:09
Freeze Frame:
Voltage: 14.50 V
Coding: 0200006
pregunto; una vez que te ha salido todo este listado has probrado ha darle a borrar todos los fallos desde el autoscan???
desde ahí mismo puedes entrar uno por uno para ir borrando los errores también......
desde select entrando en el modulo 61 de la bateria dices que no te deja entrar??? igual es un problema del cable que no lo lee, pero si te deja entrar en el resto de unidades deberia dejarte.
Danos un poco más información
Finalmente he podido anular todos los fallos, se trataba de un rele quemado... Lo descubri a traves de otros post de este gran foro.
Pero sigo sin poder acceder a los modulos de bateria o regulador, intenta conectar pero no lee nada y al rato da error.
Un saludo,
Un saludo,
De que rele se trata y dónde está situado?
