Estimados hoy realice Scanner al Auto y me tiro los siguientes errores
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 CJ
Component: 1.8L R4/5VT MOTR HS D01
Coding: 04000
Shop #: WSC 00001
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00001
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0105
Coding: 00040
Shop #: WSC 00001
7 Faults Found:
- Temperature Sensor in Fresh Air intake duct (G89)
29-10 - Short to Ground - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 900 N
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 00544
Shop #: WSC 06324
XXXXXXXXXXXXXXXXX AUZ7Z0C2378504
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D16
Coding: 14184
Shop #: WSC 06324
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00001
Address 56 -------------------------------------------------------
Controller: 8L0 035 186 D
Component: concert II NP2 0050
Coding: 05000
Shop #: WSC 00001
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
Que significa y que piezas debo cambiar?
SALUDOS
cami
Pues de momento si no los as hecho ya, tienes que borrarlos todos y darte una vuelta para ver si te vuelve a aparecer. Lo hiciste ya?
saludos
no, no lo he hecho. pero lo haré.
Gracias.
