A3 tdi 2.0 Publicado 20 de Noviembre del 2014 Denunciar Publicado 20 de Noviembre del 2014 Buenas noches a todos! Tras encenderse esta tarde al testigo de avería de motor, le he pasado el VagCom y este ha sido el resultado: -----------------------------------INICIO------------------------------------- Thursday,20,November,2014,21:10:34:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WAUZZZ8TXXXXXXXXX License Plate: Mileage: 108660km-67518mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8T (8T0) Scan: 01 03 05 06 07 08 09 0E 15 16 17 19 36 37 42 46 47 52 53 55 56 77 VIN: WAUZZZ8T98A002008 Mileage: 108660km/67518miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb Part No SW: 8K0 907 401 HW: 8K0 907 401 Component: 3.0TDI EDC17 H01 0006 Revision: --H01--- Coding: 01140023180F0118 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM30LTDIA5 A01008 ROD: EV_ECM30LTDIA5.rod VCID: E8DFDE2B1386805EBC3-80BD 1 Fault Found: 5308 - Throttle Body Actuator Bank 1 (J338) P0638 00 [175] - Implausible Signal MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 7 Mileage: 108570 km Date: 2014.11.20 Time: 18:08:21 Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb Part No SW: 8T0 959 760 HW: 8T0 959 760 Component: MEM-BFS H08 0026 Revision: AA000000 Serial number: 00001001003005 Coding: 08017025002444441000 Shop #: WSC 06325 000 00000 VCID: 55A167DF3CF48DB6975-8000 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 12 Reset counter: 255 Mileage: 95821 km Time Indication: 0 Date: 2014.06.12 Time: 16:01:00 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 279 D Component: BCM1 1.0 H19 0253 Revision: 05019001 Serial number: 00000000015315 Coding: 260050910114BF110009000300005D5D4F9C038800010141000000 Shop #: WSC 00417 572 88449 VCID: 306FF64B63D6889E243-8065 Subsystem 1 - Part No SW: 8T1 955 119 B HW: 8J1 955 119 Labels: 1KX-955-119.CLB Component: WWS 200407 H13 0040 Coding: 00FD11 Subsystem 2 - Part No SW: 8T0 955 559 HW: 4E0 955 559 B Component: RLS H12 0001 Coding: 02532C Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G Component: E1 - LDS H07 0070 1 Fault Found: 03110 - Active Steering Control Module (J792) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 176 Mileage: 108570 km Time Indication: 0 Date: 2014.11.20 Time: 18:05:00 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 289 C HW: 8K0 907 289 C Component: BCM2.01 H38 0253 Revision: 00002001 Serial number: 0103951668 Coding: 011E1680003904C0032000 Shop #: WSC 06325 123 12345 VCID: 3979CB6FB0AC49D693D-806C Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0030 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 2 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 217 Mileage: 108570 km Time Indication: 0 Date: 2014.11.20 Time: 18:09:43 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 217 Mileage: 108570 km Time Indication: 0 Date: 2014.11.20 Time: 18:09:46 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 336DQ077506058 Coding: 0000001 Shop #: WSC 06325 000 00000 VCID: 3169F34FA8DC81962BD-8064 1 Fault Found: 00856 - Radio Antenna 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 6 Reset counter: 208 Mileage: 104309 km Time Indication: 0 Date: 2014.10.22 Time: 22:12:38 ------------------------------------------------------------------------------- End --------------------------------------------------------------------- En rojo he puesto el error que más me preocupa y del que no encuentro respuesta... alguien me podría decir de que se trata? Muchas gracias a todos!! Responder
storm79 Publicado 3 de Diciembre del 2014 Denunciar Publicado 3 de Diciembre del 2014 Lo poco que te puedo decir: unidad del mando de la valvula de mariposa J338 - señal no plausible. Esto me pone en los codigos de vag que me baje del foro A4 Responder
