Hola a todos del foro-
He conectado el Vag-com a mi Audi A6 Avant 3.0 TDI del 2009 y he copiado los errores que me salían, por mucho que miro no consigo localizar por que se me enciende la luz del Chek.
Así que agradacería a los expertos que me puedan ayudar.
Gracias de antemano-
Os adjunto lo que me salio en el vag com,
VCDS Version: Release 11.11.3
Data version: 20120401
Tuesday,04,November,2014,10:39:15:32264
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 76 77
Mileage: xxxxxxxxxxxxxx
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0090
Revision: 00H05000 Serial number: 10602401137021
Coding: 0000131
Shop #: WSC 02325 785 00200
VCID: 254BEF4DECFA271
Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
No fault code found.
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 H HW: 4E0 035 729
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 350GU087893422
Coding: 0001004
Shop #: WSC 02335 785 00200
VCID: 2855E6799BE83A9
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000548968
Coding: 0000278
VCID: 1C3DCAA9DFB0E69
1 Fault Found:
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 201
Reset counter: 99
Mileage: 171854 km
Time Indication: 0
Date: 2014.08.03
Time: 00:55:59
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H21 0310
Revision: 00000000 Serial number: 4F0907279
Coding: 0002121
VCID: 346D020957204E9
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8501210
Shop #: WSC 00000 000 00000
VCID: 1A31CCB1D584989
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 72U31T978
Coding: 3073158
Shop #: WSC 00482 572 95788
VCID: 234FF155E2CED91
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0871200D1
Coding: F5519E7730320600
VCID: 2D5B176DB40A1F1
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 364GQ087805303
VCID: 3B7F29357A7E811
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist
Cannot be reached
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
