Despues de comprar el "cablecito" este es el resultado:
Tuesday,02,December,2014,16:30:31:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4B43N092697 License Plate:
Mileage: 182230km-113232mi Repair Order:
Chassis Type: 4B (4B - Audi A6 C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAUZZZ4B43N092697 Mileage: 182230km/113232miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 4Z7 907 401 B
Component: 2.5l/4VTEDC G000AG D09
Coding: 01016
Shop #: WSC 02325
VCID: 3C7D2CB02C9566FE88B-49D8
Subsystem 1 - Part No: 00018059
Component: 130 106EC150_1.R75096641382
WAUZZZ4B43N092697 AUZ7Z0C2384159
1 Fault Found:
00550 - Start of Injection Regulation
08-10 - Control Limit Surpassed - Intermittent
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 H
Component: AG5 01V 2.5lTDI RdW 2121
Coding: 00001
Shop #: WSC 00000
VCID: 4B9F7F6C793BD146311-5000
1 Fault Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06357
Shop #: WSC 00000
VCID: 4A917A687641C84E0A7-5072
2 Faults Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 H
Component: Airbag 8.4EP 2000
Coding: 0000606
Shop #: WSC 02325 785 00200
VCID: 54AD6410F4058EBE60B-5072
No fault code found.
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 933 M
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 04160
Shop #: WSC 01234
VCID: 2D5B11F4E7EFFF760F5-5000
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01304 - Radio
49-10 - No Communications - Intermittent
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
VCID: 4797435C65533526159-5000
3 Faults Found:
01316 - ABS Control Module
79-10 - Please Check Fault Codes - Intermittent
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
01400 - Suspension Level Control
11-10 - Control Limit Not Reached - Intermittent
Address 77: Telephone Labels: None
Part No: 8E0 862 333 A
Component: Telefon Nokia3 0303
Coding: 0002124
VCID: 2757E3DC9513D526F59-5072
1 Fault Found:
01522 - Handset for Telephone (R37)
004 - No Signal/Communication
End ---------------------------------------------------------------------
Tuesday,02,December,2014,16:46:20:65217
75 76 77
Coding: 01016
Shop #: WSC 02325
VCID: 3C7D2CB02C9566FE88B-4A3A
1 Fault Found:
Readiness: N/A
Coding: 00001
Shop #: WSC 00000
VCID: 4B9F7F6C793BD146311-5072
1 Fault Found:
18265 - Load Signal
Coding: 06357
Shop #: WSC 00000
VCID: 4A917A687641C84E0A7-5000
2 Faults Found:
18265 - Load Signal
Coding: 0000606
Coding: 04160
Shop #: WSC 01234
VCID: 2D5B11F4E7EFFF760F5-5072
2 Faults Found:
01304 - Radio
Coding: 25500
Shop #: WSC 09999
3 Faults Found:
Coding: 0002124
VCID: 2757E3DC9513D526F59-50E6
1 Fault Found:
Como informacion :
Le he cambiado las 4 balonas por unas Arnott
El testigo de temperatura del agua no funciona
y me gustaria subir la altura de los faros(alumbran muy bajo)
La radio sintoniza muy mal las emisoras
Tambien me gustaria subir la altura normal del coche,aqui con la nieve y el estado de las carreteras es muy recomendable
A priori parece que el sensor del liquido refrigerante te falla. que el regulador de altura igual por eso te da varios fallos en distintos sitios.
Para regular la altura de faros, tendrías que hacer una calibración del coche para que el coche sepa cual es la altura que tiene, porque con el cambio de balonas seguramente esté midiendo mal.
Borra también todos los errores para quitar los históricos y quedarte con los que están saliendo actualmente, para centrar el tiro. Borras, te das una vuelta larga y luego vuelves a mirar los errores.
En la suspensión aparece error del sensor G291, que está en la caja de válvulas. Igual se te ha cascado la caja de válvulas. Pero primero limpia los errores.
