HouseMusic Publicado 22 de Diciembre del 2014 Denunciar Publicado 22 de Diciembre del 2014 (editado) Hola! Llevo un tiempo con las luces del ABS y ESP en el cuadro encendidas, le he pasado el vagcom: Monday,22,December,2014,16:39:43:65217 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: License Plate: MESSAGE2 Mileage: 166660km-103557mi Repair Order: Chassis Type: XX (8N - Audi TT (1999 > 2007)) Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77 VIN: XXXXXXXXXXXXXXXXX Mileage: 166660km/103557miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06A-906-032-AJQ.lbl Part No: 8N0 906 018 Q Component: 1.8L R4/5VT 0004 Coding: 05500 Shop #: WSC 01236 VCID: 3F875BBC3D837DE6AD9-5000 3 Faults Found: 17526 - Oxygen (Lambda) Sensor Heating; B1 S2 P1118 - 35-00 - Open Circuit 18057 - Powertrain Data Bus P1649 - 35-10 - Missing Message from ABS Controller - Intermittent 17522 - Oxygen (Lambda) Sensor; B1 S2 P1114 - 35-00 - Internal Resistance too High Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl Part No: 8N0 907 379 D Component: ESP 20 CAN V006 Coding: 23049 Shop #: WSC 01236 VCID: 3D7B21B4378F6FF6BF5-49D8 2 Faults Found: 65535 - Internal Control Module Memory Error 00-00 - - 00778 - Steering Angle Sensor (G85) 49-00 - No Communications ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8N0-820-043.lbl Part No: 8N0 820 043 A Component: TT-KLIMAVOLLAUTOMAT D03 Coding: 00040 Shop #: WSC 01236 VCID: 2855E0E0C80DDA5EFC3-2534 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8N8-909-601.lbl Part No: 8N8 909 601 Component: Airbag Front+Seite 0005 Coding: 10102 Shop #: WSC 01236 VCID: F7F7739CD53305A6259-50E6 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl Part No: 8N1 920 860 J Component: KOMBI+WEGFAHRS. M73 D54 Coding: 00044 Shop #: WSC 65008 VCID: 3A712AA826A158CE9A7-4A9C XXXXXXXXXXXXXXXXX AUZ5Z0B4246166 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8Nx-962-267.lbl Part No: 8N7 962 267 Component: Zentralverrieg. D04 Coding: 06656 Shop #: WSC 00050 VCID: FDFB61B4F70F2FF67F5-4DD6 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D004 Coding: 00009 Shop #: WSC 01236 VCID: E5CB29D47F9F8736875-5072 No fault code Cómo se puede comprobar si es el modulo de abs o el sensor g85? Editado 22 de Diciembre del 2014 por HouseMusic Responder
bala Publicado 23 de Diciembre del 2014 Denunciar Publicado 23 de Diciembre del 2014 Haz un ajuste basico del sensor g85,seguramente que si lo hace correctamente desaparezca el otro error ya que tiene pinta de saltar por culpa del g85,no recuerdo ahora mismo como se hacia pero busca por la red que ahi mucha info Salu2 enviado por tapatalk Responder
racing gear Publicado 23 de Diciembre del 2014 Denunciar Publicado 23 de Diciembre del 2014 Usa el buscador q hay muchisima info. Aparte de hacer un ajuste basico (con el vagcom), no te olvides d mirar que tengas bien los fusibles que hay en la bateria. Un saludo Responder
HouseMusic Publicado 23 de Diciembre del 2014 Autor Denunciar Publicado 23 de Diciembre del 2014 He mirado los fusibles y estan bien, despues he hecho un borrado de fallos y estos son los que no se borran y persisten: Monday,22,December,2014,16:44:44:65217VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.0.0Data version: 20130910VIN: License Plate: DESPUESBORRARMileage: 166660km-103557mi Repair Order:Chassis Type: XX (8N - Audi TT (1999 > 2007))Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77VIN: XXXXXXXXXXXXXXXXX Mileage: 166660km/103557miles-------------------------------------------------------------------------------Address 01: Engine Labels: 06A-906-032-AJQ.lbl Part No: 8N0 906 018 Q Component: 1.8L R4/5VT 0004 Coding: 05500 Shop #: WSC 01236 VCID: 3F875BBC3D837DE6AD9-5000No fault code found.Readiness: 0000 0000-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl Part No: 8N0 907 379 D Component: ESP 20 CAN V006 Coding: 23049 Shop #: WSC 01236 VCID: 3D7B21B4378F6FF6BF5-4A9C1 Fault Found:00778 - Steering Angle Sensor (G85) 49-00 - No Communications-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8N0-820-043.lbl Part No: 8N0 820 043 A Component: TT-KLIMAVOLLAUTOMAT D03 Coding: 00040 Shop #: WSC 01236 VCID: 2855E0E0C80DDA5EFC3-2566No fault code found.-------------------------------------------------------------------------------Address 15: Airbags Labels: 8N8-909-601.lbl Part No: 8N8 909 601 Component: Airbag Front+Seite 0005 Coding: 10102 Shop #: WSC 01236 VCID: F7F7739CD53305A6259-50E6No fault code found.-------------------------------------------------------------------------------Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl Part No: 8N1 920 860 J Component: KOMBI+WEGFAHRS. M73 D54 Coding: 00044 Shop #: WSC 65008 VCID: 3A712AA826A158CE9A7-4A9C XXXXXXXXXXXXXXXXX AUZ5Z0B4246166No fault code found.-------------------------------------------------------------------------------Address 35: Centr. Locks Labels: 8Nx-962-267.lbl Part No: 8N7 962 267 Component: Zentralverrieg. D04 Coding: 06656 Shop #: WSC 00050 VCID: FDFB61B4F70F2FF67F5-4DD6No fault code found.-------------------------------------------------------------------------------Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D004 Coding: 00009 Shop #: WSC 01236 VCID: E5CB29D47F9F8736875-50E6No fault code found.End --------------------------------------------------------------------- luego he intentado ajustar el sensor g85 segun este manual: 11 – CALIBRADO DEL SENSOR DE ANGULO DE DIRECCIÓN Previamente a comenzar con el calibrado tenemos que seguir el siguiente procedimiento:1º - Arrancamos el vehículo2º - Giramos el volante en cualquier dirección (izquierda y derecha) aplicando un giro o varios, de tolerancia superior a 10º3º - Llevamos el volante hasta la posición 0, dejando el volante en posición completamente recta. Sólo permite un intervalo de error de 5º.4º - Recorremos a muy baja velocidad unos metros con el vehículo para asegurarnos de que el trazado que describen las ruedas sigue una línea recta5º - Iniciamos el Vag-Com y nos dirigimos a la dirección 3 – ABS BRAKES sin apagar el contacto del vehículo ni el funcionamiento del motor y salimos del vehículo evitando que halla grandes cargas adicionales sobre el y continuar el proceso desde el exterior.Para comenzar a calibrar el sensor de ángulo de dirección iniciamos el software Vag-Com inmediatamente, sin apagar el contacto del vehículo ni el funcionamiento del motor, nos dirigimos a:Dirección 03 – ABS BRAKES -> [Acceso-11]Introducimos la cifra 40168 en el campo y presionamos (Hazlo!)Inmediatamente después, nos dirigimos a:Dirección 03 – ABS BRAKES -> [Ajuste Básico-04]En (Group) introducimos vamos a 001 y damos a GO! Hasta obtener el OK del ajuste. y me sale este error: Tuesday,23,December,2014,16:22:18:65217VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.0.0Data version: 20130910VIN: License Plate: ADJUSTMENT---------------------------------------------------------------------------------------------------------------------------------------------------------------- Address 03: ABS Brakes (8N0 907 379 D)16:21:52 Group 060: Adjustment of Steering Angle Sensor (G85) Adjustment Adjustment Not Possible Adjustment Status 0.00° Steering Angle N/A Steering Angle Sensor (G85) cómo lo veis? Responder
HouseMusic Publicado 23 de Diciembre del 2014 Autor Denunciar Publicado 23 de Diciembre del 2014 leyendo en un foro ingles, he hecho un chequeo del angulo de giro del volante en el bloque de ABS/measuing blocks: Address 03: ABS Brakes (8N0 907 379 D)20:53:33 Group 004 -10.50° Steering Angle Sensor (G85) -0.51 m/s^2 Lateral Acc. Sensor (G200) -0.36°/s Rotation Rate (G202) Yaw Rate N/A al mover el volannte no se mueven los grados, queda siempre en -10.50... Responder
Estol Publicado 23 de Diciembre del 2014 Denunciar Publicado 23 de Diciembre del 2014 Tienes estropeado el sensor de giro del volante o el conector o cables están mal. Responder
HouseMusic Publicado 24 de Diciembre del 2014 Autor Denunciar Publicado 24 de Diciembre del 2014 Tienes estropeado el sensor de giro del volante o el conector o cables están mal. A q conector o cables te refieres? Responder
txori Publicado 22 de Enero del 2015 Denunciar Publicado 22 de Enero del 2015 Perdona cambio un poco de tercio. El fallo de lambda no te ha vuelto a aparecer? Te lo pregunto porque tengo ese mismo fallo, lo borro y me vuelve aparecer a la semana o 500 km, y de humos el coche va bien, seguro. Suerte con tu problema del ABS. Responder
HouseMusic Publicado 12 de Febrero del 2015 Autor Denunciar Publicado 12 de Febrero del 2015 Le cambié las 2 sonda lambda q me daban fallo, ahora estan ok.... Las compre en oscaro y se las cambie yo mismo alquilando un elevador para q fuera mas comodo, en una hora lo tienes listo sin ser muy manitas... El problema del abs viene del sensor g85, he pedido uno a un desguace a ver si lo puedo solucionar, nuevo vale 310+IVA, un hachazo... Responder
HouseMusic Publicado 2 de Abril del 2015 Autor Denunciar Publicado 2 de Abril del 2015 Después de probar con varios sensores de giro llevé el TT a un experto en diagnosis y me dice q el modulo ABS esta averiado, no le deja conectar con mi tipo de motor APP... Desmonté el modulo abs y es el num. 8N0 907 379 D, alguno que tenga el etka me podría decir los módulos q son compatibles con el mío para encontrar uno de segunda mano? Responder
