demon Publicado 30 de Diciembre del 2014 Denunciar Publicado 30 de Diciembre del 2014 Address 13: Auto Dist. Reg (J428) Labels: None Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A Component: ACC Bosch MQB H03 0141 Serial number: 18041376510484 Coding: 00001900FE0339 Shop #: WSC 00028 028 00207 ASAM Dataset: EV_ACCMRRBoschVW372 001013 ROD: EV_ACCMRRBoschVW372_SE37.rod VCID: 3561C75F94B4ADB6775-8060 9 Faults Found: 15360768 - Component Protection U1101 00 [009] - Active Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:08 1058 - Databus U1123 00 [009] - Received Error Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:07 1059 - Databus U1123 00 [009] - Received Error Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:07 1078 - Databus U1123 00 [009] - Received Error Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:07 1024 - Databus U1123 00 [009] - Received Error Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:08 0261 - Databus U1121 00 [009] - Missing Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:07 0284 - Databus U1121 00 [009] - Missing Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:07 1027 - Databus U1123 00 [009] - Received Error Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:07 1028 - Databus U1123 00 [009] - Received Error Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 133 Mileage: 11758 km Date: 2014.12.28 Time: 00:04:08 ------------------------------------------------------------------------------- Responder
ximo@6 Publicado 1 de Enero del 2015 Denunciar Publicado 1 de Enero del 2015 (editado) la unidad 13 es el acc control de distancia pero ningún error de los que tienes puesto coincide con los que lleva vas para esta unidad la protección de componentes es el error 2048 y tu tienes un disparate de números elegiste bien el modelo antes de hacer el scan?, has puesto la unidad nueva?, todos los errores hacen uso a la memoria, Editado 1 de Enero del 2015 por ximo@6 Responder
